Question about Garden
I was given mkd lawn tractor been sitting for 2 yrs changed oil/fresh gas battery started right up idled for about 10 mins turns over now will not start
Seems to be not getting enough fuel do you think its a carb issue
    New Friend:
Starter switch
Posted on Apr 21, 2017
  • 3,182 Answers
Clean the carb and filter .
My lawn tractor craftsman 14.5hp IC OHV B&S stalls approx. 5 mins after starting so I restart and it can stall in another 10-15 min again and so on.
you may have some debris in your gas tank blocking the pickup tube. It will float away when the mower dies, then block the tube after it runs again.
Jan 03, 2017 | Craftsman Garden
Mower will not start after changing the battery out and checking all connectioncs
U could try to use some starting fluid spray into carb and have someone crank it right away But first do you have fresh gas in the tractor if not I would drain and fill tank with fresh gas. Also I always change my spark plugs at the beginning of the season,
Apr 10, 2014 | Husqvarna Riding Lawn Mower 42 Inch Cut...
My 97 poulan lawn tractor runs strong for a few min. then acts like it;s running out of gas and dies out. I changed the plug ,fuel filter and added fresh gas to no avail. the air cleaner looks good as...
It sounds like you have some debris or water in the carberator. You can drain the bowl easily depending on the style of carb. Most newer units take a 7/16 or 1/2 inch opened end wrench and just loosen the bowl bolt or valve whichever it might be until you get fuel or fluid flow. If there is water or other debris I recommend dumping the tank and flushing the fuel system with a good carb cleaner.
Oct 24, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a 1991 Honda accord has been sitting for years now it wont start where should I start I was told that the gas turns to funk after sitting for a long time.
if it is posible for you to drain the the old gasoline out and refill the tank with fresh gasoline that would be great, but if you only have a1/4 tank and draining the tank is not posible fill your tank up with supreme gas not regular the better grade gas with the high octane will dilute the old gas and help burn off the gas when the car starts.if you have more then 1/2 a tank try to pump out the gas with a driil pump, you can buy these a your local hardware store insert hose in filler neck of the should also remove the spark plugs and with and oil can add 8 good pumps of the can of motor oil in the cylinders do not replace plugs **** with a freshly charged battery turn the engine over few time in 2 or 3 second intervals this will kleen any rust that would have built up on the cylinder walls and also lube up the cylinder wall so that at start up the cylinder wont be dry ,add a few more sqirts of oil between turnovers.Replace spark plug if old ones look bad put spark plug in and start her up its going to smoke a bit at firts **** it will stop after the oil that was put in the cylinders burns off,let the engine idle for 10-15 minutes before putting any strain on motor give it a chance to clean out cylinders burn a few tanks of gas and change gas filter it should be fine.
Apr 04, 2011 | 1991 Honda Accord
Truck has set for two yrs. i would crank an go around the coner put insurance on it drove a few days later it started running sluggish it kills at stop it cranks right back i put a tune up changed plugs...
After sitting for 2 years, the gas has moisture/water and it's pretty much not gas anymore. It's like your car needs 87 octane and you are running on 80 octane, just enough to fire off but not strong enough to to keep a good idle/firing. I would drain all the gas out and use a higher octane gas for a half of tank just to clean the lines and injectors. Fill the tank up 1/2 with high octane and use a bottle of injector cleaner. This should clear up the sluggish problem. Also it's a good idea to change the oil and run an engine cleaner through. Drain a quart of oil, and pour in the engine cleaner. Let engine run for about 5 min for oil to heat up and circulate. Drain oil and change oil filter, put in new oil.
Jul 06, 2010 | 1991 Chevrolet C1500
It runs normally at high revs but dies on idle
the units came out with EPA carb's some have idle screw adjustment and preset high jet, or the other way depending on the unit. try and change the fuel, use only high octane fuel for 2 cyc no ethanol with fresh oil mix, run for about 5 to 10 min's. if your carb has adjustment screws set your low side idle screw but still change the fuel.
Sep 03, 2009 | Homelite Mighty Lite Lawn Trimmer
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I have a Craftsman lawn tractor 21.5 hp, model no. 917.272463. The engine starts well, but while running it spits and sputters every second or so, whether at idle or at full throttle. I changed the fuel...
Try changing the its oil-seals. The problem lies there. It may be damaged or the oil-seals are now smaller than its is used to and it is because of the heat. The oil-seal are rounded things that are made of rubber.
May 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Last weekend I sharpened the blades, changed the oil filter, the oil, and the spark plug, put in fresh gas and started the mower up and mowed the lawn no problem. This weekend, it started right up but when...
There is an operator presence switch under the seat...if the mower shuts off when you release the brake, this switch is faulty and must be replaced
May 02, 2009 | Garden
Gas in the oil in my craftsman 17.5 riding mower
You have a bad antibackfire valve. It is located on carburator below the fuel bowl. You can replace it, or as I advise others, install an inline shutoff valve. Turn the fuel valve on to start it, then turn it off when you shut the engine down.
Mar 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
