Question about The Computers & Internet
I need to have step by step instructions on how to load the fonts in my Designerl from a flobby
How to install malayalam font
Step 1
Download the Malayalam Unicode font Anjali Old Lipi to your desktop (see Resources).
Step 2
Open "My Computer" and navigate to C: > Windows > Fonts.
Step 3
Drag the font file from your desktop to the "Fonts" directory.
Step 4
Launch Google Chrome.
Step 5
Click the wrench icon in the upper-right corner. Click "Under the Hood" button and "Customize fonts."
Step 6
Click the listbox next to the "Encoding" label and select the "Western (ISO-8859-1)" option.
Jun 19, 2016 | Cell Phones
Tip
Updated! Convergence Problems & Solutions - With example photos
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
SOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
SOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
on Aug 31, 2009 | Philips 46PP9302 46" Rear Projection...
Want to change font size on Iphone
To make your text larger, go to settings, accssibility, then large text, it will give you different font sizes to chose from.
Apr 15, 2013 | Apple iPhone 5
Need game instructions for "Who's
I believe you can download the directions for the game here
www.ciudadaventura.net/teachers/docs/guide_unit2.doc
@font-face { font-family: "Times New Roman"; }@font-face { font-family: "Courier New"; }@font-face { font-family: "Wingdings"; }@font-face { font-family: "Calibri"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0in 0in 10pt; line-height: 115%; font-size: 11pt; font-family: Calibri; }table.MsoNormalTable { font-size: 10pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; }ol { margin-bottom: 0in; }ul { margin-bottom: 0in;
Aug 18, 2011 | Toys
My font is Times New Roman 12 point. How do I change that to Times New Roman 14 point and not have to make the change every time I work on a new document?
Sounds like you are working with Word 2007 right? Here are the instructions for making the font what you want automatically when it starts up. From the Microsoft webpage: Set the default font
  1. If your document already contains text that is formatted with the properties that you want to use, select that text.
If you are starting from a blank document, go to step 2.
  1. On the Home tab, click the Font Dialog Box Launcher, and then click theFont tab.
  1. Select the options that you want to apply to the default font, such as font style and font size. If you selected text in step 1, the properties of the selected text are set in the dialog box.
  2. Click Default, and then click Yes.
May 18, 2011 | Microsoft Office Word 2007 Full Version...
What is code 28
BODY { FONT-FAMILY:Tahoma; FONT-SIZE:10pt }P { FONT-FAMILY:Tahoma; FONT-SIZE:10pt }DIV { FONT-FAMILY:Tahoma; FONT-SIZE:10pt }TD { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } I bet people who use Sony and Cannon camcorders may feel frustrated trying to enjoy their videos on iPod, iPhone or iPad, as these videos are taken and saved in the form of mts/m2ts and they cannot play on these players. It used to be my trouble, too, but then I found I needed to convert mts to mp4. I found some powerful mts to mp4 converter so I'd love to share it with all you guys.How to convert mts to mp4?
Download and install mts to mp4 converter on your PC. It takes only a few steps to convert m2ts to mp4 on Windows.
Step 1: Connect your HD video camera/camcorders to your PC. Copy the source videos to your PC's hard-drive before converting or editing them.
Step 2: Launch the m2ts/mts to mp4 converter. Click "Add files" to browse your computer hard disc and add the .mts or .m2ts files you want to convert. You can load all the source files before the mts to mp4 conversion as batch converting is supported by this m2ts mp4 converter.
Step 3: Now you select mp4 as the output format and specify a directory for the output files. This mts/m2ts to mp4 converter supports comprehensive video formats including avi, mpeg, wmv, mp4, mov, xvid, 3gp, flv and more.
Step 4 (optional): The mts to mp4 converter can set the brightness, the contrast and the saturation of your videos, crop, trim videos and even merge multiple files into one single file before the conversion.
Step 5: Click the "Start "button to start the mts to mp4 conversion and all you have to do is to wait until the m2ts mp4 conversion is done.
Related article: How to convert m2ts to mp4 and How to m2ts/mts to mp4
Oct 04, 2010 | Microsoft Windows XP Professional
How to import fonts to photoshop?
  1. Regardless of the source, download the font and save it in a fonts folder on your hard drive.
  2. Step 2 Double-click the fonts folder and choose "File." You should be able to select "Install New Font" at this point.
  3. Step 3 Find the fonts you want to install. They may be on a CD or in a folder on your hard drive. When you download fonts from an online site, save them in a place that is easy to access when you install them in Windows.
  4. Step 4 Highlight the TrueType or OpenType font you wish to install and click "Ok." This will complete the installation. Programs, such as Photoshop will automatically incorporate the new font in the list provided by the program.
  5. Step 5 Go to the start menu and select "Settings." Open your control panel. In Windows XP, the control panel will be in the start menu. There is no need to look for "Settings" first.
Hope this is what you need
Mel
Jun 08, 2010 | Adobe Photoshop CS5 Upsell from Photoshop...
I am trying to change my default in word 2007 to times roman whenever I open a new document but cannot locate normal.dotm document to do this. Can you help.
Note the small arrow in the red circle in the following instructions - that is where you need to click!
  1. On the Home tab, click the Font Dialog Box Launcher, and then click the Font tab.
    default.aspx?assetid=za101762921033
  2. Select the options that you want to apply to the default font, such as font style and font size. If you selected text in step 1, the properties of the selected text are set in the dialog box.
  3. Click Default, and then click Yes.
Mar 16, 2010 | Microsoft Office Professional 2007 Full...
Unable to load post script fonts in windows-xp
Well postscript fonts are vector outline fonts, so they contain instructions about the building of their outlines and curves and such. Hence two files are required to use a postscript font under Windows.
As to how to install these fonts, well
  1. Click Start | Settings | Control Panel.
  2. Double-click on the Fonts folder.
  3. Choose File | Install New Font.
  4. In the Folders menu, navigate to the folder containing the fonts that you wish to install. A list of available fonts will appear in the List of Fonts window.
  5. Click on the font you wish to install or use the "Select All" button to install all fonts in the List of Fonts.
  6. Click on OK.
Please keep in mind:
  1. If you are installing fonts from a CD be sure the 'Add without copying files' box is NOT checked; unless the fonts are on a located somewhere (such as a network) which you will have access to at all times.
  2. Postscript fonts have two files: PFB (printer font binary has outlines that control how the font looks) and PFM (printer font metrics has information about font spacing). Be sure you have both font files.
  3. If you currently have or previously had Adobe Type Manager Deluxe 4.0, 4.1, or 4.1.1 installed you may need the Adobe Deluxe Updater in order to properly use your Postscript fonts under Windows XP. Get it from Adobe.
Hope this helped. Let me know and if yes please rate me:)
Feb 15, 2009 | Adobe Computers & Internet
Computers & Internet Logo
Top The Computers & Internet Experts
d3yavu3
kimblebear
Level 1 Expert
baklogic
Level 1 Expert
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
