Question about HP Photosmart C4180 All-In-One InkJet Printer
Printer noise makes noise when scanning, rubbing on track. all else works.
  • 684 Answers
Please Call HP on 800-289-6947 to get the printer replaced if it is under warranty.
Posted on Jul 24, 2009
Bear tracker squealing noise when trying to start after running it goes away help please it sat for a year before got rear end fixed
Joe, do you mean a bearing track?
If so, a bearing -or track - usually makes a grinding or knocking noise, not a squealing noise.
If a car stands for a long time the brake rotors can corrode a bit and the pads can stick. Sometimes, when the car is first used after standing, you may hear a rubbing or squealing noise from the wheel. That's the pads sticking to a rusty rotor. The noise may wear off after a few miles when the pads 'polish' the corrosion off the rotor.
The other thing that causes squealing from a wheel are the brake shims. Try cleaning things first.
Mar 14, 2016 | Cars & Trucks
The scan head moves when I start the printer, but then stops after making a loud noise, and the window reads, Printer error.
If visible check the print head track for some kind of blockage. Please include your model # and brand name next time.
Mar 18, 2015 | Office Equipment & Supplies
Check print path error after belt replacement (HP 1055)
Did u observed the belt having 50% vertical tracks & 50% horizontal tracks?. The vertical tracks as well as horizontal proper position?.. understand the snap., re install the belt once again as shown in fig... i hope UR problem will be resoled..
Apr 15, 2014 | HP DesignJet 1050c plus InkJet Printer
My Dell AIO 924 printer will not feed paper.
1.Check inside the printer to see if you have the ink properly installed.
2.Make sure you don't you re-use papers that you have already used.
3.All papers have to be perfectly allined.
4.Check the connection wires between the computer and the printer.
5.Scan your computer with a security system to catch and eliminate viruses,tracking cookies etc.
If all else fails I don't know what to say
Jun 24, 2012 | Dell 924 All-in-One InkJet Printer
Brother MFC 9440CN - I am getting "Document Jam"
Take the cover off of the ADF, rub clean the rollers with a damp cloth. Make sure there is no paper stuck in the area Also, check that the sensor flags are activating. just move them back and they should bounce back to normal position. Cleaning should do the trick.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Jan 21, 2011 | Brother MFC-9440CN Laser Printer
ADF Jam
It sounds like the grabbing wheels in the document feeder are losing their grip. You can take alcohol to rub down and clean the rubber tires in the document feeder. There is a possibility that a very small piece of paper is jammed in the feeder as well, which can cause the paper to jam and make a weird noise. Please let me know if this resolves your issue. Thank you.
Mar 27, 2009 | Dell Photo 964 All-In-One InkJet Printer
Blocks of noise
Don't know about the slow motion, but the noise is usually from dirty heads. Just like a cassette player it needs them cleaned periodically. Dip a Q-tip in rubbing alcohol and rub over the entire path the tape takes. You'll see a little block that actually reads the tape. Thats what you need to clean.
Make sure you eject the tape and remove the battery while the tape drive is open to clean it. Rubbing alcohol dries fast but give it an extra ten minutes and check it again.
Video recorder while the heads were dirty will not change however new video should be clean.
You may also have a bent tape carrier that is putting your video off track. It needs to be pushed or pulled to realign it.
It it's not the cause though, this can make playing back the earlier tapes more difficult since they will read and record in a slightly different part of the tape.
Jul 10, 2008 | JVC Cybercam GR-D72 Mini DV Digital...
Oil for scanning lamp track
I had the same problem with my Epson v200 scanner. I took it apart and rubbed - sparingly! - a little white grease in its track. It works fine now, but I have not used it much since I greased it. A tube of white grease should be about $3 in an auto parts store.
Jun 21, 2008 | Office Equipment & Supplies
HP Photosmart C4180 All-In-One InkJet Printer Logo
66 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
