Question about Light Garden
Where is the PCV valve located at on a 2005 Mariner 4 cylinder. My check engine light came on and it said to replace PCV hose. I would like to know the location of both
The fat hose go from carburetor to air filter and a hard skinny line going to the block from the fat Airline.
    Top Expert:
  • Light Master
  • 78,936 Answers
There is no carburetor on this vehicle.
Posted on Apr 21, 2017
Location of pcv valve 95 nissan KA 24 engine hardbody
Follow the breather hose(s) to where they meet the engine and that is where the pcv valve is usually to be found if your engine has one; valve cover, crankcase or inlet manifold are the likely locations.
Not all engines use a pcv valve. Many engines just have a tiny hole into the inlet manifold which typically soon blocks and needs cleaning.
Ford was one of the manufacturers who in the early days of a pcv system being required, used an oil filler cap to attach the breather system to and the tiny hole was inside the cap along with the flame trap and oil mist filter.
That like many of the plastic pcv valves was intended to be a throw-away item.
I hope I have helped you a little.
Feb 05, 2015 | Cars & Trucks
Excessive pressure in the crankcase of a mazda 2005 6
Have you checked the hose from the valve cover to the air cleaner ?
The PCV valve pulls air from the crankcase into the intake, but the crankcase has to get fresh air from the air cleaner too.
If the crankcase is getting extra pressure from the cylinders you should have a check engine light and trouble codes.
Jan 15, 2013 | 2005 Mazda 6
Check engine light on OBD 2 reads PO 2189, want to know how to repair l
This error indicates too lean a fuel mixture is being delivered to Bank2 (bank of cylinders closest to the front of the car.
This could be caused by a defective IAC valve ( Idle Air Control) but more likely is bad vacuum hose or PCV valve
Check and double check then redouble check all hoses for cracks or leaks. Replace the PCV valve ( about $10)
Feb 04, 2011 | 2006 Mazda 6
Where is the pcv valve located on a 2005 dodge ram 1500, 4.7 ltr eng
looking at the engine from front it should be in the right valve cover. a hose comes from the pcv valve to throttle body.to replace it, just pull up on valve to release from rubber grommet. have a good day !!
Jan 08, 2011 | 2005 Dodge Ram 1500
Were is pcv valve located on 1989 honda accord lx 4 cylinder
You PCV will be located on the center, rear engine area. It is just below the intake manifold, between the block and intake manifold. The valve is housed in the vacuum hose that runs halfway into the engine.
Jan 02, 2010 | 1989 Honda Accord 4 Door
Need to know where the crankshaftpositionsensor is located on a 2005 stratus 2.4lt engine
I am assuming your Stratus is a Sedan with the DOHC 4-cylinder engine. If so this might help. Do you know where your PCV valve is? (The PCV valve is on the driver-side of the engine up close to the top. It is a little black plastic cylinder with a vacuum tube coming out that goes up to the air intake fairing up near the fan.) The CSPS is right below the PCV valve. It has an electrical connecter with a little red release clip where the wires plug in. The sensor is about 3-4 inches wide and shaped like a rounded diamond with a raised circle in the middle. It is held on by 2 small bolts. I hope this helps.
Apr 18, 2009 | 2005 Dodge Stratus
Where can I find the pcv valve location
please rate as fixed if this helps.
4 cylinder
SECTION 303-08: Engine Emission Control 2003 Escape Workshop Manual
REMOVAL AND INSTALLATION Positive Crankcase Ventilation (PCV) Valve —2.0L Zetec Removal and Installation
  1. Remove the PCV valve.
    • Remove the crankcase ventilation hose from the PCV valve.
    • Remove the PCV valve from the grommet by turning the valve counter-clockwise
Apr 12, 2009 | 2005 Ford Escape
PCV Valve
It is bolted into the rear valve cover near the passenger side.
Mar 18, 2009 | 2005 Dodge Caravan
Where is the pcv valve located on a 2003 ford ranger
  • The PCV valve can be located in several places. The most common location is in a rubber grommet in the valve cover. It can be installed in the middle of the hose connections, as well as installed directly in the intake manifold.
  • Once the PCV valve is located, make sure all the PCV system hoses are properly connected and that they have no breaks or cracks.
  • Remove the air cleaner and inspect the air and crankcase filters. Crankcase blowby can clog these with oil. Clean or replace such filters.
  • Oil in the air cleaner assembly indicates that the PCV valve or hoses are plugged.
  • Make sure you check these and replace the valve and clean the hoses and air cleaner assembly.
  • When the PCV valve and hose are in satisfactory condition and there is oil in the air cleaner assembly, perform a cylinder compression test to check for worn cylinders and piston rings.
  • Feb 27, 2009 | 2003 Ford Ranger Regular Cab
    Garden Logo
    Top Light Garden Experts
    Dennis Key
    Dennis Key
    Are you a Light Garden Expert? Answer questions, earn points and help others
