110.28102310 Kenmore washer diagnostic manual or help to do self diagnostic
    Top Expert:
  • Washing Mach... Master
  • 77,499 Answers
Kenmore washer model 11044722401 how to manually advance the cycles? Sears technician showed me how a few years ago-- so I know it can be done. It is a technician diagnostic test/ function.
With the washer off, unplug it and plug it back in the lights should blink twice. Then press the wash temp and water level keypads at the same time. The water level should stay on but all others should stay off. If this happens the washer is in diagnostic test mode. Hope this helps
Nov 04, 2016 | Kenmore Washing Machines
I replaced the board in a Kenmore elite oasis washer and still get the f54 and f68 code. What's next
Hi Tony. Can you provide the model number of your Kenmore? It should be 110.27xxxxxx. We;ll see if we can figure this out. First, check to see if the inner tub spins freely by hand - we want to ensure that nothing is binding it up (like a nylon stocking). Also, after you changed to board, did you press Pause/Cancel to clear all lights? Have you run a self-diagnostic test?
Sep 24, 2014 | Kenmore Washing Machines
Diagnostics ok but only spins slow
Water pump screen is plugged. Will not drain properly even though it goes into high spin.
Mar 14, 2014 | Kenmore HE3T Washer
I have a kenmore oasis 110.27032603 washer that has displayed an f 50 error code. am trying to find out how to get into the diagnostics on the machine so I can begin troubleshooting. any help greatly...
This may help:
Following is the Whirlpool Service Manual for their Cabrio washer which is basically the same as the kenmore Oasis.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
I'd also see the following Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Sep 26, 2010 | Kenmore Washing Machines
What does it mean when is says f29 error
If you unscrew a couple nuts at the bottom front panel of washer, you can remove the bottom front panel. Taped on the inside of that panel is a book with an explanation to all your codes and how to put washer into self diagnostic test. Good luck hope it helps.
Jul 19, 2009 | Kenmore HE2 Plus Front Load Washer
Water problem
Apr 01, 2009 | Washing Machines
Kenmore Elite H3 control buttons - some work some don't
The diagnostic function will not help you if your user interface board (UIB) is acting up because to put into diagnostic you have to select drain spin, then the no spin option, and hit the prewash button 4 times.
It sounds like your UIB is the problem.
Jan 01, 2009 | Kenmore 42822 Front Load Washer
On-line User Manual "Kenmore 3.8 cu. ft. HE3t Washer
I have the Service Technician Diagnostic Guide...it was located behind the lower front panel on the right hand side. It's not really a user manual, but wasn't sure what info you needed that you hoped might be in the user manual, as opposed to a Diagnostic Guide.
Nov 18, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
167 people viewed this question
Top Washing Machines Experts
