Question about Tablets & eReaders
How to unlock bootloader on a Nexus 7 6.0.1 without a PC
How do I root my Nexus 7 with secure bootloader and without a PC, also how can I find if the tablet is 2012 or 2013 version as it does not say in "about tablet" Sorry to ask these questions but I have scoured the internet for answers and found nothing that I think is a solid method as I do not want to brick my nexus7... And yes I am a complete newb
vortash
  • 431 Answers
SOURCE: when i turn on my pc it ask for a password i never created, how do i fix this problem
Hello again sounds like it has lost its bios configuration and wants the CMOS re-setting check the hard drive hasn't come loose or your CD if it is an interchangeable one .. and if the floppy drive was in the machine ( not a disk an actual changeable drive ) .was in the last time you shut it down put it back in and reboot see if it's ok unlikely but worth a try
So if no joy you will need to remove the CMOS battery probably located under the keyboard .. or sometimes behind the ram module underneath and a few machines have their own battery holder under the machine .. its silver looks like a large watch battery and is in a plastic holder .. don't touch it with your hands they are static sensitive as are the other components around it .. wear a pair of marigolds the rubber will help protect the circuit ... hope this is a success for you good luck .. Regards Vortash
Posted on May 19, 2009
TechyDrood
  • 2072 Answers
SOURCE: i want to root my tablet but it wont root bc on the boot screen it says locked how can i unlock it so i can root it
Go visist XDA's forum and look up the rooting guide for your device. HTC is one of the better manufactures that actually allows for easy rooting.
Posted on Dec 13, 2012
maxcarson
  • 7627 Answers
SOURCE: help me please i formatted a archos 101 internet tablet and i guess i supose to do somthing to exit it but nothing works can you help please say yes that you have an answer
If you post to "Tablets and eReaders" a Tablet Expert can help you.
Posted on Mar 31, 2013
daimljz
  • 53 Answers
SOURCE: Convert my videos from itunes to mp4 for watching on Google nexus 7?
You can use two ways to do it.
One way is to sync itunes movies to your Nexus 7, the other way is to convert itunes to Nexus 7.
Posted on May 10, 2013
  • 130 Answers
SOURCE: unlock tablets
did you modify the 'follow this tablet setting' You
may want to turn that off
Posted on May 31, 2014
How to root or install custom Recovery on visual land prestige prime 10se or maybe unlock bootloader.
Try root it using a universal one touch root application (PC NEEDED) such as www.kingoroot.com or kingroot.com
Just look at compatible phone lists they have.
Nov 05, 2016 | Tablets & eReaders
How to Root the Nexus 7?
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.cnet.com/how-to/how-to-root-your-google-nexus-7/&ved=0ahUKEwj6ipCW-OLPAhVFyWMKHW26A6gQFggeMAE&usg=AFQjCNH-Ok5I2GrZK_0rnfG42zqyN7oUoA
Oct 17, 2016 | Android Tablets & eReaders
How to remove a password from google nexus 7
I believe the only way to reset your password would be a hard reset. This will also remove all of data and return the device back to the original factory settings.
Reset your Nexus device to factory settings
Apr 22, 2014 | Google Nexus 7
Forget pattern unlock code , need help unlocking .
you shoud to reset it.
Hold power button and + or - button together.
Apr 14, 2014 | ASUS Google Nexus 7 8GB Tablet Unlocked...
Get message to restart bootloader
Select start by using the volume buttons and hit it with the power button.
To prevent this, don't hold down the volume buttons while powering on your tablet.
Apr 03, 2014 | ASUS 32GB Google Nexus 7" Tablet with...
My nexus 7 wont go past multicoloured x.. cant switch on/off. tried hard reset and nothing works
Important:Plug your device into power outlet
Step 1: Power off Nexus 7
Step 2: Power on while holding Volume Down/Up
(enter BootLoader)
Step 3: Press Volume Up to toggle to "Recovery Mode"then press power to select
Step 4: Hold The Power Button and tap Volume Up when you see "No Command"
Step 5: Press & hold Power Button & Volume Up Button Again
Step 6: Toggle with vol down and vol up / power at wipe data (all data) & reboot
Nov 20, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
My nexus 7 tablet wont leave the startup screen. I tried a hard reboot but it stays on that screen and wont turn off
(enter BootLoader)
Step 6: Toggle with vol down CLEAR CACHE & reboot
Nov 03, 2013 | Google Nexus 7
Wont turn on
If you can get into the bootloader try doing a factory reset, if you are rooted press and hold the power and vol down button and that would boot into recovery. Worse case, you can google factory images for nexus 7 e and download a factory image from google and they provide the instructions on how to reimage your devices
Apr 17, 2013 | Google Nexus 7
Can I use a 4G plug in connect USB with my Nexus 7?
(Using a WIFI Hotspot is definitely recommended. Connecting your 4G USB dongle to the Nexus 7 will drain the battery quickly since the USB is using the Nexus's battery to power on. This is what I use) but here's how to get your 4g usb dongle to work
Your device must be rooted, and you would need a USB OTG cable/adapter. Here's an example of an OTG USB cable -6c4749a3-0b72-4ebc-8cb6-60f7bfb77d23.jpgThis app should work on any nexus 7 and it is very simple just install the app and enter your apn of your operator connect your dongles via otg cable and it will work the app available on google play store called ppp widget here is the link it is for rooted device
PPP Widget
Mar 13, 2013 | Google Nexus 7
Can't start my nexus 7 tablet
my nexus 7 will not unlock on switch-on it is still under guarantee
Sep 08, 2012 | ASUS Google Nexus 7 8GB Tablet Unlocked...
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
