Question about Garden
Throttle linkage diagram for pacific hydrostar pressure washer 4 hp
    Top Expert:
  • Garden Master
  • 44,100 Answers
For a throttle linkage diagram, contact Pacific Hydrostar directly.
Posted on Apr 22, 2017
How much oil does a pacific hydrostar in the pump their is no site glass pump 95618
There is no oil in this pump. When storing it long term , put some automotive antifreeze in it. Disconnect the water hose and tip the unit on its face to drain water out of the inlet fitting for short term non freezing times.
Aug 22, 2016 | Garden
I need to change the pump on my pacific hydrostar 2800
That cannot be done over the internet, no matter what ISP you have.
Further, you need to be more-specific about exactly what you have.
Pacific Hydrostar makes both sump pumps and pressure washers with 2800 ratings (gallons per hour and PSI, respectively). So you should use the model number of your device, not what the large print on its decals say, when requesting help with them.
Apr 03, 2015 | Computers & Internet
I just purchased a 98444 Pacific Hydrostar Power Washer. I was checking out the oil level in the pump and it appears to be bone dry. The manual calls for 75w/90 non- detergent oil but does not tell me the...
The oil cap should have a dip stick if not it should take maube a quart but add a little at a time untill u see some oil. But do not fill it all the way to the top
Sep 21, 2013 | Garden
Pacific hydrostar 68333 1500psi pressure washer...motor keeps cutting out, but reset breaker does NOT trip.
dont know the model or if it has a pressure switch inside the box but try and remove your lance and just operate the gun... if it runs ok your last could be blocked
Aug 21, 2013 | Pacific Hydrostar Pacifichydrostar...
Pacific hydrostar 2800 pressure washer
did it overheat if so replace the pump it will overheat again only two things the packing can be worn overpressuriztion in pump head by a faulty unloader is another this symptom has many variables even a cracked plunger can cause this i can and will help you give me more info like is the oil milky in color or is sight glass melted etccc.will be glad to help 30 years plus exp..
Jul 31, 2013 | Garden
Pacific Hydrostar pump 2" 6.5 HP Item # 95977. I
Do you know where get a owner/repair manual for a Pacific Hydrostar portable water pump #95977?
Jul 09, 2011 | Plumbing
Pacific Hydrostar 95618. pump oil?
Pacific Hydrostar is another pacific rim product that has no website, and no manuals online, and nobody to contact, and no parts available. These machines must be made for the throw-away user.
Pump oil comes about half way up inside pump housing > pump oil is 20 or 30 weight non-detergent oil SAE20 SAE 30
Engine oil comes half way up dip stick > engine oil 10W30
Do not turn power washer on its side or upside down when draining oil, or engine oil will go into carburetor and machine will not start
Oct 13, 2010 | Garden
Help! i have a pacific hydrostar 65078. Engine runs fine. Pump pressure is good with the hose off. the stream shoots across my driveway. But when i connect the hose(sears 3/8 25'' i loose all pressure.
You have to have a clogged hose gun. Try blowing it out with air. Also, Harbor Freight sells the Pacific-Hydrostar and you can buy a 2 year full warranty for around $70 bucks. A small price to pay if you use your powerwasher on a frequent basis. If anything goes wrong, regardless of what the cause, they simply replace the washer.Hope this helps.
Nov 20, 2009 | Garden
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
