Question about Bose Audio Players & Recorders
My Bose color soundlink speaker got water damage how do I fix it ?? If it's been a month since this happen will rice still be an option?
  • Bose Master
  • 17,099 Answers
Rice is not ever a good option. Given the amount of time that has passed, the water is gone and corrosion has set in. When something battery or electrical gets wet, you need to remove the power immediately. Then work on drying it out.
Posted on Apr 21, 2017
  • 59 Answers
SOURCE: The rice dries out in the "keep warm" mode
You have a strange problem. I use my rice cooker often and the only thing that I can think of that may be casing your problem is if the steam vent is clogged. A clogged vent would cause the steam to condense and run to the bottom.
With the machine empty of food, you could try pouring hot water through the vent to see if this clears any clogs. If it does not, it could be other problems that I can tell you will cost more money to fix than to replace with a new Rice cooker.
Good Luck.
Posted on Apr 25, 2010
drifterK
  • 4924 Answers
SOURCE: my bose soundlink speaker is
The issue is that the Bose only one blue-tooth frequency ..and if you use it with your airport express it can not work with he speakers too ...Use either one of them at once ..probably the issue is it skips out of pairing with the speakers when you connect the airport ...so ..you will have to use cable for one of them ..
To pair the speakers again use the button for pairing ..Play the home theater..and press that pairing button ..and it will find the frequency ..
The idea is that you can not use them both ..It is possible though to have them already paired ..and be able to switch between them ...The frequency is the same all the time ..and once found in the bose theater..just reconnect each time ...same in the airport express..Just press the button on the speakers to allow to be found..and search from the unit..
Posted on Aug 01, 2011
SD Tech
  • 14553 Answers
SOURCE: my bose soundlink air does not respond to all commands on remote
Have that remote tested---I have and most shops have a tester---point remote at the tester and press any or all buttons and the tester reacts or not. Most common cause if only certain buttons do not work is liquid got inside.
Many digital cameras are able in a extremely dark room to respond in the same way when the remote is pointed at them and buttons pressed with a faint flash on the camera display screen---a go or no go test for every button.
Posted on Dec 04, 2012
Testimonial: "thanks this is a good bit of info ,but the soundlink is new never been used so went back to dealers and it turned out to be an option to open in properties on my pc. BUT THANKS AGAIN FOR YOUR HELP"
  • 15 Answers
SOURCE: Problem getting my bose soundlink to play blue tooth audio from my laptop.
Hi Sirtuan.
Go to the system panel, there choose "sound" . a list with all available sound devices appear. search for your bose soundlink and make it your "standard device".
had the same prob. with my BT headset and this works for me.
if your bose get disconnected the sound should automatically switch to pc speakers.
Regards
Gue.
Posted on Apr 06, 2013
android48201
  • 47 Answers
SOURCE: How to get Bose soundlink mini out of battery protect mode
Call Bose have excellent customer service
Posted on Feb 03, 2015
How do I know if my bose mini soundlink bluetooth speaker needs a battery?
[PDF]Owner's guide - Bose
worldwide.bose.com/.../soundlink_mini/.../owg_en_sou...
Bose CorporationMini Bluetooth® Speaker. Owner's ... to charge and discharge the battery pack several times to obtain ..... the Bose® SoundLink® Mini speaker battery lasts up.
Sep 25, 2015 | Bose® CORPORATION Bose - SoundLink Mini...
I dropped the speaker in water yesterday. I turned it off & attemped to dry out now it won't charge.
You toasted your battery. Unfortunately, you are more than likely out of luck as water damage is not covered under the Bose warranty.
The next time, hopefully never again, you drop an electronic device in the water, DO NOT TURN IT ON! Remove the battery and let dry for 48 hours, with all possible covers removed.
Apr 19, 2015 | Bose Corp Bose SoundLink Mini
Bose Soundlink Mini paired to Win 7 PC but will not play audio
For pairing your bluetooth Bose speaker to your computer you might need to update the Bose speaker software
I have included the link to download the actual software, and the updates available. According to the page for the download, you will need to have the speaker connected to the computer with a micro USB cord.
SoundLink Wireless Mobile speaker update
Aug 24, 2014 | Bose Corp Bose SoundLink Mini
Bose soundlink mini paired to PC ( Win7) but wont play audio
I have included the link to download the actual software, and the updates available. According to the page for the download, you will need to have the speaker connected to the computer with a micro USB cord. SoundLink Wireless Mobile speaker update
How stop the Bluetooth indicator always flashing on my Soundlink Mini?
Blinking blue light - Discoverable and ready to pair or reconnect with a device. See manual here: Bose SoundLink Mini Bluetooth Speaker Owner guide
Jun 16, 2014 | Bose Corp Bose SoundLink Mini
Blue tooth speaker wont turn back on.
Unable to connect to a device?
Before attempting any of the following steps, make sure that you are running the latest software version on your SoundLink Wireless Mobile speaker. Click here to visit the software update center and update your speaker. If you are still having difficulty connecting to a device after updating the software, continue to the troubleshooting steps.
Unable to connect with a previously paired device?
Please try the following to resolve this issue:
Perform a product resetTo perform a SoundLink speaker reset, following these steps:
  1. On the speaker, press and hold Mute for 10 seconds, the LEDs will flash briefly
  2. Press Power to turn the SoundLink speaker back on
Clear the pairing list on both the SoundLink Wireless Mobile speaker and the source
  1. On the SoundLink speaker, press and hold the Bluetooth button for approximately 10 seconds until you hear a tone. The SoundLink speaker clears all Bluetooth devices from its memory and becomes discoverable
  2. Clear the list on your Bluetooth device. For more information, please refer to the manufacturer of the device
  3. Perform a product reset. On the speaker, press and hold Mute for 10 seconds, the LEDs will flash briefly. Press Power to turn the SoundLink speaker back on
  4. Try pairing the device again by following these steps:
    1. With the Bluetooth device and the SoundLink speaker both turned on, press and hold the Bluetooth button on the speaker for three seconds to make the speaker discoverable. The Bluetooth indicator will slowly fade on and off approximately once every second to show the speaker is in discoverable mode
    2. Set your Bluetooth device to "Discoverable." This will allow your device to discover the SoundLink speaker
    3. On your device, locate the Bluetooth device list. Select "Bose SoundLink" from the list
    4. If your device asks for a passkey, enter digits 0000 and press OK. Some devices also ask you to accept the connection. Your Bluetooth device indicates when pairing is complete. The SoundLink speaker indicates pairing is complete when the Bluetooth indicator stops fading on and off and remains on
Be sure the SoundLink speaker is within 30 feet of the Bluetooth deviceThe system is designed to operate at a range of 30 feet. However, performance can be diminished by obstacles such as walls or metal, and may also be affected by other Bluetooth devices. Try moving the SoundLink speaker closer to the Bluetooth device.
Be sure the source's Bluetooth function is OnMany Bluetooth enabled devices have an option where the Bluetooth feature can be turned On or Off. This option may be set to Off to save the battery life of the device. Be sure this option is set to On. If the Bose product is paired to the Bluetooth enabled device, it should automatically reconnect when its Bluetooth function is turned on. If the Bose product doesn't automatically reconnect, manually select the Bose product within the Bluetooth list on the device.
Manually connect the SoundLink speaker in the device listSome devices will pair to a device but not automatically connect. Go to the pairing list of the device and check if this is the case. If it is, try connecting to the SoundLink speaker.
Oct 20, 2013 | Just Wireless Bluetooth Headset Wireless...
Hi Sirtuan.
Regards
Gue.
Apr 06, 2013 | Bose SoundLink Wireless Music System...
Cant connect Macbook to Bose Soundlink Wireless Music System
What I did to connect to BOSE wireless speaker to my MacBook air was go in advance settings and uncheck all three options there and then press the wireless button until it beeped--> then I was able to pair it to my laptop. Success!
Jan 02, 2012 | Bose SoundLink Wireless Music System...
439 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
