Question about Hardware & Accessories
Timer / clock stopped working. Would turning power of and or resetting restart it or is it likely to need replacing
SOURCE: FAULTY TIMER/CLOCK
I found mine did the same I pusshed the face and it came back on. It appears fault within circuitry of clock and will need to be replaced
Posted on Sep 14, 2007
  • 492 Answers
SOURCE: My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Posted on Apr 30, 2009
SOURCE: Thermador CMT21 clock and timer don't work
If you have the old analog clock, there is a new digital replacement kit that makes this oven look modern and give it more life
Posted on May 12, 2009
SOURCE: reset timer between batches of cookies
click the Hr/+ and the Min/- keys at the same time...the timer will reset.
Posted on Aug 05, 2009
Testimonial: "IMLOUISE YOU ARE A GENIUS!!! HOW DID YOU FIGURE THIS OUT? MY MISTAKE WAS THROWING AWAY THE INSTRUCTIONS. I THOUGHT IT WOULD BE EASIER TO DO. "
gotgeek2
  • 565 Answers
SOURCE: intermatic timer for my pool pump - clock is not running
Usually the timer motor is bad when that happens. Replacement timer motors are available from websites like this one:
http://www.aplussupply.com/intermatic/timermotors.htm
Be sure to get the right voltage timer motor. Intermatic T101's and T103's use a 120 volt timer motor (Cat# WG1570) and the T104 uses a 240 volt timer motor (Cat# WG1573).
If you don't want to mess around replacing the timer motor, you can purchase a new timer, and as long as the existing enclosure is in good shape, just swap out the guts.
Posted on May 14, 2010
On/off tripper problem with T 103 timer
if it won't trip it, the on pin is not lining up right and u need to take it off and put it making sure it is right. if that's not it u got a bad timer
Mar 26, 2012 | Intermatic Hardware & Accessories
So my intermetic time is broken, the gears dont turn, and the on/ off override isnt working. I need my pool heater, what do i do?
Sounds like you lost power to the timer. Look in your electric panel for a tripped breaker. Turn it OFF then back ON.
Aug 20, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
I have a intermac ML200Rt and after a power outage the clock motor does not turn anymore. It can be manualy turned to black and red trippers to turn lights on and off. The manual overide switch works also....
If clock motor stopped working, then there are no replacement clock motors/modules for power packs.
Buy cheap plug-in timer, set power pack to override, plug power pack into cheap timer.
If you have sales receipt, Intermatic/Malibu ML series power packs have 5 year limited warranty.
Open following links for troubleshoot steps, warranty links, trippers, and tips for getting next power pack to last longer.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 28, 2011 | Malibu ML200RT - Low Voltage Power Pack...
Had to replace a fixture today. when I replugged the lights the lights turn on manually but the clock on the timer does not advance I have 56 watts of light Is the timer broken?
If clock motor does not rotate, then some people report taking it apart and cleaning gears.
The PB912M10 timer clock motor is not sold separately. Aug 2010.
If power pack transformer still works: buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
With receipt, power pack might still be under warranty.
Open following link for power pack tips and resources:
Nov 29, 2010 | Intermatic Malibu 121W Power Pack...
Power is good going into the timer but the timer is not running. I am wondering if there is a fuse that needs to be changed or a reset switch? The timer has been replaced in the last year.
If I understand correctly, you have T-104 240V timer.
Timer was running fine before, and recently stopped working.
If this is not your timer, add a comment.
1) Click manual override back and forth to see if Load turns on-off.
If Load does not turn on-off, then check power at Load.
Timer has 5 terminals A 1 2 3 4
Check terminals 2 and 4 for 240Volts when Load is ON
2) Check terminals 1 and 3 for 240Volts to make sure timer has full 240V and breaker is not tripped OFF on one leg. If timer has 120V, it appears to have voltage, but clock will not rotate and Load will not turn on-off. Check breaker for 240V across both screws.
3) Is dial rotating?
If dial is not rotating or is stuck in place, replace 208-277V clock motor.
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK2?Pid=search
4) If dial is rotating, but trippers don't flip on-off lever, then trippers may be worn down. Buy new trippers.
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
5) How to wire T104 timer
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
How timer works
Clock motor rotates dial.
ON-OFF trippers on dial contact lever.
ON tripper pushes lever one direction.
OFF tripper pushes lever other direction.
Lever moves electrical contacts together, or pulls contacts apart.
When lever moves on-off, manual override lever also snaps back and forth with audible clicking sound.
Nov 24, 2010 | Intermatic T104 24h 208-277v Mechanical...
My timer is loosing approximately 3 hours a week.
If I understand correctly, you have a box-type timer.
The brand of the timer could be Intermatic timer or another brand.
The timer has a dial
The timer dial is not keeping up with current time.
The timer functions correctly otherwise and turns the Load on-and-off.
There are a few reasons that can cause this.
1) The clock motor is bad, and needs to be replaced.
-Answer back with the brand and model of timer and we can look up a source for your specific voltage clock.
2) The gears are rusty and dirty
-Turn off power and lift mechanism out to inspect condition.
-The timer is bad and needs to be replaced.
-With some timer models, you can buy new timer and swap insides without changing box.
-Answer back with brand and model if you need help locating replacement.
3) There is a power interruption, for example a loose wire or bad breaker.
-If the clock is off by 3 hours exactly each time, then power interruption is NOT the best suspect.
-If the clock is off 3 hours this week and 1 hour next week, then electric problem is a better suspect.
-If the timer clock does not have power, it stops running
-If there is a loose wire at the timer then clock may stop now and then
-If there is a loose wire at the breaker or a loose wire somewhere between breaker and timer, then clock could run slow.
-If breaker is loose on the busbar, then there would be a burned smell inside the breaker box
Please answer back as you narrow down the cause. We will be glad to help more.
Oct 24, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Clock does not work,manual operation turns light on
You posted under Intermatic-malibu power packs.
There are no replacement clock motors.
Improvise by setting timer to override and plug power pack into cheap plug-in timer.
For information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
Jul 11, 2010 | Malibu ML200RT - Low Voltage Power Pack...
How do i reset clock for the taylor clock timer 5851-21?
my Taylor 5851-21 has Hour Min Then under thatt Timer/Reset abd Start/Stop. How do I set the time. I know how to work the timer and reset the timer, but I need to set the clock. But it does not have a clock button label as you describe above.
Nov 20, 2009 | Taylor Hardware & Accessories
Jenn-Air JES9860 burners and oven stopped working problem with display
sounds like you lost power to your stove. if you can't reset the clock, it needs to be replaced. in otherwords, the power outtage shorted out the clock.
have a technician replace it.
Jan 14, 2008 | Jenn-Air JES9860 Electric Kitchen Range
FAULTY TIMER/CLOCK
Dec 14, 2006 | Smeg F170 Pyrolytic Stainless Steel...
Hardware & Accessories Logo
64 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
