Question about CDA Dishwashers
My CDA CW448 dishwasher has stopped working .... does anybody have any suggestion?
Hello My CDA CW448 has developed a fault. When a wash cycle is started, it drains any water away ok, then runs for a minute or two, then stops, I can hear a small clunk when it stops. If it's left in this state, you can hear it trying to heat up water, but it isn't pumping any water around. It will eventually fill up with steam, but it never gets going as such. I don't get any warning lights, just the normal lights. I've tried resetting it, but no difference. I've pulled the unit out, turned it onto it's back, and checked in the bottom sump pan, there's no water in there, and everything is super clean. The polystyrene float all seems fine. If I then put the unit upright, and back into place, switch it back on, it will then actually do a wash which took me by surprise ... but never stops! I then can't do another wash. Any help appreciated :o)
  • 1003 Answers
SOURCE: Kenmore 587 High Temp/Heat Dry lights flashing, cycle not complete
REPLACE TIMER
Posted on Jan 18, 2008
gwshaw71
  • 83 Answers
SOURCE: Drain pump runs continuously
Which model do you have and is there any fault codes showing on unit? I have all of the service manuels for miele products.I am factory auth. for service on miele.
Posted on Feb 24, 2008
Skill Will
  • 53 Answers
SOURCE: Dishwasher not pumping the water out?
hi
the larger motor housing underneath the unit is what moves the water around to wash, the smaller pump is the drain pump, if you don't hear that running it is likely in need of replacement. check your paper work for warranty, if it's out of warranty try to find a deal online and it's relatively easy to replace
Posted on Mar 21, 2008
lancaster5
  • 245 Answers
SOURCE: Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Posted on Aug 23, 2010
BElectric
  • 1140 Answers
SOURCE: Hello, my Bosch Classixx dishwasher SGS43E42EU/21
Hello Dave,
Sounds like an overfill problem - the symptoms are consistent with a failed pressure switch. Water enters the dishwasher through a chamber which has a float arm connected to a small microswitch -this is the pressure switch. The concept is similar to that of the float switch for the aqua-stop system.
As the water level in the dishwasher rises, the water level rises in this chamber. Once the dishwasher and the chamber are full, water pressure trips this switch, closing the water inlet valve and the wash cycle then starts.
If the pressure switch doesn't trip, the water level continues to rise and this trips the overfill float switch. This closes the water inlet valve and starts the drain pump. Once the water level has dropped the dishwasher attempts to fill again, but the pressure switch remains closed and the cycle repeats - ad infinitum.
To check the pressure switch you will need the remove the left side panel (when facing the door) and a multi-meter to test the switch with. If you have the necessary equipment and skills to attempt this repair yourself (seems like you do) please let me know and I will provide the relevant details.
Regards,
BElectric
Posted on Feb 23, 2011
My cda cw496 dishwasher beeps in the middle of the cycle and then water leaks from the bottom. any suggestions?
The problem could well the plumbing past the machine... Are any of your other drains in the kitchen slow? A little snaking of the drain lines may be in order.
Jan 02, 2015 | CDA Dishwashers
LG dishwasher error code after 2 minutes
fault with the programe as it has stoped in mid cycle
Aug 01, 2012 | Whirlpool Dishwashers
It starts the cycle then it drains down and the bleeping starts saying theres a fault.
MAY BE A LEAK AND ITS ACTIVATING FLOOD SWITCH WHICH WIL DRAIN MACHINE TO STOP FURTHER LEAKS CHECK SEALS AND MOTOR SEALS FOR LEAKS
Jun 17, 2012 | CDA WC430 Dishwasher
Cda 497/1 not washing
see this possible causes: Water-heating cycle the cicles compren washing, and rinse, the machine stop, because the heating element, and thermostat can be defective test.see the diagram Timer test the timer see the diagram for defective, clean contact, with special spray, tigh the wires very well. 5_9_2012_10_57_35_am.gif5_9_2012_10_57_57_am.gif
May 08, 2012 | Dishwashers
Cda 350 dishwasher
I have a cda cw195/1 integrated dishwasher, the red light stays on and when I attempt to start it the cycle begins then stops and it continually beeps, all the filters are clean and there are no blockages any ideas
Jan 14, 2012 | Dishwashers
CDA dishwasher (model number CW496) , stops working at the rinse cycle, and does not empty, filter is ok, tried re-setting the programme but unless there is no water being held the programme won`t work
my dishwasher starts off with good intentions then a couple of minutes later it starts beeping non stop.I open the door to find it has turned on to the rinse cycle and will not do its job.I continue to start it again and then it repeats the problem again.Can you help?
Sep 21, 2009 | Dishwashers
Zanussi DW907 Dishwasher stops early in cycle
the heater relay may have gone on the pcb or you may have a stat/wiring fault in the heater circuit.
Feb 15, 2008 | Dishwashers
Dishwashers Logo
37 people viewed this question
Top CDA Dishwashers Experts
David Payne
David Payne
john cordey
john cordey
Are you a CDA Dishwasher Expert? Answer questions, earn points and help others
