Question about Optics
I have a monark thunderbird serial number 3h08569 what year is it from?
What year is a evinrude outboard with serial number 1451821
The motor HP is critical in such searches. Here are all the resources you need to find the information yourself.
About this result
How To: Outboard Engine Serial Number Year Match, iboats.com How ...
www.iboats.com/basics/serial_number_year.html
  1. Cached
  2. Similar
For engines prior to 1969 refer the the Johnson 1960-1979 serial number year chart located here. If you have a commercial model refer to the Johnson commercial serial number year chart located here. Evinrude changed how they indicate year in the model number in 1980.Mercury Outboard · ‎Evinrude Outboards 1950-1979 · ‎Johnson Evinrude Commercial
[PDF]5006145_Model Number Reference.fm - Evinrude
shop.evinrude.com/media/document/ModelNumberReference.pdf
  1. Similar
MODEL NUMBER DESIGNATION - OUTBOARDS. Model Years 1980-1998. V E 70 T L ED A. MODEL VARIATION. A = Australia. B = Belgium. C = Canada.
Evinrude Outboard Motor Model Numbers & Codes - Marine Engine
www.marineengine.com/manuals/evinrude/
  1. Cached
  2. Similar
The nameplate should contain a model number and a serial number. The model number will identify the year and certain details of that motor. 1980-Present: Evinrude outboards from 1980 to the present use a model number that can help determine the year and features of the motor. See the model number code here.0.5HP · ‎0.9HP · ‎1HP · ‎1.1HP
Marine Motor Look-Up Guide - Auto Repair Manuals
www.autorepairmanuals.biz/page/599222
  1. Cached
  2. Similar
keywords: Find year, serial, number, model, number, #, outboard, motor, marine, motor, look-up, Johnson, Evinrude, Mariner, Mercury, Force, OMC, Yamaha, ...
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE ...
www.maxrules.com/models/OMC_models_files/EVthru79/ev_index_79.html
  1. Cached
  2. Similar
WHAT YEAR IS THAT OLD EVINRUDE? FIND OUT HERE ON OUR MODEL YEAR LOOKUP CHART! evinrude outboard with serial number Google Search
Nov 29, 2016 | Boating
The steel on the crank arm of my Monark 817e exercise bike broke, how do i remove it, it has no cover/nut/bolt/washer holding it to the axel
It's very difficult to find someone familiar with a particular model of a particular brand of exercise bike, but I pulled up some pics that seem to show that yours can have one of two types of crank. One is called a "one-piece" crank. Typically it is removed by unscrewing parts from the left side after removing the left pedal (left-hand/reverse threads). You may have to remove the housing to access and remove the parts. The other is a 3-piece cranks, and the arm will have a plastic cover at the axle. If you remove that dust cap you will see a bolt underneath. One has to remove that bolt and then use a specialized tool (crank extractor) to remove the crank arm. Check with a bike shop (take in the unit or take some good pics) for replacement.
Aug 05, 2016 | Monark Cycling
I'm wondering how to read the Serial # to determine the year of the machine.
very few serial numbers give indication of year of manufacture
a year of manufacture will show when a serial number began but will not tell how many years variations of that serial number ran for
for example in 1990 a serial number 0010101 was started for the first item produced but after 10 years the serial number will be 00101999 so 001011596 will not show a year of manufacture just that it was produced between 1990 and 2000
to add more confusion
in your particular question example a model 7800576 could have been produced in 3 different countries and the serial number will be from any one of those countries as each set of serial numbers will denote which country it was made in
may be it you contacted the manufacturer technical division, they may be able to provide a matrix that will answer your question better
May 13, 2016 | Garden
What years did they make the Monark model 2280 bicycle?
this web site should help you.http://www.nostalgic.net/monark-bicycles
Apr 30, 2015 | Monark Cycling
Find the manufacture year mercury verado motor
According to i-Boats, "Nothing in the Mercury Mariner Outboard engine model numbers or serial numbers provides year information directly.
The first serial number sold in a year becomes the beginning serial number. Serial numbers between that year's beginning serial number and the next fall into the same year. Search for your engine horsepower on the Mercury Mariner serial number year chart located here to find the beginning serial number for the range that includes your engine." Your other option is to take the serial number to an authorized Merc marine eager and they can look it up for you.
Sep 27, 2014 | Boating
Serial numbers sk50-6 2882
Who is the manufacturer?
Aug 30, 2014 | Monark Cycling
Radio wiring colors for factory 1996 mercury cougar
There are many types of radio, cassette and CD models for the Thunderbird and Cougars throughout the years.This is what I found,you need to get your serial number off of radio to get right harness.
Jan 11, 2014 | Cars & Trucks
Mercury outboard s/n 9445826, what year was this motor built ?
call mercury outboard they can tell you the answer to your question
Aug 29, 2013 | Raymarine St6002 Smartpilot Hydraulic...
Serial#854480 model94 Winchester rifle what year was it made
serial SI100808419 Samick guitar does it exist
Mar 11, 2012 | Computers & Internet
Stock tire search
Look on the side for a raised block with four digits; it's usually next to the U.S. DOT tire identification number. The first two indicate the week of its manufacture, and the last two are for the year. For example, 1702 would indicate the tire was manufactured in April, 2002. Prior to 2000, there were only three digits, with the last one indicating the year
Nov 10, 2008 | 2004 Triumph Thunderbird Sport
Optics Logo
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
