When I press shift and press 2 it should come up with this '' .But instead It comes up with this @ .It is also the same with the other number keys.Thank you
    Sergeant:
  • 168 Answers
Your computer is set up as an American English keyboard. The number keys, when shifted are !@#$%^&*() . If you are showing these characters, it is correct EXCEPT if you are not in America. You need to change the language in control panel-Regional and Language Options.
Posted on Jul 24, 2009
    Master:
  • 409 Answers
Sounds like you have a US keyboard set. Go to regional options and change it to a UK one.
    Scholar:
  • 86 Answers
The SHIFT plus 2 button will create the ampersand @.
The Quotation mark is 2 buttons right of the L key.
How to i get the at sumbol instead of2
Hold down any Shift key (left or right) and press the 2 key. The symbols shown over the numbers are entered when the shift key is held while the particular number key is being typed.
Sep 04, 2014 | Computers & Internet
My @ key isnt working. instead of that the other blue marked colan is coming. how to toggle back
Have you tried pressing the button "2" on your laptop? And have you tried pressing "Shift" and then "2"? If the number appears when pressing 2, but @ doesn't appear when pressing "Shift" and then "2", chances are your input language aren't correct. Go to Start > Control Panel > Regional and Language Options > Languages Tab. There you can set the proper input language for your keyboard.
Try using the on-screen keyboard as well. Go to Start > All Programs > Accessories > Accessibility > On-Screen Keyboard. If @ works there, then its possible your keyboard might be faulty.
Jan 30, 2013 | HP Pavilion dv6-1030us Notebook
HOW DO YOU DO NEGATIVE 10 POWER NUMBERS LIKE 2.5 X10-2?
Hi ceanelson,
First, I would clear the memory. Press [SHIFT] [9] (CLR) [1](Setup) [=] (YES). Then press [SHIFT] [MODE] [2] to switch to the LineIO mode. Put the calculator in Norm2 mode. I just like the way it display these kind of numbers in Norm2 mode. Press [Shift][Mode] [8] [2] for Norm2. Next check make sure FIX mode is greater than at least 5. I usually select FIX 9 but, 5 seems to be good for must non-essential calculations. Next, press [2] [.] [5] [*10^] [(-)] [2] [=]. You can use the [SHIFT] [LOG] for the 10^ and, I usually do instead of [*10^] key.
Next, when dealing with numbers like these, I always use brackets. Such as press [ ( ] [2] [.] [5] [*10^] [(-)] [2] [ ) ] [=]. This is because, if you divide or do some other math operation you want to keep this number as a whole complete number. The calculator tends to break numbers like these up and, you do not want that to happen. It's a good habit to get into. Post a comment on any questions you may have and, I'll respond quickly.
Jan 25, 2011 | Casio fx-300ES Calculator
How do i find square root of a number on casio FX-115ES?
Press the square-root key (third row from the top, second column from the left). Type in the number and press =. If you get a symbolic result, press S-D to convert or else press SHIFT ENTER instead of ENTER. If you don't want to see any symbolic results, press SHIFT MODE 2 to switch to the LineIO mode.
Dec 05, 2010 | Casio FX-115ES Scientific Calculator
How do i get a decimal on division instead of a fraction? in example when divide 100 by 3 it gives 100/3 instead 33.3
  1. If a fraction (or a radical) is already displayed press the [S<=>D] key to convert it into a decimal number.
  2. If you are entering an expression and want its result displayed as a decimal number, press the [SHIFT][=] key sequence instead of just [=].
  3. More permanent solution: If you do not want fractions nor radicals, configure the Input/Output to be LineIO. To do that, press [SHIFT][MODE] to access the (SETUP) then select the option [2:LineIO]
Jun 01, 2010 | Casio fx-300ES Calculator
On my dell mini when i press shift and the @ key a " comes up instead but when i press shift and 2 the @ comes up, can this be changed round?
The issue could be with the language settings. Go to Start>Control Panel>Regional Settings> Keyboard Language and ensure that it is set to English US
Dec 17, 2009 | Dell 0Y3740 Keyboard
Keyboard
The character code for the @ is 64. To insert it, hold the ALT key down and type 0064 on the number pad.
Hope this helps. Let me know if you need further assistance.
~ Spoem
Mar 27, 2009 | Computers & Internet
The numbers that are on the letters on the key board are stuck on
you prbabley just need to hit shift 10 times and turn that function off or press and hold it for 8 seconds (shift) and turn that off too.
Jan 17, 2009 | Logitech 967437-0403 Keyboard
The@sign
I had the same problem. When I pressed shift and that comma key I got a " instead of a @.
I looked to see what on the leyboard you normally press to get a " and that's the number 2 key.
Tried pressing shift and the 2 key and hey presto, I got a @.
So it looks like @ and " have swapped places.
So shift and 2 for a @!
Lizzie H
Oct 24, 2008 | Computers & Internet
Keypad
see on your keyboard's keys, the symbols which is above is to be pressed by holding down the shift. As ! is above 1 so for ! you have to press Shift + 1, same as @ is above 2 show for @ you have to press Shift + 2, simalarly # is above three so for # you have to press Shift + 3........... is it clear.....then... :)) ... otherwise Ask me again.
Iqbal
Apr 05, 2008 | Acer Aspire 5102WLMi Notebook
Computers & Internet Logo
374 people viewed this question
David Payne
David Payne
