Have a 64 gb sd card in, but can't get 4 channel wireless system to record...help
  • 5 Answers
SOURCE: Micro-sd card capacity
absolutely. the first time you pop it in, your phone will ask you if you want to format it. select 'yes' and then you will find several new folders for pix, flix, music, etc.
Posted on Nov 21, 2007
leroyal
  • 2120 Answers
SOURCE: Dosen't reconize 8 GB SDHC memory card
Older model printers won't recognize high-density memory cards.
2 gb is probably the largest to be used in your printer.
Posted on Dec 26, 2008
  • 489 Answers
SOURCE: Can I upgrade the 8 GB SD card to a 16 GB SD card?
You should be able to use any size SD card you want to.
Posted on Apr 14, 2009
Mr_Wizardtex
  • 205 Answers
SOURCE: Sansa MP3 recognizes 8 gb micro sd card as a 4 gb card
your reader does not support the 8gb device, look for firmware upgrade for the reader
Posted on Jun 29, 2009
t00nz
  • 4738 Answers
SOURCE: Tried to unlock Lexar SD 2GB and Lexar SDHC 4 GB - No luck
First of all, the 4GB card will never be able to work in your camera. Check on its face. It likely says SDHC, and SDHC cards as this format came out after your camera was designed (I know it looks exactly like a normal SD card, but it's not).
Now the 2GB card should work with your camera as it is a standard SD card. Remove the card from your camera. Look on the side of the card for the tiny slide switch, and slide it to the other "unlocked" position. Reinsert it in the camera, and see if that corrects the problem.
Posted on Oct 19, 2009
I HAVE ALCATEL T'POP MODEL 4010X .
The model phone you use supports up to 32 GB of storage. So a 64 won't work but up to a 32GB will.
Mar 15, 2014 | Computers & Internet
Tip
How to recover SDXC Memory Card
Storage is getting cheaper, smaller while offering higher capacity every year. 64 GB memory cards are extremely common in today's smartphones, digital cameras, tablets and media players. Due to their sheer capacity, a single failure can cause a local catastrophe with that much information being gone.
http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-0_0.jpg
Fortunately, the market offers numerous data recovery tools that can help you get your data back. But there is something about these cards you should know before you reach for a data recovery tool.
Flash Chips: Riddled with Defects
Can you believe you can buy the whole 64 gigabytes of fast, high-quality solid-state memory for as little as $20, or does it sound too good to be true? Why is an SSD drive of said capacity three to four times as expensive as a much smaller SD card with similar capacity? Isn't it using exactly the same type of memory, just in a different shell?
In fact, you can't really buy 64 gigs of high-quality flash memory for under $20, and there is a good reason why SSD drives are that much more expensive compared to SD or micro SD cards. The answer is buried in the question itself. Why you can buy a 64 GB microSDXC memory card off Amazon for not much more than $20, the actual flash memory the manufacturer puts in these cards is of a completely different quality compared to that of a typical SSD drive.
So how exactly are manufacturers able to achieve these unbelievably low memory prices? They do smart tricks to make the memory card appear as 64 GB of contiguous space while in fact the actual chip is riddled with defects.
Each memory card employs a tiny microcontroller that maps flash cells to logical addresses. The memory chips are manufactured with abundant capacity. During the manufacture, the chip is tested for defects. Unreadable blocks are simply mapped out and become non-addressable and inaccessible from the outside. Bingo! We've just turned an imperfect chip into a perfectly usable memory card. These tricks are nothing shoddy; they are used by all SD card manufacturers, and they are part of the published SD standard. If not for these tricks, SD memory would probably cost the same (or more) as today's SSD drives.
Now when you know the truth about today's flash chips... can you trust them your data? In fact, you can. Granted, SD cards can sustain a much more limited number of write cycles compared to an SSD drive. When one or more data blocks reach their end of life, the built-in microcontroller of said SD card is supposed to take them out of circulation and assign their logical address to another (working) cell. But what if that cell contained some system information such as a part of a file system? If this is the case, the memory card becomes corrupted, and you'll need to use special tools to extract information from that card.
Recovering Data from SD Cards
Luckily, we have a large number of data recovery tools available on the market that claim to recover the entire content of your memory card. But were they really tested with any of those memory cards in their compatibility lists, or do developers simply assume the recovery will work based on the same principle as traditional magnetic media? In fact, I've seen both and in between. Some products can recover all types of SD cards as they claimed, some other tools can't deal with SD cards at all, while some other tools can only recover SD cards up to 32 GB.
Wait a minute... Why the 32 GB limitation? Why some of the tools can recover 32 GB cards, but fail miserably when reading a 64 GB one? Should the tool either work or not? The reality is more complex than the numbers. While SD memory cards up to and including 32 GB conform to the SDHC standard, larger SD cards (64 and 128 GB) conform to a different standard called SDXC.
Recovering SD, SDHC and SDXC Memory Cards: Is There a Difference?
There is in fact a big difference between smaller (up to and including 32 GB) and larger (64 GB and up) SD cards. The former conform to the SDHC standard, while the latter use the newer SDXC standard.
For you as a user this can mean two things.
  • First, if you are using a 64 GB memory card, make sure that both your portable device and your computer's SD card reader advertise support for SDXC cards (or simply put, they explicitly state support for 64 GB SD cards). If your card reader is old and can only support SDHC cards, you won't be getting anything but errors if you try to read that card with your computer.
  • Second, SDXC cards are formatted with a different file system. Let me explain. When SD cards initially appeared, they used FAT32 as a file system. FAT32 was good enough in the old days. However, this file system has inherent limitations, restricting maximum file size to 4 GB. Just a few years ago this would be a laughable limitation. Today, a typical HD video will already run you more than said 4 GB. If you try to save a large file onto a 32 GB memory card (formatted with FAT32), the write operation will fail.
This is why the SD consortium decided to use a different file system for the new generation of SD cards. 64 Gb, 128 GB and larger SD cards come formatted with exFAT.
exFAT is a new file system developed by Microsoft. exFAT is based loosely on the original FAT32. However, exFAT does not have the limitations of the older FAT/FAT32. exFAT is extensively used in portable electronic devices due to its lightweight design. This was one of the reasons exFAT was selected by the SD consortium as a standard file system for the SDXC format.
Are there downsides to exFAT? There's one, but it's a major one. While exFAT is designed and owned by Microsoft, it's not free. Microsoft requires manufacturers pay licensing fees for using exFAT in their devices. As a result, this has become a limiting factor for many portable electronic devices, especially inexpensive ones. This is one of the reasons why you can use 64 GB SD cards in some devices but not in others.
As a result, when recovering data from a 64 GB SD card, you'll need two things:
  • An SD card reader supporting SDXC (or stating explicitly that it can read 64 GB SD cards);
  • A data recovery tool that supports exFAT;
Not all data recovery tools can support exFAT because of the restrictive licensing model employed by Microsoft. Even if a tool advertises support for "all types of memory cards", it may or may not support exFAT. One of the tools known to support SDXC memory cards and exFAT file systems is Hetman Partition Recovery.
But I've Just Bought a 64 GB SDHC Card!
Sigh. This chapter is probably the most disturbing part of this article. Every other week, we receive an email from a customer describing a typical situation. Because there are so many reports, and because they all describe the same thing, let me just summarize it below.
A guy buys a 64 GB SD card for a price that's significantly below the market. When the memory card arrives, he tests it in his computer, discovering 64 gigabytes of usable capacity. Suspecting that 64 GB of flash memory for under $5 could be a scam, the guy tests the card by writing some data. The writes are extremely slow (3-7 MB/s), so testing the entire capacity would literally take the whole day. He writes some 1-4 GB of data and reads it back. All seems fine, so the guy formats the card and puts it into a phone, MP3 player, digital camera, or whatever portable device he bought it for.
Day after day, week after week the card is filling up with data. Pictures, music and videos are saved onto that memory card. 8 gigs, 16 gigs, 32 gigs, 64 gigs - the writes keep going, the memory card seems to be holding well. Then all of a sudden a photo won't show in a viewer, an MP3 file won't play, a video won't show up. The guy takes the card out and connects it to a PC in an attempt to save the rest of the data. But... oops! There are no photos, music or videos on that card, just garbage.
It is this moment the guy seeks for help and writes us an email. Sadly, in situations such as the one I described our hands are tied: that memory card was a fake. In fact, the "deal" advertises a 64 GB micro SD card for only $4.79. Yes, it's under five bucks for a 64 GB memory card. The description is Pidgin English and reads something like this: "New 64 GB Class 10 Micro SD HC Memory Card with Adapter Fast USA Shipping Dependable memory card for your favorite photos, videos, apps, and games Easily transfer files between phone, tablet and camera" blah, blah, blah.
Remember: if it seems too good to be true, it's probably not true. See that "Micro SD HC" designation? It's a dead giveaway. You can't buy 64 gigs of memory for $5. And, THERE ARE NO 64 GB SDHC CARDS, period. The SD standard dictates that all SD cards with capacities higher than 32 GB are made to conform to the newer SDXC standard. If you buy this card, you won't be getting anything but a fake.
Ditto. Do not buy these. Remember how the packaging looks, and ignore deals that seem too good to be true.
SDXC Recovering 64GB and 128GB Memory Cards Hetman Software
on Jun 06, 2016 | Hetman Partition Recovery - Recover...
Tip
Wii soft mod guide
Wii SoftMod Guide 3.1 - 4.1
Before we start into the process, you will need an SD card, at most 2gb capacity. This SD card will need to be formatted into FAT32 format.
Note: If you are on Wii System Firware 3.1, 3.3 or 3.4 You need to be connected to the Internet, unless you know the proper steps to upgrade using the Wii System WAD and Firware Updater 4.1 which I may include later.
First, download this file pack. Wii SoftMod 3.1 - 4.1 Pack
Download Readme file here. Wii SoftMod Readme
Step 1. Install The Homebrew Channel & BootMii
1. Put all the files from ‘Wii SoftMod 3.1 - 4.1.rar’ onto the root of the SD Card.
2. Insert the SD card into Wii.
3. Go to Wii Options, then go to Data Management > Channels > SD Card, then you will get a message saying "Load boot.elf?" , select 'Yes' and the Hackmii installer will run. (Goto the Channels first, then insert card or your console might freeze)
4. Install Bootmii as boot2 if you can, if not then install it as an IOS then go back and install the Homebrew Channel.
Step 2. Install Recommended CIOS
1. Go to Homebrew channel and run Trucha Bug Restorer, load IOS36, press 1, read the warnings then select 'downgrade IOS15', select to load IOS from SD card then let it do its job, keep an eye on what it is doing and make sure you select 'load from sd card' when it asks & don't get any errors.
2. Run Trucha Bug Restorer again, this time select to load IOS15 on first screen using dpad left/right, then select the IOS36 menu & install patched (select 'yes' on all 3 patches) IOS36 to slot 36, again using IOS from SD card.
3. Run Trucha Bug Restorer again, load IOS36 and this time select restore IOS15.
4. Run cIOS38 r14 installer, select IOS36 as the one it should use and then select wad install.
5. If your Homebrew Channel flips upside down then continue with the guide and when completed reinstall the homebrew channel.
Step 3. Update System Menu (Only for 3.1, 3.3 or 3.4 Firmware) Note: Internet Connection needed
1. Before you update to 4.1 make sure you have at least 250 blocks free or you will brick, install IOS60-patched first with Wad Manager using IOS249, then run Firmware Updater 4.1.
Step 4. The Final Step
1. Go to the Homebrew Channel and run Wad Manager 1.4 and load IOS249 (Default) and SD card.
2. Instal the following IOS.
* IOS38-64-v3610
* IOS50-64-v4889
* IOS53-64-v5149
* IOS55-64-v5149
* NeoGamma r8b17
Restart your console and your finished!
on Feb 18, 2010 | Video Game Consoles & Games
I want to know the graphic card slot in the motherboard ASUS M2N68-AM-SE2. Whether it supports DRR1, DDR2 OR DDR3.
Hi, you can see the list here:
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68AM/#specifications
At this site you also find drivers.
Remember to select your operating system
AMD Socket AM2+ / AM2 Processors
for AMD Phenom™ FX / Phenom / Athlon™ / Sempron™
AMD Cool 'n' Quiet™ Technology
AMD64 architecture enables simultaneous 32-bit and 64-bit computing
Support 45nm Phenom™ II CPU Chipset NVIDIA Geforce 7025/nForce 630a
System Bus 2000/1600 MT/s Memory 2 x240-pin DIMM, Max. 4 GB, DDR2 1066/800/667/533 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*DDR2 1066 is supported by AM2+ CPU only Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
Storage Southbridge
4 xSATA 3 Gb/s ports Support RAID 0,1,5,10,JBOD
ATAPI support ,AHCI mode
LAN RTL8211CL Phy Gigabit LAN Audio ALC662 High Definition Audio 6 -Channel CODEC
USB 10 USB 2.0 ports (4 on back I/O, 6 on board)
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCI-E x16 Graphic card slot.
Aug 25, 2011 | ASUS M2N68-AM SE2 Motherboard
My wife's computer is an Acer Aspire 5100 with a 4000 AMD Athlone 64 processor. It came with only 1 GB of memory and is runniing Vista Home Basic. It is terribly slow and I would like to increase the...
yes one will be for single channel ram the other for daul channel ram.if you have the acer owners manual it will tell witch ones are single and witch one is daul.
Sep 21, 2010 | Acer Aspire 2100 (91.AB675.D02) PC Desktop
Should you use an 8gb sd memory card in a panasonic lumix dmc-fx3 camera ?
The manual lists the following SD cards compatible:
4 GB SDHC Memory Card
2 GB SD Memory Card
1 GB SD Memory Card
512 MB SD Memory Card
256 MB SD Memory Card
128 MB SD Memory Card
64 MB SD Memory Card
An 8GB card may or may not work. If you try it, make sure it is an SDHC card. (Note: HC=High Capacity)
Thanks for using Fixya.
Apr 27, 2010 | Panasonic Lumix DMC-FX3 Digital Camera
What is the most capacity of Micro SD that suport of that cellphone!
The SDA announced the microSD format at CTIA Wireless 2005 on March 14, 2005, and approval of the final microSD specification was announced on July 13, 2005. At launch, the microSD format was available in capacities of 32, 64, and 128 MB. SanDisk introduced a 2 GB microSD card in July of 2006, initially priced at 99 USD. Since then, prices for flash memory devices have fallen dramatically. The same 2 GB card as of April 2009 can be found for as little as 12 USD at department stores, and as of May 2009 for as little as 6 USD at online electronics stores. At present date Jan 2010 a 16 GB micro SD card class 2 comes for about $40 and a 4 GB class 2 micro SD card comes for about $8.
please rate my answer as helpful. thanks. Joe
Feb 23, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
I need to know what kind of sound card i have for my hp note book Model number: KR346AV
Processor Processor Class: AMD Turion 64 X2 Mobile Processor Speed: 2 GHz Cache Size: 1 MB Bus Speed: 800 MHz Memory Installed Memory: 2 GB Maximum Memory: 4 GB Memory Technology: DDR2 System Input Devices: Keyboard|Touchpad Interface Connection: Audio - Line In (1/8" Mini)|Audio - Line Out (1/8" Mini)|Audio - S/PDIF (1/8" Mini)|Bluetooth|Ethernet - RJ45 Twisted-Pair (XBaseT)|FireWire 400/IEEE 1394 - 4 pin|Infrared - iRDA Wireless (iRDA-SIR)|Port Replicator/Docking Station|Serial - RJ11 Modular (Phone/Telco)|USB - Universal Serial Bus 2.0|Video - S-Video|Video - 15 pin High-Density D-shell (VGA) Slots: Express Card 34|Express Card 54|Memory Stick PRO|MultiMedia Card (MMC)|SD Card|Sony Memory Stick|xD-Picture Card Display Display Size: 15.4 in Aspect Ratio: 16:10 Display Type: LCD Display w/ Glossy Screen Max Resolution: 1280 x 800 Video Chipset: NVIDIA GeForce 7150M Storage Included Drives: DVD+-RW DL Hard Drive Capacity: 250 GB Number of Storage Drives Included: 1 Features Included Network Card: Ethernet (10/100 Mbps)|Wireless Ethernet - 11 Mbps IEEE802.11b|Wireless Ethernet - 54 Mbps IEEE802.11g Included Devices: Built-In Microphone|Built-In Webcam|Headphones|Modem|Remote Control Software Operating System: Microsoft Windows Vista Home Premium Dimensions Height: 1.56 in Width: 14.05 in Depth: 10.12 in Weight: 6.06 lbs Warranty Warranty Information: 1 Year Limited Warranty More Info URL: URL General normalized-Cache Size: 1 normalized-Display Size: 15.4 normalized-Installed Memory: 2000
Sep 26, 2009 | HP (400745-001) Sound Card
What kind of memory SD card would work for Panasonic DVD Recorder DMR-ES46V? I was hoping to put in a 8 gig memory card but those are all SDHC. Will those cards work in this unit?
This info is straight from the panasonic website. The owners manual and more info for the unit can be found here.
Hope his helps!
Suitable SD Memory Cards
8 MB, 16 MB, 32 MB, 64 MB, 128 MB,
256 MB, 512 MB, 1 GB, 2 GB (Maximum)
Mar 16, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
Panasonic PVGS-50D SD memory card
Check your manual for the max supported SD card size. Most likely it will either support a minimum of 2-4 gb :)
So yes you can get larger cards for your PV GS 50D
Regards,
Shadowmaru
Feb 10, 2009 | Panasonic PV-GS500 Camcorder
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
