Question about Nexgrill Grilling
How to replace the burners in the nexgrill model 720 0677
2 Suggested Answers
  • 2006 Answers
SOURCE: How do I change the
That same model number has several different burners. One is a straight burner (three each); a couple are loop types and several have a flat surface with gas outlets.
Part Number
Description
Shopping
Cart
10361
Stainless Steel
Tube Burner
10361.jpgThis stainless steel tube burner is a replacement burner for numerous gas grills produced by Nexgrill, some of which are sold under the Charmglow brand name. This burner is 16 & 13/16 inches long. Please use our Nexgrill drop down model list, together with the illustration and sizes, to select the correct burner for your grill. Most of these grills use three to five burners. If you wish to benefit from quantity pricing on the 10361 burner, see the order entries below for three-pak and five-pak quantities.
This is the easy one - Just pick up the flutted end and slide out from the gas line. No screws or bolts
$12.79 each
Quantity:
Posted on Jun 05, 2011
Troubleshooting nexgrill charcoal gas grill
did you replace the battery in the igniter?
less than 100 degrees indicates a safety has engaged, close gas valve, open burner valves.....wait 5 minutes. keep lid open, close burner valves, open gas valve until you hear the regulator click
turn on "ignition burner" and ignite (with switch or at specified port).
After this part is lit open other burners one at a time , waiting until each lights before opening the next.
Dec 07, 2013 | Nexgrill Charcoal and Gas Grill Combo
Have a three burner model. Middle burner is not lighting up.
The burner could be out of postion or the igntion is burner should light with a lighter ,to prove there is gas there , if not burner or orifice could be block or wire could be off the ignition .
Jul 11, 2012 | Nexgrill 720-0234 (LP)
I need to convert from natural gas to lp. I cannot find my owners manual. Is there one online I can download?
Contact Nexgrill and ask them for the correct orifices for your model grill to go from NG to LP. Once you have the correct orifices you will also need the LP tank and a regulator and hose. It is farily straight forward to replace the orifices. You have to remove each burner, take out the NG orifice and install the LP orifice.
Jun 18, 2011 | Nexgrill 720-0234 (LP)
How do I change the burners on a Nexgrill Model 720-0108? Thanks for any info for less than handy woman!
Part Number
Description
Shopping
Cart
10361
Stainless Steel
Tube Burner
$12.79 each
Quantity:
Jun 05, 2011 | Grilling
Jenn-air model 720-0061 LP burners only light on one side cleaned with wirebrush and blew out with air?
The crossover for the flame to "jump" to the other side of the burner is clogged, rusgted, etc. It looks like a straight cut line on the rear under side of the burner. Nexgrill told me that the burners did not have an adequate amount of "finish" on them. Call them and get all new burners for free under warranty, Since 2004, I am on my 5th set of burners.
May 05, 2010 | Jenn-Air JLG7130A
Seering Burner on 720-0466
Push and turn clockwise when so that it will spark.I hope it will help your problem.
May 18, 2009 | Nexgrill 720-0234 (LP)
Grill jenn-air will not heat past 100 degrees
You need to pull the burners out and scrub open the side feedholes on the burner. These ususally clog up over time reducing the heat available for cooking. Also, sometimes the Gas regulator goes bad over time when left outside for a year or two. A bad regulator will put out less gas as it fails closed.
May 04, 2009 | Nexgrill 720-0234 (LP)
Nexgrill patio heater won't stay lit
I called Nexgrill technical support at 1-800-913-8999. They are sending me a new thermo couple to keep the valve open when ignited - so the patio heater will stay on. I needed to give them the serial number (inside the propane tank door) and fax them a copy of the receipt.
Hope this helps.
Jun 01, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Jenn-air grill
Cleaning burners"
May 25, 2008 | Grilling
Grilling Logo
98 people viewed this question
Top Nexgrill Grilling Experts
80stech
Michael Vincent Cruz
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Nexgrill Grilling Expert? Answer questions, earn points and help others
