Question about Haier Heating & Cooling
My dog ripped my power cord out of my Haier A/C unit and i dont know where they go
hotuna
  • 288 Answers
SOURCE: faulty safety power cord...
You can by-pass it by simply connecting the 2 wires together. Obviously the safety it is supposed to protect you from will not work, but it can get you by instill a replacement can be found. It seems like the surge burnt the coil out on the switch. If you are conscious of the heater and what its going ,you should be safe. They made these things a long time without a trip switch on the cord. It just requires some common sense.
Posted on Mar 10, 2008
  • 306 Answers
SOURCE: my dog chewed the cord to the haier air condiener
You can go get a new cord make sure it is for window air conditioner has to be heavy duty for the amps that it draws. Or you can patch it making sure to get the right wires connected. And really the best way would be new cord but wrapping the wires and insulating them very well can get by. As long as you know how important it is to make the connections very good.
Posted on Aug 16, 2009
  • 636 Answers
SOURCE: dog chewed power cord which includes power unit
If it is chewed before the control knob, just buy a 3 prong plug adapter and wire it up.
Posted on Sep 18, 2009
  • 8404 Answers
SOURCE: Need wiring schematics for Haier HWR12XC5 AC
My friend ... you are doing a simple repair ... you don't need a wiring schematic to replace this power cord. When you get the unit open ... you will find the other end of the ripped cord ... black goes to black, white goes to white green goes to green or ground. In fact ... you will trim the end of the cord and reattach it using either crimp connectors or wire nuts.
Thanks for your interest in FixYa.com
Posted on May 31, 2010
  • 47 Answers
SOURCE: My dogs chewed and ripped out the electrical cord to my haier 10000btu a/c unit, model# hwr10x1c. I know where the the green ground goes, but where do the Other 2 go?
A 10,000 BTU A/C is probably a 110 volt unit. You are correct that the green wire goes to the ground terminal of the plug. The red or black wire is the "Hot" wire and would go to the "narrow" prong or "right" side of the receptacle - when the ground is on the bottom (if it is installed correctly) as you look at it. The white wire goes to the wide prong or left side of the receptacle. If the plug is fine and you have to connect the wires to the unit, there should be a wiring diagram to follow inside or on an electrical cover plate. Polarity is critical, so be sure what you do or let an electrician do it for you. Good Luck!
Posted on Mar 31, 2017
Mar 30, 2017 | Heating & Cooling
Haier window unit reset plug not resetting
check the house power board circuit breaker if the light indicator is not working
Jul 25, 2016 | Haier Heating & Cooling
REWIRE THE POWER CORD THE POWER CORD WAS RIPPED OFF BY MY SWOON TO BE EX HUSBAND BY HIM RIPPING IT OUT OF THE WINDOW. THERE IS A GREEN, WHITE AND BLACK WIRE. WHERE DO THE BLACK AND WHITE WIRES GO?
Its easy to do but difficult to explain here. I think it best to have someone with a bit of electrical skill to do this for you . Sorry i cannot help you as much as i would like. Good luck. jon
Aug 08, 2011 | Haier hwr10xc6 Air Conditioner
I have to install a new cord . i need to know where to hook up the power line inside my unit .thank you
To get the best information (because, I can't see the unit) call Haier Customer Support 1-877-337-3639 and ask for Technical Service.
Jun 29, 2011 | Haier HWR12XC8 Air Conditioner
Dog chewed power cord. how do I repair
assuming this is a window air cond? It is not safe to use electrical tape, duct tape or any other kind of tape on a power cord to cover bare wiring. Many times I have cut the cord short enough to cut out the place where chewed and gone to a hardware store where I can get a new cord end that matches the wall plug and wire it in to the shorter cord. If this is not possible, you will need to either make a new cord or try to find a cord at an appliance supply house.
Apr 09, 2011 | Haier Heating & Cooling
May 31, 2010 | Heating & Cooling
Haier portable DVD player will try an load the disc but is unsuccesful, has power and monitor works
Check to make sure exact power volts are meeting units specifications, take a reading at end of power cord
Dec 02, 2009 | Haier Portable DVD Player PDVD7
My dog chewed the cord to the haier air condiener can i replace the cord or fix it
Aug 15, 2009 | Haier Mechanical Air Conditioner HWF05XC7
Power Cord Chew Toy
Any qualified electrician will be able to fix it. It shouldn't take more then 1/2 hour for them do to it, and they can even put on a cable that will protect your dog/the cable from biting through again and possibly getting electrocuted. Overall cost should be less then 50 dollars. Check the Yellowpages if you don't know an electrician.
Jun 05, 2009 | Samsung AS1293L Air Conditioner
Faulty safety power cord...
Mar 10, 2008 | Haier hwr10xc6 Air Conditioner
Heating & Cooling Logo
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
