Question about Konica Minolta Office Equipment & Supplies
Konica Minolta biz 600 error c-6708 plz help - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,595 Answers
Exposure lamp or CCD issue. both located under the big glass. The CCD is the large black device on the right. The scanner is device on left that lights up scan a document though the Doc feeder or main glass.
try this reset
FIRST, if this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the destroy the lamp or CCD
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly
Posted on May 07, 2017
  • 16 Answers
SOURCE: konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
Posted on Jul 19, 2008
Kevin Hayes
  • 167 Answers
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Posted on Feb 17, 2009
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
  • 158 Answers
SOURCE: konica minolta biz hub C250 need to reset admin code URGENT
you cannot overide the administrator password on the konicas the default password is 12345678 try that
Posted on Oct 31, 2009
  • 44 Answers
SOURCE: bizhub 250. error c2152
Check and make sure there are no jams by the fuser ie: bits of paper in the paper path.
Posted on Nov 29, 2009
Sir I have Minolta biz 600 error c-6708
If this code comes back have to replace the CCD or the exposure lamp. both located under the big glass. The Black device under the glass to your right is the CCD and the exposure lamp is bright light to your left which turn on when you scan
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Apr 21, 2017 | Minolta Office Equipment & Supplies
Error Code c0045
Bop. Error Code c0045. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Konica Minolta Di450 Error Codes
Aug 25, 2016 | Konica Minolta Minolta Di450 Di470 Di550...
After upgrading to windows 10, unable to scan doc from Konica C203 to PC
To help you troubleshoot the issue about unable to scan but able to print, it is recommended to try uninstalling the previous software and driver and re-install Konica Minolta BizHub C203 printer software and drivers from the link given below:
If issue persists, you can find the troubleshooting link and check if that helps to resolve the issue:
If issue persists, it is recommended to contact Konica Minolta bizhub for further assistance:
Jun 13, 2016 | Konica Minolta bizhub Office Equipment &...
C-6708 code
Does your exposure lamp come on ? Mite have a problem with the scanner lamp or the Scanner reader that the CCD the black device under the big glass that views the document to be copied. Exposure lamp is what high lights the original document(s)
May 30, 2014 | Konica Minolta Developer 02xk Dv710 for...
71 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
