Question about IFB Washing Machines
Ifb elina model it didn't spin I changed MCU card 1year back Pls help to how to fix it
P11 IS THE CURRENT ERROR CODE APPEARING IN MY IFB WASHING MACHINE. PLS ADVISE
You are not very clear as to what else is going on with your washer.
Is it getting any power, are the dials on all cycles functional? Sorry I know what an IFB Washer is but there can be quite a few malfunctions. Please elaborate if possible.
Dec 24, 2016 | IFB Washing Machines
I have IFB washing machine it shows E7 error
1:IFB Washing Machine Not Turning ON OR Turns ON But Does not Starts. 2:IFB Washing Machine Door Does Not Opening. DE Error 3: Water is not coming inside the IFB Washing Machine Inlet problem 4:Water is Leaking from the washing machine, drum or hose pipe damaged 5:Wash is not happening / Spin not Happening in the IFB Washing Machine 6:Drum NOt rotating or Drum Making Huge Sound while spin cycle, 7:Water not Draining From the washing Machine 8:Burning smell, Tripping Problem, etc https://electronicshelponline.blogspot.com/
Read more: http://ifbservices-com.webnode.in/error-code-fault-codes/
Aug 05, 2016 | IFB Washing Machines
My ifb washing machine top load is got error in timing display as number 4
If the error comes up as E:04, then that is an error code that the washing machine is overloaded.
Try this:
Remove the clothes from the washing machine.
Unplug the machine from the power receptacle for 1 hour.
After 1 hour, plug machine back in and run the machine without the clothes in it until it completes the cycle.
On the next load, do not load the machine with as many clothes.
Please reply to me if this works.
Thank you!
Jun 13, 2016 | IFB Washing Machines
My IFB Neptune DX dishwasher has died with F9 error code(divisor position error) with all LEDs The tech guy has tried changing the electronic card/ controller but that did not work. The problem is not
First of all you should make sure you have not paid the technician for the service call and new controller if that did not fix the problem. F9 errors are usually linked to controller or sensor faults. If replacing the controller has not helped then it is a sensor like a thermostat or motor speed etc. that is confusing the controller. In any case it the IFB authorised technician who can fix the problem as there is not much information available about this dishwasher.
Apr 22, 2014 | Dishwashers
Ac voltage become hihg or low when start ifb washing machine
We got a IFB front loading washing machine last week only after 3 time wash 4 th day it is showing AC-LOW message . the service people came and went but nothing is done what is the next solution?
Same point top loading Godrej 6.5 kgs working fine but water consumption is more in that compared to front loading machine so pls sugeest good solution at the earliest.
Sep 30, 2012 | IFB Washing Machines
Whirlpool awm 8143 doesn't stop at the end of the spin cycle. Instead it clicks for a while when the timer displays 1 minute then displays F07 then goes back to wash cycle. While googling I found something...
F07 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit. Check wire harness connections between drive motor and Motor Control Unit (MCU), and between MCU and the Central Control Unit (CCU). Reconnect power and plug unit in.
Check the MCU by looking for operations of the drive motor, and check drive motor for powered rotations. Replace failed component.
Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 12, 2010 | Whirlpool AWM8123 Front Load Washer
Washing Machines Logo
22 people viewed this question
Top IFB Washing Machines Experts
Eric Taylor
Tall Tiger
Tall Tiger
Eric Sutherland
Are you an IFB Washing Machine Expert? Answer questions, earn points and help others
