Question about Minolta Office Equipment & Supplies
Sir I have Minolta biz 600 error c-6708 - Minolta Office Equipment & Supplies
  • Minolta Master
  • 6,325 Answers
If this code comes back have to replace the CCD or the exposure lamp. both located under the big glass. The Black device under the glass to your right is the CCD and the exposure lamp is bright light to your left which turn on when you scan
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Posted on May 06, 2017
  • 214 Answers
SOURCE: Konica Minolta biz hub c350 malfunction code c-0b4c
C0B4C Finishing option Exit Motor malfunction
Try reboot holding utility key down and do trouble reset, if it doesn't help then there is something wrong with exit motor, call for service
Posted on Dec 07, 2007
SOURCE: error code c-12cc for Konica Minolta biz hub c-350?
Error code C0520 on Konica Minolta biz hub c-350??
Posted on Apr 26, 2008
SOURCE: error c3451
First ignore the revious solution, it is not even close. The error code c3451 refers to a copier warm up error, the machine had not reached the correct temp within a specific time. I bet it happened when you first swiched on one morning. Easy to reset and fault usually goes away.
To Reset switch machine off using the switch inside the front door, not the one on the control panel.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on.
This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing.
hope this helps
Posted on Jan 15, 2009
Kevin Hayes
  • 167 Answers
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Posted on Feb 17, 2009
SOURCE: hard reset 6708
how can nokia 6708 master reset
Posted on Aug 18, 2009
Konica Minolta biz 600 error c-6708 plz help
exposure lamp or CCD issue. both located under the big glass. The CCD is the large black device on the right. The scanner is device on left that lights up scan a document though the Doc feeder or main glass.
try this reset
FIRST, if this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the destroy the lamp or CCD
Apr 21, 2017 | Konica Minolta Office Equipment & Supplies
What does service code C4661 mean on the biz hub 600?
Could not locate that code in the service manual, sure about it?
Sep 10, 2014 | Konica Minolta Bizhub Press C6000 Copier
C-6708 code
Does your exposure lamp come on ? Mite have a problem with the scanner lamp or the Scanner reader that the CCD the black device under the big glass that views the document to be copied. Exposure lamp is what high lights the original document(s)
May 30, 2014 | Konica Minolta Developer 02xk Dv710 for...
I am having L code errors on our Konica Minolta Biz Hub 363
Sir/Mam,
#10 Transfer roller needs replacing sponge looking roller right side of the of the machine when you open to remove paper jams.
# 9 Developing unit needs replacement that the part that holds the drum and developer/toner. IF YOU YANK THIS UNIT OUT WITHOUT REMOVING THE LITTLE COVER ONE BOLT and DICONNECT THE CONNECTOR. BIG TROUBLE, going to cost a lot to repair.
#8 PAPER DUST REMOVER the device that collect paper dust yes paper does produce DUST. Just before the sponge roller
#6 IS Warning that the developer has not been replace inside the drum cartridge. SEE #9
#4 Drum need to be replaced.
Really have to watch for all of that sir/mam.
Apr 11, 2014 | Konica Minolta "Minolta Bizhub 363 Copier,...
Hard reset 6708
Jun 04, 2008 | Computers & Internet
56 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
