Question about The Computers & Internet
Applications are showing on the left of the screen vertically and Im trying to remove them by exist but they come back
I have nokia n73 phone.it's showing genaral memory full close some application and try agin when watching videos editin images etc.
Long press navigation or menu button,if there are existing application running or unwanted application,navigate that apps and just press c to exit or close that application.this may happen when you open an apps and do not close the apps properly then open a new one,this error takes place. If does not work,you need to format the phone to remove the unwanted running application on your system,just type *#7370# on your home screen,a lock code will be ask then enter your preferred code if change before, or 12345 as the default code,be sure to back up all of your data before doing this method.
Jul 27, 2011 | Nokia N73 Cellular Phone
I had installed Highland Warriors previously on my laptop, then i uninstalled it, and reinstalled it. After i had completed reinstalling it i try playing it, but it says please insert disk into cd/dvd...
When you uninstalled the program, you did not actually remove all data the was originally placed on the system.
Get a program (free if you can) called REVO Uninstaller. Runs REVO and select uninstall Highland again. Now use the Left Over Scan option. When it seeks out left over data, the Blue Line will fill the entire line, meaning all data is now found. Hit "NEXT" and a new window appears. Hit select all and remove existing left over data. When done, turn off the computer and wait 10 seconds to turn on again. Now reinstall your game and try to paly it as usual.
Jan 11, 2018 | Data Becker HighLand Warriors for Windows
I have a hpdv6000 series laptop and recently it
Hi:
I believe that your LCD panel is the problem, but you should verify that you have good video, by toggling to an external monitor to check your output. If it dispays good, you have an LCD problem.
Nov 10, 2009 | HP Computers & Internet
About configuration
I would suggest uninstalling the application completely and rebooting your PC before trying to reinstall. Use Revo Uninstaller, a free application available here: http://www.revouninstaller.com/revo_uninstaller_free_download.html
Thiswill effectively remove all the bits and pieces left behind, including the registry entries that were created. Some of these settings are kept during a normal uninstall, and stay persistant when you reinstall the application.
After it has been completely removed, try the reinstall and see if your problem still exists. If so, please post back.
Jun 18, 2009 | Yahoo Messenger
IBM Thinkpad 2652 has horizontal and vertical gridlines on screen
Try to remove your Memory modules and clean the contacts with a pencil eraser. Makes sure to clean both sides of the memory contacts.
Nov 21, 2008 | IBM ThinkPad A31 Notebook
Red Vertical lines on 15" Acer LCD Monitor
I think this is most likely a monitor problem. Can you try a different monitor of computer to the monitor? That would help pinpoint the problem. Is it under warranty?
Sep 17, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
My screen showing a vertical line
Replace the laptop under warranty. No point trying to fix the error and voiding the warranty.
May 25, 2008 | Compaq Presario Notebook
Screen split into 2 colours - vertical split
I think it is degaussing problem if any thing is lying which has magnet please remove it. &then put of monitor for 15 minutes & then put on again.do not move when it is on. please let me if it gets ok good luck
Sep 09, 2007 | Philips 170B4MG 17" LCD Monitor
Computers & Internet Logo
43 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
