Question about Cell Phones
I cannot get my A360 polar device to pair with my flow app on my phone. What do I do?
I was working for a year, but I have switched off my device and now I cannot get it to pair. What do I do?
My bluetooh vibeDG-478assist was working i took it n another room w my phone now i cant get it to pair back up tried installing app to do it i get msg its pairung but wont connect
If you make both bluetooth devices go into a search mode at the same time they should pair. Some devices give you a code that must be entered to pair with the other unit. I've had some units give the code and before you can look at it it's gone. Another app was taking over at that stage. Solved by getting rid of the secondary app.
Reinstalling that app after a successful pairing.
Distance or proximity is sometimes a factor as well.
Feb 08, 2018 | Cell Phones
I have nokia 6120 classic with BH-100 ear piece, how do you get the hands free ear piece to work
just go into the settings & there you will Accessory settings..
Thank you
May 21, 2008 | Cell Phones
I can't get my headphones to pair up with my LG phone what do I need to do
  1. Place your Bluetooth headset into pairing mode by holding down the call button, then setting the power switch to ON. ...
  2. On your Mobile Device, tap Apps > Settings > Bluetooth.
  3. Tap the Bluetooth switch ON to enable Bluetooth.
  4. Tap Search for devices at the bottom of the screen.
  5. if you don't come right go to www.lg.com/us/support/product-help/CT30013120-1430860289178-headset
Apr 05, 2017 | LG Radio Communications
How do I reset the time?
User Manual - Pivotal Living
pivotalliving.tumblr.com/usermanual
To ensure the most accurate tracking of members' sleep and daily activities, we ... Once on, to turn the Pivotal Tracker 1off at any time hold the device button for 5 ...Reset Time and then sync your band to reset the time and band counters.
[PDF]User Manual in English (pdf)
www.polar.com/e_manuals/Loop/Polar.../manual.pdf
Polar ElectroThe big picture: Polar Loop activity tracker, Polar Flow web service, and Polar Flow mobile app. .... tracker you'll first need to change time on your computer.
Jan 01, 2016 | Fitbit Charge HR Heart Rate and Activity...
How do I get speaker to work with Samsung S5 with good sound quality
Be sure JBL is charged, press the power button on JBL, press the Bluetooth button on JBL. Turn on your phones bluetooth,make it visible to all devices, make it search for aplliances. When it finds JBL - pair it (you may have to make up a pairin number). The "sun" button controls different sound qualities. And turn the volume up! You should download the JBL MUSIC FLOW APP from the APP STORE to make the most of it.
Feb 19, 2015 | JBL Pulse Portable Bluetooth Speaker
My iPhone 5 will not pair with a Bluetooth device
First switch off and switch on,both phone and Sena,switch on BT on the phone.Switch on BT on Sena.Give search on both the devices.As soon the BTs are detected give connect.It will work.
Oct 04, 2014 | Apple iPhone Cell Phones
Trying to pair KeyStone DAB app to 3 Android ZTE-Racer. All i get is 'Pairing rejected by Bluetooth device'. when I put the pass code in!
It works with KeyStone's DAB-Bluetooth modules which are not yet in production until Q4 this year.
Jul 07, 2011 | Cell Phones
I have a nokia 2730. but the bluetooth is not working properly. whenever i tried it shows "sending failed" to any other mobile.
Hi,for the blue tooth to work, first you will have to pair the device you want to use with it. Without pairing the device it will work.
When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 25, 2010 | Nokia 2730 Cell Phone
Im trying to set up my blue tooth to work on my ps3 but no signal is found what am i doing wrong?
You need to pair your PS3 with your bluetooth headset.
  1. Turn on your PS3's bluetooth and search for bluetooth devices.
  2. While the PS3 is searching and the BT headset is off, press and hold the call/end button on the bluetooth headset until it's light glows steadily. Do not let go until the PS3 finds it.
  3. Pair the devices and allow the BT headset to connect automatically.
  4. To connect, press and hold call/end button on BT headset like the one in step 2.
Oct 25, 2009 | Samsung WEP410 Bluetooth Headset Wireless...
I have a problem with my bluetooth headset h500 pairing it?
The Blackberry Pearl was designed to work with 2.0 model bluetooth handsfree headsets. Whereas the Motorola H500 is compatible with 1.1 - 1.2 bluetooth apps only. I'm guessing you will have to dish out the cash on this one, sorry!
Jan 14, 2009 | Cell Phones
Cell Phones Logo
57 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
