Question about Sportcraft Exercise & Fitness
Which silicone lube should I use for a sportcraft TX455?
    Top Expert:
  • 79,077 Answers
Spray Silicone.
Posted on Apr 21, 2017
Does this norditrack use wax or silicone lube
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
I am assuming you have never waxed your machine before. If this is the case, you should be safe using the liquid silicone lube. When this becomes an issue is if you were using the powder wax and tried to change to a silicone liquid. It would still work, but you would, more than likely, end up with some wax build up on your rollers.
How to Lubricate Treadmill Using Liquid Lube Video
Jan 05, 2016 | Exercise & Fitness
Tx200 sportcraft treadmill
Grainger usually has the best products at a reasonable price
Item # 44N745
Silicone Aerosol, Container Type Aerosol can, Size 11 oz., Temp. Range -40 Degrees F to 500 Degrees FVOC Content 55 Percent, Specific Gravity 0.72O-rings
Oct 15, 2013 | Sport & Outdoor - Others
Treadmill speed varies with or w/o load. Belt not loose. Led speed indicator constant.
0ed98914-d0ff-4c07-aa5a-486eca10f03f.gif1) adjust the speed sensor see the diagram, clean the sensor very well, tight the connector very well.
2) LUBE the deck belt with silicone or wax READ your owner manual,
God bless you
Jun 03, 2013 | Sportcraft Tx5.0 Tx 5.0 Rc Treadmill Motor...
Tx 5.o rc sportcraft treadmill varies in speed with or w/o load.
1) adjust the speed sensor, see the diagram attached, test for open or faulty. clean it very well. tight the connector very well
2) LUBE the treadmills very important . do it with silicone or wax. Read your onwer manual for verification.
I have a sportcraft tx 5.0 rc treadmill. My treadmill runs for seven seconds then turns off with a three on the left side of the screen. I read up on this and saw that its an error code 3 meaning issue...
see the video how to lube and proceed according. use silicone or wax.
lube the rollers bearing too.
test the input voltage motor, if there are the motor need repair, see my personal TIPS for motor help
test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram attached
God bless you
Dec 10, 2012 | Exercise & Fitness
What causes my treadmill to slow down when i step on it
1) you need LUBE , with silicone lube, maybe you have a WORN deck belt, and is time to change.
2) LUBE the rollers bearing very well
3) test the bearing from the main motor, and repair too.
God bless you
Nov 11, 2012 | Sportcraft TX 4.9 Model 4041 Walking Belt
My Sportcraft TX-400 Treadmill shuts off after 7 seconds
Dear sIR:
This by lack of LUBE, in your schedule maintenance DECK BELT. maybe the belt is worn.
2) Lube the roller bearing.
3) Align the belt see the diagrams
4) Test the input voltage motor, if there are voltage motor, the motor need repair.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
Now you can RUN the software calibration for diagnose, troubleshooting. See my personal TIPS for HELPs too.
sincerely. God bless you
May 06, 2012 | Sportcraft TX 400 Walking Belt
Belt is slipping and squeaking when walked upon what type of lubricant should be used
Sounds like the motor belt is slipping. Make sure the belt from the motor to front roller pulley is tight.Once you have that adjusted lube and adjust the walk belt. The squeaking is usually from the motor belt. Many treadmills(Proform, Nordictrack for example) use Silicone lube (lube n walk, or silicone With teflon from Lowes works good) Call the manufacturer to make sure it uses a silicone lube.
Nov 23, 2010 | Cadence Exercise & Fitness
Exercise & Fitness Logo
Top Sportcraft Exercise & Fitness Experts
John
Are you a Sportcraft Exercise and Fitnes Expert? Answer questions, earn points and help others
