Question about Sharp Office Equipment & Supplies
Sir I have a sharp ar m236 I want to scanner postion setting what I do first and sceand. .plz help step by step
SOURCE: I Want Printer driver for AR-5316
http://www.sharp.co.za/techweb/drivers/copierdrivers/gdidrivers/gdidrivers_5316-5320.htm
welcome to pattaya thailand
Posted on Apr 15, 2008
SOURCE: driver sharp ar-5220
Driver Sharp AR-5220 Please.
Posted on Dec 05, 2008
  • 990 Answers
SOURCE: sharp AR-M236 Fault U2-40
Hello sir; This error code require reset the procedure as follow;
press "#/p" " . " "clear" " . " then enter 16 press start enter 0 press start again, press "clear all" machine will back to normal.
Posted on Aug 04, 2009
Sharp Tech
  • 63 Answers
SOURCE: driver of the sharp printer AR 5316E for vista 64 bits
Currently Sharp does not have any specific drivers for this model that are compatible with vista. But if you go to www.sharpusa.com under customer support, product downloads. You might try using the AR-M160 drivers. They are practically the same machine. For the model choose model not listed and manually type in AR-M160.
Posted on Oct 17, 2009
  • 3741 Answers
SOURCE: sharp ar-m236 error code H4-21
-H4-21 means: Sub heater lamp abnormally low temperature detection. The setup temperature (about –25°C: Sim 43-1-1) is not reached within the specified time (about 32sec) from turning on the power ON SW. (When the temperature falls below 140°C in the standby mode.)
-Causes:
Sub heater thermistor defect
Sub heater lamp failure
Sub thermostat failure
Control PWB failure
-Check the sub heater lamp blinking with SIM 5-2-2.
When the lamp blinks normally: Check the thermistor and the harness. Check the MCU PWB thermistor input circuit.
When the lamp does not light: Check for disconnection of the heater lamp and thermostat. Check the interlock switch.Check the power PWB and the MCU PWB lamp control circuit.
Clear the display of self-diagnostics with SIM 14.
The H4 errors will not reset by themselves. You must enter service mode to reset this error even if the problem has been repaired. The reset process is outlined below (DO NOT USE ANY OTHER FUNCTIONS IN SERVICE MODE):
Press the following sequence: "#/P" "*" "C" "*"
Type in 1 4
Press start
hit 1 for yes
hit start
Unit should power off and the restart.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Dec 28, 2009
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
AR M236 U9-99
U8-99 error of the target of the operation panel
requiring the intervention of the technician.
Apr 21, 2011 | Sharp AR-5316 Advanced Digital Imager...
Code e7-02 sharp Ar m236
Hi.
that erorr is for SHARP AR405 E7-02 Laser unit problemHere an link
service manual here
Feb 13, 2011 | Sharp AR-235 Copier
I have Sharp copier AR-M236 with error code:f2-04, how can i remove this error?
That error is a bad CRUM. Replace developer unit use only Sharp supplies. The chip on the developer unit doesnt match with the machine.
Aug 22, 2010 | Sharp AR-M237 Copier
Please i need to reset my sharp ar-m236 password how do i do that
You can reset the nic card password by ressetting the nic card to factory defaults, custom setting, key operator, 00000 , print settings , network settings, reset the nic, default password is Sharp
Mar 15, 2010 | Sharp AR-M237 Copier
Driver of the sharp printer AR 5316E for vista 64 bits
Oct 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M236 Fault U2-40
Aug 04, 2009 | Sharp AR-235 Copier
I need to obtain a meter reading for sharp ar-m236. How do I do that?
Simply press and hold the copy mode then you get the meter reading and toner percentage status
Apr 15, 2009 | Sharp AR-235 Copier
How can I inter to s.p program for sharp ar-m236
Basicly there is not a trick to the S.P. mode. You go in to it & touch The S.P. on the display and then turn the main power switch off and then back on and that is that is needed. But if that did not work you will need to go deeper in to the problem.
Dec 16, 2008 | Ricoh Aficio 1035 Copier
22 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
