Question about Hobart Kitchen Ranges
Hobart ml-132055 inexspensive converion to lp from natural gas
  • 1543 Answers
SOURCE: Converting a GE Profile Gas Range from LP to natural gas
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
Posted on Jan 06, 2009
  • 5568 Answers
SOURCE: Want to convert from LP to Natural Gas
Typically, the only thing required is changing any and all jets since energy content and pressure are different. The only source for these is probably the manufacturer; check their website.
Posted on May 20, 2009
  • 512 Answers
SOURCE: Converting Weber from LP to Natural Gas
On the weber model you need to purchase the natural gas model. It will cost you alot more to buy all parts needed to convert. Weber doesnt want you to convert do to safety reasons. This is why they will only tell you you can't convert. Buy the right grill and save yourself a headache.
Posted on Jan 20, 2010
  • 1959 Answers
SOURCE: Can a weber spirit e210 natural gas grill be
Weber sells conversion kits. Basically, you need a new regulator and manifold to accommodate LP instead of the existing regulator/manifold setup for natural gas. Unfortunately, Weber does not sell their parts online. Their parts phone # is: 877-731-8081
Posted on Apr 27, 2011
SOURCE: Conversion kit for Weber Summit LP to Natural Gas
Hi, you can purchase your kit at amazon, click here and take a look: Amazon com weber grill conversion kit to natural gas. I hope this was helpful. Cheers
Posted on Dec 16, 2014
Convert LP Lincoln oven Impinger II series 1700 to natural gas series 1600
Yes. You need a set of natural gas orifices to replace the LP ones on the oven and all the burners too.
Jan 28, 2014 | Ovens
Changing your gas appliance from natural gas to LP or vice versa.
You have an LP gas stove which you really like and would like to take to a new home but the new home has a natural gas hookup. Since natural gas is already available it would be convenient to be able to use it. Can you convert your unit over to work on natural gas?
Yes it is possible to convert any LP gas appliance to natural gas or from natural gas to LP. The only difference is the size of the orifice used in the burner.
LP gas is composed of a much larger molecule than natural gas and requires a larger orifice to output the same amount of gas as a natural gas unit at the same setting. Therefore if you used an LP stove on natural gas it would produce too much heat and burn rather intensely. If you used a natural gas stove on LP it would not have much flame at all. You can see the problem. The solution is also obvious. You need the correct orifice.
Changing the orifice is easy. It is located in the middle of the burner and unscrews out of the unit. Install the new one the opposite way. Do not overtighten it.Usually the burners are made of soft metal and can strip easily.
The parts you would need are available at most good appliance stores but I would recommend the following site . The parts will be cheaper at repairclinic. They have parts for almost any brand and a great search engine. They also have excellent videos showing how to make the repair.
Thanks for using FixYa and for the great rating.
on Dec 10, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
How do I convert from liquid propane to natural gas
You need parts from the manufacturer. The gas orifices are different sizes between natural gas and LP gas. If you try natural gas with an LP gas orifice, you will not get much flame. If you use LP gas with a natural gas orifice, you will burn off your eyebrows and possibly other things.
Dec 19, 2013 | Capital Cooking Titanium X CCE26XRBI (NG)...
Model# BWH30NLTB
Unit goes under sure heat name also.
My unit emitted unburnt gas smell the minute pilot started,
and was annoying during burner operation.
I discovered they built unit with primary pilot that had 2 ports.
They used LP and sealed off natural gas,instead turning lp/nat
knob on back activates second pilot for natural gas use.
This means natural gas goes thru LP pilot orifice and burns
slightly off during normal natural gas use(by design).
The unused natural gas orifice has 1 air mix hole and the LP orifice
has 2 air mix holes.
I carefully plugged 1 of the holes in the LP orifice and suddenly
pilot gas flame seated correctly on orifice port.Gone was the
unburnt odor of natural gas.
The typical flame in a flame appearance now was exhibited by
the small pilot,secondary pilot remained consistent with manual
Of course, to use with LP I would have to open blocked air mix
hole in addition to the other changes per manual.
Hope this helps someone with similar condition.
Dec 31, 2012 | Reddy Heating & Cooling
I have a new PinnacleTG560N natural gas BBQ and I want to convert it to propane, what can I do, or can I get a converion kit to make this work.
Unfortunately, there's nothing you can do. According to Weber, there are no conversion kits, as your grill is not convertible to propane. Like wise, a Weber propane grill is not convertible to natural gas.
Link to your Owners Manual (see page 2 - Warnings):
Apr 28, 2011 | Weber Spirit? E-310 Propane Grill
Converion kit to natural gas.
I don't believe Weber makes a gas conversion kit for your model grill. I say this, because your model grill comes two ways, Natural Gas or Propane. This indicates to me, that there's more than just changing the burner orifices involved.
I can tell you this ... If you could convert it to Natural Gas, you would soon discover that the grill doesn't preheat as fast as with propane. Nor, will it maintain heat as well as propane, in an outdoor environment. Propane burns cleaner and hotter than Natural Gas in an outdoor environment.
Sure, it may seem like a hassle to refill and change the tank, but I can assure you, you won't be satisfied with it's performance.
Feb 03, 2011 | Weber Spirit? E-310 Propane Grill
Jan 06, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Change hobart gfo53a deep fryer natural to lp gas
The orifice is not adjustable but there is a small air sheild around it that is held in place with 1 screw and needs only to be adjusted if the flame is not of a blue color (starting to get a yellow or orange color in it).
Nov 28, 2008 | Hobart Kitchen Appliances - Others
Converting a range from LP to Natural gas
Yes, it is possible.
You have to get the right orifice's for Natural gas. LP gas orifice has twice the size hole as compared to Natural Gas. Using it without the right orifice will put out way too much gas, and you will burn everything, as well as it will be a fire hazard.
Your local gas company or propane company should be able to get you the right orifice
Please rate this solution.
Jul 31, 2008 | Jenn-Air ® 48" Professional Over The...
Need to install LP converion kit How do I get to the inside of dryer
To convert a gas dryer to lpg. Undo door hinge screws, lift door and hinges, door should come off. opposite side of door opening remove 2 screws opposite form door hing side. Now the front panel will pull off front the top. Ease the top out and the bottom is just sat in two hooks and will lift out. Now your are in.
Nov 05, 2007 | Maytag Neptune MAH5500B Front Load Washer
Kitchen Ranges Logo
27 people viewed this question
Top Hobart Kitchen Ranges Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Hobart Kitchen Range Expert? Answer questions, earn points and help others
