Question about Kettler Exercise & Fitness
How do I replace the pull cord on a Kettler Coach LS Rowing Machine?
3 Suggested Answers
  • 3 Answers
SOURCE: Slack in line on rowing machine
extend the line to its max required length while you are sitting on the machine { as using } then get someone else to adjust the slack on the line and make it taught , the adjustment should be a bolt and nut type located on the main wheel . do not adjust the line from the seat as this may dislodge the seat . happy rowing
Posted on May 06, 2009
maxtreadmill
  • 832 Answers
SOURCE: Kettler Model Kinetic S3 Rowing Machine rope snap want spare rope
KETTLER® USA 1355 London Bridge Rd Virginia Beach, VA 23453 USA
Phone # 757.427.2400 Fax# 757.427.0183 e:mail:info@kettlerusa.com
Posted on Mar 02, 2010
Loss of tension for a kettle coach rowing machine
The fly wheel has a 'freewheel' mechanism similar to the rear wheel on a bicycle. It needs cleaning and regreasing with light grease to free it up and make it work properly. The job is not difficult but needs some diy knowledge. Before trying to remove the fly wheel some slack will need to be created on the 'bungee' return cord and anchored securely. You will also require circlip pliers to remove the shaft. The freewheel mechanism is a set of needle bearings that move forward in their recess to allow the wheel to rotate and move back and lock when the wheel rotates in the opposite direction. These need to be free moving and old grease thickens and becomes sticky. Clean with something like GT 85 and regrease with a light grease.
Dec 29, 2013 | Kettler Coach Rowing Machine
Kettler Treadmill Sven
http://www.ehow.com/how_5973977_care-kettler-coach-rowing-machine.html
see this web page in relation to your questions
sincerely. God bless you
Apr 30, 2012 | Kettler Exercise & Fitness
Hi, I have a kettler coach ls rower and was wondering why it jitters when i row. You can feel and hear the rope on the wheel like its grinding or something. Thanks
The rower keeps going slack. i wind it back up and after about 3-5 rows it clicks and goes slack again. any suggestions??
Aug 27, 2011 | Kettler Exercise & Fitness
Feb 15, 2010 | Kettler Rowing Machine Kadett Rowing...
How do I clear the odometer....the manual does not specify...
I have the Coach LS Rower (not programmabe). I removed the battery and this reset the odometer to 0. Hope this helps. Not sure if the programmable model is the same or not.
Feb 01, 2010 | Kettler Coach LS Programmable Rower
Cable breaks every 10 -15 times I row. Could I buy another recommended cable with instructions for fitting correctly?
Is it the bungee that breaks? If so, you can absolutely replace that if you call the manufacturer.
You will know that the bungee is breaking if you pull on the cord and receive no resistance, or if the cable does not reel itself in.
If it is the actual cable connecting to your handle, there is much larger issue with your machine, and a new cable is not going to help. You should look into repairing the whole system.
Oct 26, 2009 | Kettler Coach Rowing Machine
Cord seems to be slipping off the flywheel; I pull and the cord goes slack, spools out much more than is needed, and when it retracts (basically from my stopping the pull and slowly letting it reel itself...
You have a bungee problem, your bungees broke. You can easily order new bungees from your manufacturer. They are also easy to replace once you take off the side of the fan.
Jul 15, 2009 | Kettler Coach Rowing Machine
May 06, 2009 | Kettler Coach Rowing Machine
Exercise & Fitness Logo
89 people viewed this question
Top Kettler Exercise & Fitness Experts
Jim London
Jim London
ray gallant
Steven Brandon
Steven Brandon
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
