Question about Maytag MGR6772BDS Gemini Gas Kitchen Range
Control panel touch pad will not respond because of exposure to extreme heat from stove top fire. When it was working the larger lower oven took hours to heat up, if it did at all. trebor46385@yahoo.com Robert
  • 36 Answers
The touch pad is part of the main control and that is what you will need. the real problem will be the price of the repair.but this might solve your original heating problem.
Posted on Jul 24, 2009
My stove top does not respond to the touch
Good Morning Kenneth Kozoway, thank you for your inquiry!
I see that you have explained the stove top on your Electrolux range is not responding to touch and the oven controls are working properly. From what you have described it sounds like a possible issue with your control panel or sensor. I would suggest performing a reset on your range and you can do that by disconnecting the power from it for ten minutes. If that does not help correct the issue I would recommend having a professional technician come and perform a proper diagnosis for repair. Hope this is helpful. -Matt
Dec 25, 2014 | Electrolux 30" Self-Cleaning Slide-In...
CAN NOT CONTROL BOTTOM OVEN
I assume yiu had the electronic oven control repaired. Sometimes the touch pad also goes bad. I have had to replace them at the same time. If the oven indicator lights showing the oven being on shows up on the display it could be that the thermal fuse behind the oven has gone out. this in in the common line and will shut down both ovens at the same time but you will get the control panel to respond to the touch pad.
Nov 23, 2013 | Whirlpool RBD305PDS Electric Double Oven
I have a Kenmore Wall electric oven unit that the heat element at the top is working only and F2 is what comes up and continues to beep. The heat is extreme. WE are wondering if we should just get a new...
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 19, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Maytag MER5730ACW Stove.F3 fault code.
hello there
Please go thru this list of the fault codes for this appliance it will tell lyou what to do for the fault or what part needs to be replaced
MAYTAG FAULT CODES
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components. Find Parts clear.gif
Jan 13, 2010 | Maytag MER5730 Electric Kitchen Range
Stove control panel not working
You do not have a fuse or overload button on a Maytag cook-top. If you heard a pop, it was the touch pad on your control board blowing out.
Oct 22, 2009 | Kitchen Ranges
Jenn Air slide in range JES9750AAB - Touch Pad
put on tree belt . having the same problems replaced ERC $200.00 now they are telling me touch pad touch pad is $240.00 .the stove cost $1300.00. $1740.00 how much more will i have to put in this stove
Aug 02, 2008 | Jenn-Air JES9800A Electric Kitchen Range
The touch pad panel on stove is blank
on the ge range, you need an ERC its the main control for the oven. yes its costly. comes in a kit with a new wire harness
Nov 16, 2007 | GE Profile JGSP48 Gas Kitchen Range
JGBP79 GE Spectra XL44
Yes I had the same problem on my JGBBP79. Change the lower igniter. About $75. Keep the range for a few more years and get rid of it. The next problem you'll mostly likely have is the touch pad F1 error. That stupid thing is +$300 and nothing more than a membrane touch pad attached to some glass. :-(
Nov 08, 2007 | GE Profile Spectra JGBP79 Gas Kitchen...
Maytag MGR6772BDS Gemini Gas Kitchen Range Logo
408 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
