Question about Optoma Office Equipment & Supplies
I need an Optoma pk320 power lead replacement, optoma uk sell them at 40 pounds, any cheaper alternative
Marrie
  • 563 Answers
SOURCE: Optoma DV10 MovieTime Color Wheel replacement
Hi guys
Your best bet on getting your hands on a Service Manual would be to contact Optoma themself.
As for changing the colour wheel , it is pretty straight forward if you were able to open up the unit and get to it.
The colourwheel is mounted with three tiny scrws to a bracket in which it sits. And the bracket in it's turn is fastenend to the body of the Projector with two tiny screws.
First unscrew the bracket from the casing of the Projector and then take off the three screws that holds the Colour wheel to the bracket. Replace and do the whole proses again - but obviously just the other way round.
This is really easy to do yourself.
Give me a shout if you need any further assistance.
Thanks for using Fixya and good luck.
Posted on May 07, 2008
SOURCE: optoma ep739 won't power up
The lamp cover has a disconnect that won't allow power while the cover is off. Sometimes the piece of metal gets bent out of place.
Try removing the cover for the lamp, and bending the little piece of metal forward.
It worked for me!!!!
Posted on Nov 27, 2008
  • 4 Answers
SOURCE: Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Posted on Mar 10, 2009
SOURCE: optoma hd70 starts flashing colors
I removed the front cover and top panel, Using the Radio Shack dust removing spray, removed all dust from interior including circuit boards, color wheel ect, now it,s operating like a new projector.
Posted on Jan 04, 2010
SOURCE: Optoma DV10 color wheel
Okay, I recently had a loud noise coming from my projector and found online meterial stating that the colour wheel had been damaged. So with a bit of guts I managed to open the projector and found the colour wheel missing a segment.
I removed the colour wheel and the broken piece of the segement and tried to contact Optoma. Optoma turned round and said they cannot sell me the the colour wheel, which got me very upset. Some people claim online that Optoma will sell you the part on a back order at £50. (if you can be a little specific on how you managed to convince them to sell you the part, would be great).
The only option I had available was to send my project to them and they would repair for an estimated cost of £125+VAT. Guess what, you can buy the entire projector off ebay for 150quid!!!
Anyways after fiddling around quite a big online I got fedup and decided to glue the broken segment together and it SOLVED the loud vibration problem. I have colour and picture.
Becareful not to tighten the colour wheel screw too tight orelse it will break another piece of segement (Like I did).
Here are instructions on how to open up the projector.
http://www.geekfest.info/DV10/dv10.html
I cannot guarantee this will work for you as it depends on how badly you have shattered the colour wheel segment, so do at your own risk. I had two piece of the segment broken and a third by tightening the colour wheel screw too tight.
This will work for awhile but the colour wheel does need replaceing one day. If anyone can tell me how you can get Optoma to sell you the colour wheel would be great.
Best of Luck
Posted on Feb 06, 2010
Optoma ex550 / es550: I need the service menu code for an optoma ex550? I need to adjust my color wheel index. Alternatively the full service manual or access to easp.optomausa
If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs and other devices are given.
Jul 06, 2016 | Optoma Office Equipment & Supplies
Why is HDMI input not working?
Apparently, HDMI cables can be finicky. You may have to try different ones to find something the projector "likes".
Sep 01, 2015 | Optoma Pk320 Pk320 Pico Pocket Projector
I have a Optoma EP721. It now projects verticle lines on the screen background. How do you eliminate the verticle lines ?
It sounds like you have a projector which is in need of professional repair. You should eliminate source material problems first though by checking the projector with alternative input sources, ensuring that you also check the cables, and various inputs on the projector.
If the lines are present on all the inputs then the fault is internal to the projector. This will require professional repair. The first point of contact should be Optoma at www.optoma.co.uk/support.aspx (UK) or http://www.optomausa.com/ (USA). They should be able to give you an idea of ow much it may potentially cost to have your projector repaired and (most importantly) check whether it is under warranty. Most Optoma projectors ship with 3 year warranties these days.
Feb 19, 2011 | Optoma EP721 Projector
Where do i find the ballast unit, both inside my projector and for sale?
In the optoma hd-81 there is a lamp unit housing.It goes faulty the lamp unit housing .There is no ballast in the hd-81 projector.There is lens ,the lamp unit housing and the circuit board.In most of the cases the lamp unit housing goes faulty.In that case the lamp housing needs to be replaced.It can be replaced and replacement lamp is also available. -------------------- Buying original lamp is always advisable.But there is compatible lamp also available.The original lamp housing is costly and compatible housing is bit cheaper.In some rare cases the compatible lamp does not work.But the compatible lamps also are good. To buy original lamp.Click this link directly:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/Optoma+Technology+Inc/Optoma/BLFS300B/New.aspx ------------ this is link for compatible cheaper lamp.Click this link:-- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx --------------- The procedure to replace the lamp:--- to get this procedure.Please click on the link below:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx ------------ this link is for the user manual of optoma hd-81 and the procedure to replace lamp is mentioned on page number 59.Please read the instructions before replacing lamp.----------- This will help.Thanks.Helpmech.
Feb 03, 2011 | Optoma HD81 DLP Projector
I cannot get my EZ PRO 500 CTX projector to show a full screen picture from an XP or Vista PC. I lose part of the left and bottom.
dous anybody know how mush these r worth,as i have 1 to sell,my e-mail address is cottageinn@live.co.uk its in a case with power lead and remote,its powers on-with picture...simon
Nov 19, 2008 | CTX Optoma EzPro 500 Multimedia Projector
Optoma RD65 Service manual
Did you ever find the service manual for your RD65. I am also looking for a service manual, Optoma will not provide the manual. This TV is out of production due to all the problems with it, you would think they would help out those of us that had faith in their product and spent our hard earned money. Optoma's Tech support and customer service is terrible. If you have the service manual I would be willing to pay for a copy. Email me at waltlevick@comcast.net
Nov 03, 2008 | Optoma RD65 65" Rear Projection HDTV
Best of Luck
Aug 08, 2008 | Optoma MovieTime DV10 Multimedia Projector
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
