Question about Bosch Washing Machines
Put new bulb in oven 15watt should be 40 light not working is it because it is wrong wattage
It is Bosch make
  • Chris freeman
    Chris freeman May 16, 2017
    Check new and old bulb side by side some times as you have 40w not15w the thread is same but the shoulders a are different by fraction and doesn't make contact hope this helps
  • Bosch Master
  • 16,608 Answers
  • Nope, the wattage has nothing to do with whether or not it works UNLESS you are using LED bulbs. LED bulbs are not allowed in a stove interior application. There is something wrong with the socket, the wiring or the switch.
Posted on Apr 21, 2017
Testimonial: "Thanks for that"
What size bulb goes in the oven
Seems that regular bulbs really don't like the high heat or getting splattered with cooking juices, shatter at the first contact with liquid. Think you better spend the couple of extra $$$ and not have to clean up a shattered glass mess in your oven.
The GE Reveal 40-Watt Appliance A15 Light Bulbuses neodymium glass to filter out dull yellow rays for enhanced, vivid results. The bulb is an ideal choice for use in household appliances like microwaves, refrigerators and ovens.
Light output: 320 lumens Energy used: 40 watts Life hours: 1,000 hours Ideal for use in many household appliances such as microwaves, refrigerators and ovens Unique neodymium glass filters out the dull, yellow rays of regular soft white bulbs for enhanced, vivid results
Nov 17, 2014 | Cars & Trucks
Wattage limiter hunter ceiling fan
As per the Energy Policy Act of 2005, all ceiling fans manufactured or imported into the United States must utilize a light bulb wattage limiter as of January 1, 2007. This limiter limits the capacity of the fan's light kit to a maximum of 40 watts per bulb. Not very bright at all!
Put in LED lamps and save a lot of work. Go to: http://www.youtube.com/watch?v=7WeWSKNe64A it will show you how.
Oct 18, 2013 | Hunter Ceiling Fan Light Switch Control
Newly installed Hunter remote will work light and fan if only 2 of the 3 bulbs are installed.
Did you install the correct wattage? If you put in 2-60 watt try 3-40 watt instead .
Dec 30, 2012 | Hunter 52" Ceiling Fan With Light And...
Correct wattage bulb in Simpson La Scala electric oven.
if you are refering to the light inside the oven, I dont think there is a problem with wattage as the oven is rates to high wattage
and it is also inside the oven, so in an area that can cope with heat.
if possible check remove the old bulb and check the wattage on the glass or on the side of the fitting.
I personally would recommend that a 40W should be suitable.
I hope this was useful
May 23, 2011 | Ovens
Replace light bulb
Hello. Unscrew the bad bulb. It unscrews in a counter clockwise fashion. Get a new oven bulb, of the same wattage at home depot or most hardware stores. J.
Jun 26, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Sharp Carousel Microwave work light/night light has two light bulbs. One light will turn off by pressing the panel control, but the other light remains on. Must remove light from socket in order for the...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jan 29, 2010 | Sharp R-1610 Microwave Oven
Surface and night light bulbs
If the model number you have this listed under is correct, the bulb you need is part #AP2029997, made by GE. You can also purchase these bulbs at any hardware store. They are the half sized small base, 40 watt bulbs. If you can't find 40 watt, make sure you use a lower wattage rating. If you have questions, or if the model number is incorrect, please let me know. I hope this helps you.
May 04, 2009 | GE JVM1650 1000 Watts Microwave Oven
I have a Bosch double oven and the light is out and how do I get the cover off to replace the bulb?
To change the light you need to unsreew lt lens then pul the bulb straight out to you. then reverse the steps to put back together.
Dec 17, 2008 | Bosch HBL 5056 Electric Double Oven
Oven lights
i don't know your brand but ive read service bulletins on bad light sockets in ranges id try another bulb first then replace the socket
Feb 13, 2008 | KitchenAid KEBC107 Electric Single Oven
Washing Machines Logo
176 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
