Question about Cell Phones
To unlock my pin code message which I am unable to clear and when i phone your call centre the recording is so soft and unclear that I cannot follow the instructions
Benimur
  • 6966 Answers
SOURCE: Recording to Cassette
Most Audio Shelf System follow the same procedures for recording. You need to select your source as if you will just be listening, AM, FM, Aux etc. Thereafter, you need to press Record (sometimes with PLAY) to start the recording. Normally, it will record whatever source is playing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 23, 2008
  • 214 Answers
SOURCE: error messages
I can't help directly but if you go here to the (Australian) support site
http://www.brother.com.au/customersupport/customersupport.asp
you may find your answer.
Note You may need to contact them direct to get your answer.
Good luck.
Posted on May 11, 2008
SOURCE: RCA 25205 Visys will not record message
Called the company. There is a misprint in the instructions.
In the section titled "Out-Going Announcement RECORD" on last step it says Press Exit to stop recording. It should have said Press Sel/Save.
I did this and it worked.
Repeat for Line 2 if you are doing both lines.
Next thing is to make sure you go right to the section titled "Configure Out-Going Announcement" and select the right type of message you want callers to hear for each line.
Worked like a charm and took 3 seconds to get 2 different personal messages on the machine.
Posted on Oct 21, 2008
SOURCE: Panasonic phone KX-TG2740: instructions
I downloaded the instruction manual, based on someone else's solution to a different question about the same product.
Posted on Dec 17, 2008
M2Tech1
  • 313 Answers
SOURCE: error code SC542, unable to clear message from
this is an error for the fuser heat up..the temp is not being maintained or fluctuations. try this press the yellow clear button at top of number pad then enter 107 and hold down the red cancel button..the screen will change enter the copier sp and select 5.mode arrow down to 5-810 sc reset and execute.turn machine off.. if the code disappears it could have been just a glitch if not check the fuser to see if there is heat coming from it the lamps will come on at te start up. you can check this by putting a screw driver in the actuator slot to cheat the door switch if you see the lamp come on then you may just have to clean off the thermistors .. open the fuser up with the top screws and check that there isnt any build up of toner on thermistors..hope this helps good luck A
Posted on Jun 12, 2009
What is the unlocking code for a Kyocera Hydro Life..model #6035?
Resetting the phone If the phone does not respond to taps or key presses with the flip either
open or closed, you may need to perform a reset.
There are two types of resets-soft resets and hard resets. In a soft reset,
all records and entries are saved. In a hard reset, all records and entries
are erased. If you must do a hard reset, you can restore any data that you
previously synchronized using a HotSync operation.
To perform a soft reset
May be either on or off
Open
1. Turn the Kyocera smartphone over. Open
the battery door on the back of the phone.
2. Press the reset button with the stylus.
3. Replace the battery door. Turn the phone
back over and verify that it has restarted.
Feb 02, 2015 | Kyocera Cell Phones
Screen locked and unable to unlock
Turn off . Press and hold POWER + ENTER button for reset menu.
Select
Factory reset with Volume Down button and press Power to reset. All data will be lost! there is an alternate method too friend
Use this method to hard reset your Samsung GT-S Galaxy mini phone: Enter *2767*3855#. Warning! All your data including contacts, messages etc. will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM or make backup to your PC before full reset! Take out SIM card before full reset.
Samsung GT-S5570 Galaxy mini download mode if you want to install eg. Gingerbread
Press and hold Volume DOWN + HOME + POWER ON S5570
Restart your device to clear any temporary software bugs
If you know the hard reset with buttons / keys, pls leave a comment. All comments are welcome!
Your device freezes or has fatal errors
If your device freezes or hangs, you may need to close programs or reset the device to regain functionality. If your device is frozen and unresponsive, press and hold [Power] for 8-10 seconds. The device will reboot automatically.
If this does not solve the problem, perform a factory data reset. In Idle mode, open the application list and select Settings :Privacy
:Factory data reset :Reset phone : Erase everything.
Clear storage• : Erase the credential contents from the device and reset the password
Set an unlock pattern
Once you set a screen lock, your device will require an unlock code each time you turn it on or unlock the touch screen
Settings Location and security Set screen lock : Pattern
If you forget your PIN or password, bring your device to a Samsung Service Centre to reset it.
Set an unlock PIN code
Settings Location and security :: Set screen lock : PIN
Set an unlock password
Settings Location and security :Set screen lock : Password.
You can hard reset software firmware update your Samsung GT-s Galaxy mini phone
Hope it helps u
Dec 08, 2013 | Samsung Cell Phones
Forgot unlock code voicemail kyocera jax
Go to this link...
http://www.virginmobileusa.com/resources/phones/prepaid/manual/kyocera-aw-jax.pdf
DOWNLOAD THE MANUAL FOR FUTURE REFERENCE!! LOL
Scroll down to page #39 to where it says Use Voicemail and follow the instructions!! As per the service tech I spoke to on the phone to find this link, following these instructions will automatically erase your old voicemail unlock code as well as any as yet unheard messages.
Just in case anyone still has difficulty in finding the instructions.....
Set Up your VoicemailBefore your phone can receive voicemail messages, you must set up a 4-10 digit passcode and record a personal voicemail greeting.When you have set up your voicemail, all unanswered calls to your phone are automatically transferred to voicemail, even if your phone is in use or turned off.1. Press and hold the 1 key.2. Follow the system prompts to create a password and record a greeting.
Check your Voicemail
When you receive a voicemail message, a
notification with a voicemail message icon
appears at the top of your screen.
• At the voicemail notification, select Call to call
your voicemail number and follow the system
prompts to retrieve the message.
Select Ignore to clear the notification without
checking messages. The notification icon
remains on top of the screen until you listen to
the message
• When only the voicemail message icon
appears on top of the screen, select
Voicemailand follow the system prompts
Best of luck!!
Susan
Jan 27, 2012 | Kyocera Jax Cell Phone
Unable 2 send message in my nokia 3230....
Hi
You can not send messages because the message centre number stored in your mobile may be wrong.
Please enter the correct message centre number.To get the correct message centre number please call your service provider and they will provide you the number.
To entre the message centre number please follow the steps below
Menu > Messaging >Options >Settings > Text message >Message centres
Thank you
Aug 09, 2010 | Nokia 3230 Cellular Phone
Unable to send text messages
pls go to message centre under the message settings and see if the message centre code is given in there or niot
Apr 20, 2010 | Samsung SGH-i8510 INNOV8 Cell Phone
No gsm
check its imei *# 06# if it is start00 it may work by cdma if it start with 35 it may be gsm.visit any unlock centre ask for country unlock code.
Apr 09, 2010 | i-mate JasJam Smartphone
6720 unable to change message centre
Nokia 6720 has my husbands mobile number in the Message Centre - I have tried to change it but it comes up with Unable to change setting . value read from sim card - HELP I cant send text messages but can recieve them
Mar 01, 2010 | Nokia 6720 Classic Cell Phone
Code to retrieve messages
Here are the instructions you need to follow:
If you want to be able to play your messages from a remote location, you need to enter a two-digit Personal Identification Number (PIN) code (01-99).
To select a PIN, perform the following steps:
1) With the phone in standby, press [menu/clock] twice.
The system announces "Security code," and the current PIN code is announced as it is displayed on the base.
Then the system announces the instructions for setting the PIN code.
2) Press [volume/select/ ] or [volume/select/ ] until the desired number appears.
3) Press [set] to select the PIN code. You hear a confirmation tone, then the announcement "Security code" followed by the new PIN code is announced. After a few seconds, the system announces "To set ring time, press menu again."
Note: The PIN code is set to "80" at the factory.
Remote Operation
When you are away from home, you can operate your answering machine with any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even record a new greeting message.
1) Call your telephone number.
2) During the greeting message, press [0] and enter your PIN code
3) The answering machine announces the current time and the number of messages stored in memory. Then you hear "To play incoming message, press zero two. For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command from the following chart:
Command Function Command Function
[0] then [1] Repeat a Message [0] then [6] Answering Machine On
[0] then [2] Play Incoming Messages [0] then [7] Memo Record/Stop*
[0] then [3] Skip a Message [0] then [8] Greeting Message Record/Stop*
[0] then [4] Delete a Message [0] then [9] Answering Machine Off
[0] then [5] Stop Operation [1] then [0] Voice Prompts
* For Memo Record and Greeting Message Record functions, the first time you enter the corresponding command, it
starts the Recording function. If you want to stop the recording, enter the command again.
Note: Once you enter the remote access menu, you must enter a command within 15 seconds, or the
answering machine automatically hangs up and returns to standby.
5) After all of the voice prompts have been played, you hear intermittent beeps indicating that the system is in the
command waiting mode. You may enter another command at this time from the chart.
6) When you are finished, hang up to exit the system. The answering machine automatically returns to standby.
Turn on the Answering Machine Remotely
If you have forgotten to turn on your answering machine, you can turn it on remotely from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press [0] and then enter your PIN code. The answering machine announces the number of messages stored in memory. You hear "To play incoming message, press zero two. For help, press one zero."
4) Press [0] then [6] to turn the answering machine On. You hear the outgoing message and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Feb 28, 2010 | Uniden EXAI5680 Cordless Phone
Lost my manual and cannot remember how to get messages remotely
Since I have not idea what exact model you have this may or may not work... I hope it helps, as it is for a Uniden answering service phone.
Remotely Operating Your Answering Machine
Note: The answering machine will only playback messages for four minutes and then it returns to the command waiting mode.
To continue playing your messages, press [#] then [2] again within 15 seconds.
To operate from a remote location, use any touch-tone telephone and follow these steps:
1.) Call your telephone number and wait for the answering machine to answer
2.) During the greeting message, press [#] and enter your PIN code within 2 seconds;
How to enter a PIN
To play your messages from a remote location, you will need to enter a two-digit Personal Identification Number (PIN) or PIN Code.
Press the MENU soft key. Select the ANSW. SETUP menu, and then the SECURITY CODE submenu.
Enter a two-digit security code (00-99) using the number keypad [0-9].
Press the OK soft. You will hear a confirmation tone.
You hear "To play incoming messages, press pound-two. For help, press pound-zero." You will hear a beep.
Enter a remote command within 15 seconds, each command there after must be entered within 2 seconds. You may select a command from the following:
# then 1 Repeat a Message
# then 2 Playback Messages
# then 3 Skipping a Message
# then 4 Deleting a Message
# then 5 Stop Operation
* # then 6 Answering Machine On
# then 7 Memo Record/Stop**
# then 8 Greeting Record/Stop**
# then 9 Answer Machine Off
# then 0 Help Guidance
Apr 27, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Picking up messages remotely
Try this...
See if this works for you.
Remote Operation
When you are away from home, you can operate your answering system with any
touch-tone telephone.Use this function to check for recorded messages, to play or
2) During the greeting message, press 0 and enter your PIN code.
3) The answering system announces the current time and the number of messages
Command Function
0 then 1 Repeat a Message
0 then 2 Play Incoming Messages
0 then 3 Skip a Message
0 then 4 Delete a Message
0 then 5 Stop Operation
0 then 6 Answering System On
0 then 7 Memo Record/Stop*
0 then 8 Greeting Message Record/Stop*
0 then 9 Answering System Off
1 then 0 Voice Prompts
If you forgot to turn on answering system the directions for that are here:
Turn on the Answering System Remotely
If you have forgotten to turn on your answering system, you can turn it on remotely
3) Press 0 and then enter your PIN code. The answering system announces the
4) Press 0 then 6 to turn the answering system On. You hear the outgoing message
Dec 12, 2008 | GE 25942GE2 Cordless Phone System
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
