I would like to take out a 10 ft section of interior supporting wall. I am curious what size beam I will need? Right now, there is normal size walkway through the wall. The kitchen on one side of wall is 14x14 and other room on other side is also 14x14. The wall I'm trying to remove is on main floor. There is a full basement below. In the basement, right below wall I'd like to remove, is what appears to be an i-beam. There is also a second floor above the wall that has a bathroom and bedroom above it. And the roof above that. I live in Chambersburg, Pa.
  • 17,162 Answers
Http://home.howstuffworks.com/home-improvement/construction/projects/remove-load-bearing-wall.htm
There is a lot on youtube about this. Also you should be aware that this requires a building permit.
Posted on Apr 21, 2017
Need to span a LVL beam 14ft. with only 2x6 joists to carry and no other loads on a interior wall< so I can open up a wall
Hi Dave:
Cars & trucks section so you may not get many answers.
I'm a retired Building Inspector so have a general idea of what you are talking about.
There are several variables that come into consideration.....
- Supported joist length
- Load on those joists
- You'll find the required beam size in the appropriate tables.
Your local Building Inspector should be able to assist you.
Cheers
Mar 28, 2016 | Cars & Trucks
I need to replace microwave and don't know what size in cubic feet?
Multiply interior's height x width x depth. Ex: lets say 10 inches x 12 inches x 8 inches = 10 x 12 = 120 x 8 = 960. Divide 960 by 1728 (12 x 12 x 12) =. 56 cubic ft( point 56) just a tad more then half cubic ft.
Nov 28, 2014 | In Microwave Ovens
Fuse box layout for 2005 honda crv
No. Amps Circuits Protected 1
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38 7.5
15
10
7.5
(15)
(20)
_
10
7.5
7.5
10
10
10
7.5
7.5
10
10
20
15
7.5
20
_
_
(20)
20
20
(20)
15
15
20
(15)
20
20
7.5
7.5
10
7.5
30 Power Window Relay
Fuel Pump
ACG
ABS/VSA
Heated Seats*
Front Fog Lights*
Not used
Rear Wiper
ODS (Occupant Detection System)
Meter
SRS
Right Headlight High Beam
Left Headlight High Beam
Small Light (Interior)
Small Light (Exterior)
Right Headlight Low Beam
Left Headlight Low Beam
Main Headlight High Beam
Small Lights MAIN
TPMS
Headlight Low Beam
Not used
Not used
Moonroof*
Door Lock
Front Left Power Window
HAC Option
Rear Accessory Socket
Accessory
Front Right Power Window
Accessory Power Socket on the Center Table*
Rear Right Power Window
Rear Left power window
ACC Radio
ACC Key lock
HAC
Daytime Running Lights
Front Wiper * If equipped
Dec 06, 2013 | 2005 Honda CR-V
I own a Samsung DLP 56" TV for which I purchased a swivel wall mounting bracket that holds up to 160 Lbs of weight. However when looking at the back of the tv set and the such smal size screws that...
Yes it will hold,the wall mount u bought it design for weight of 160 LBS and 50"-60" screen sized right?Just make sure hook up the wall mount on and over a wall area with strong woods beams supports have many fours by fours woods beams lumbers to take off the stress of the holding of the tv by those screws alone of the screen frame screws supports only.
Jun 30, 2011 | Samsung HL-T5676S Television
I want to frame a closet do I just need 2by4's or should I use 2by6's
Framing lumber for interior non-load bearing walls is typically 2x4 in house construction. Even load bearing interior walls often only require 2x4 framing, but could require 2x6 framing depending on the load they carry(the load is how much weight of the roof or upper floors is being supported by the wall). Sometimes 2x6 framing is used for interior walls that have plumbing drain pipes to make it easier to fit them, likewise if the interior wall has heat/air ducting in it. Another reason to use 2x6 is to allow better sound proofing or higher insulation rating. If none of the special cases I've cited apply, then 2x4 is what I would use to frame a closet.
Feb 18, 2011 | RTO M-D Building Products Carpentry &...
Translating japanese to english on fuse box
is located under the dashboard on the driver's side. The fuse label is attached under the steering column. If something electrical in your vehicle stops working, check for a blown fuse first. Below table outlines detail fuse number, its ampere and circuits protected. honda-crv-interior-fuse-diagram-thumb.png
No.
Amps
Circuits Protected
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
7.5 15 10 7.5 (15) (20) _ 10 7.5 7.5 10 10 10 7.5 7.5 10 10 20 15 7.5 20 _ _ (20) 20 20 (20) 15 15 20 (15) 20 20 7.5 7.5 10 7.5 30
Power Window Relay Fuel Pump ACG ABS/VSA Heated Seats* Front Fog Lights* Not used Rear Wiper ODS (Occupant Detection System) Meter SRS Right Headlight High Beam Left Headlight High Beam Small Light (Interior) Small Light (Exterior) Right Headlight Low Beam Left Headlight Low Beam Main Headlight High Beam Small Lights MAIN TPMS Headlight Low Beam Not used Not used Moonroof* Door Lock Front Left Power Window HAC Option Rear Accessory Socket Accessory Front Right Power Window Accessory Power Socket on the Center Table* Rear Right Power Window Rear Left power window ACC Radio ACC Key lock HAC Daytime Running Lights Front Wiper
Dec 13, 2010 | 1997 Honda CR-V
How do i adjust my headlingt on a 2001 suzuki xl7
The adjustment screws/nuts should be located either on the top of the headlamp assembly, behind the headlamp assembly, or near the frame rail by the radiator support.
You will have vertical adjustment screws for each independent beam (separate highs and separate lows, but will be same screw if highs and lows are the same bulb). You may also have additional horizontal adjustment screws as well
Park your car on a level ground 30 feet from a wall and measure the height from the ground to the bulb and mark on a wall (do this for highs beams and low beams if the bulbs are separate, if highs and lows are the same bulb, only do it for the lows)
For Low Beams: If the headlights read VOR, then aim the brightest part or cutoff part just below the mark on the wall. If it says VOL or nothing, aim them 2 inches below the mark on the wall.
For High Beams (if separate from low beams): Aim the headlight directly at the line you marked on the wall.
Nov 14, 2009 | 2001 Suzuki Xl 7
Supporting a load bearing wall
The floor/roof loads above will be a bigger unknown than the ceiling itself. The wall MAY be replacable with properly sized beam/column combinations but you will need to have a design professional look for adauate footing size, calculate floor loads (and roof loads if any), and size the beam/column system to support ALL of the loads now carried by the wall. If you have access to the origional floor and roof framing plans they will be a great help, otherwise someone will need to do some investigating to make thoes design judgements.
In 23 years working as a building inspector I'v seen way too many structural problems caused by inadaquate beam installations, Its worth the time and money to do it right.
Good Luck.
Nov 09, 2009 | Measuring Tools & Sensors
Adjust / aim headlights
Sep 19, 2009 | 1998 Lincoln Navigator
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
