Question about The Office Equipment & Supplies
The green button on my skycaddie will not press in anymore. Is there a fix?
How do I download golf courses to my sg5.
To download courses:
  1. Launch CaddieSync and sync your SkyCaddie.
  2. Select COURSES from the upper navigation bar of the CaddieSync desktop.
  3. Select the Favorites link next to Course Search.
  4. Check the box at the left of each course you want to download to your SkyCaddie.
  5. If you want to remove a downloaded course, uncheck the course in this step.
  6. Click the Download to My SkyCaddie >> button above the Favorites list.
  7. Checked courses will be downloaded to your SkyCaddie.
  8. Unchecked courses will be removed from your SkyCaddie.
  9. Click the Disconnect button in the lower navigation bar and close CaddieSync.
If you experience problems downloading courses:
  1. Turn off the SkyCaddie and disconnect the USB cable.
  2. Close the CaddieSync application.
  3. Reconnect the USB cable from the computer to your SkyCaddie.
  4. Launch CaddieSync.
  5. Click the Sync button in the lower navigation bar to resync the SkyCaddie.
Sep 01, 2011 | SkyGolf SkyCaddie SG5 Accessory Bundle Sky...
Buttons won't work. Just returned from a 6 day golf trip where the SkyCaddie SG4 worked perfectly for the first 5 days. I recharged it in a wll outlet overnight, then on the next day the buttons...
Power On/Off and Key Lock/Unlock - Press the Power button located at the top right
of the Sky Caddie to power on/off or to lock/unlock the keypad. Upon pressing
the Power button you are prompted to choose either "Off" (Left Soft Key) to power
off the device or "Lock" (Right Soft Key) to lock the keypad. To unlock the keypad,
select 'Unlock" by pressing the Right Soft Key, then choose "Yes".
Jul 02, 2011 | SkyCaddie SG 4 Handheld GPS Receiver
I need to reinstal skycaddie program on my desktop
go here and click on the caddiesync green button
http://www.skygolf.com/skygolf/Membership/Owners.aspx
Apr 12, 2011 | SkyGolf SkyCaddie Handheld GPS Unit
My skycaddie froze in transferring while connected to skycaddie sync. i cant get it to turn off or exit.
perform a soft reset. hold power and joystick for 8 seconds. it will turn off. now turn on. if boots up correctly, then ok. if not, then perform hard reset. push the information button (i) and flag button at same time. while both buttons are pressed turn on power. you should be in recovery mode. if so, re-sync.
Aug 15, 2010 | SkyGolf SkyCaddie SGX GPS Receiver
SG2.5 GPS Receiver: SCREEN NOT VERY BRIGHT AND GOES OFF AFTER 15 SECON...
press the bottom left button
scroll to preferences
select
change the contrast settings to fix the screen issue
exit to menu again and select advanced menu, select system settings - and then you can change the auto off timings
May 17, 2010 | SkyCaddie SG2.5 GPS Receiver
Sky caddie will not sync. error reads your SkyCaddie colud not be found.
plug in your connection cable to the back of the skycaddie with the cord going down towards the battery, not up. This should fix the USB recognition issue.
Jul 26, 2009 | SkyGolf SkyCaddie SG4 GPS Receiver
Printed pages come out blank
Hello please try this
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Jun 01, 2009 | Canon BubbleJet i550 InkJet Printer
Canon mp150 pixma printer error e5
dear warenout
try this methode
Methode 1
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
that's all
maybe it can fix your problem
thanks
cropp
Mar 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
24 people viewed this question
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
