User manual for a 3 memory bedol checkmaster calculator
Need to completely reset balances and password
    Master:
  • Computers & ... Master
  • 923 Answers
What about the user manual? Are you saying you already have one? If so, why don't you read it?
Posted on Apr 21, 2017
Do you still make the Bedol checkmaster 110-998
well someone might but we do not .search google.com
Mar 04, 2015 | Computers & Internet
Reset HP 17b11+
According to the manual:
To reset the calculator, hold down [CLR] while pressing the third menu key from the left. Repeat if necessary. The calculator displays
MACHINE RESET to confirm that reset has occurred.
The above sequence does not clear all memory and settings.
If you want to completely erase the continuous memory and return to default settings, press and hold down [CLR], the leftmost
menu key, and the rightmost menu key.(Press three keys simultaneously).
When the three keys are released, the calculator displays MEMORY LOST.
Apr 16, 2014 | HP 17bII+ Calculator
Where is the reset button on a TI-84
Instructions
Enter the memory options by selecting "Mem." Press the "2nd" key followed by the "+" key. Select "Reset" from the memory choices. Use the arrow key to select and delete all memory.
After choosing to delete all memory, select "Reset." After this reset, your screen should show "Mem Cleared." Once you have reached this screen, press "Enter." If you installed programs or applications, you may need to remove them manually. Once again, enter the "Mem" command.
Press "2" to select Memory Management. If you are deleting programs, input that option from the subsequent menu choices. If you need to remove applications, input that choice and press "Enter. Select the application or program from the list displayed. Press "Del" to request the deletion. Choose "Yes" to confirm your choice.
Repeat this process to delete remaining programs manually. After completing this, exit the memory menu and press the "Apps" button. Make sure no applications remain. Additionally, press the "Prgm" button, and check that all programs have been removed
Aug 29, 2012 | Texas Instruments TI-84 Plus Silver...
Can't set a 3-tier Bedol desk clock.
1) Press the SET button until the hour blinks (I think it's 4 times)
2) Press the up or down arrow to change the hour
3) Press SET again to switch to minutes
4) Press up or down again to change the minutes
5) Press MODE to lock in the change
Very non-intuitive process ... frustrates me every time. Bedol is so cheap that they want $2.50 online for instructions ... couldn't provide an online manual for their products?? Geeesh ...
Sep 22, 2011 | Office Equipment & Supplies
How to reset hp20s
Resetting the calculator using the keyboard To halt the calculator and reset the keyboard, follow the procedure below:
  1. Press and hold the [C] key.
  2. Press and hold the third key from the left on the top row.
  3. Release both keys at the same time.
  4. The calculator will now display "0.00" (if the number of decimal places is set to two.)
To completely reset the calculator and erase all user memory, follow the procedure below:
  2. Press and hold the first key from the left (the N key) and the first key from the right (the sigma +) on the top row. Release all three keys at the same time.
  3. You should see "ALL CLr" on the display.
  4. Pressing the [C] key will clear the message.
  5. The calculator will display "0.00."
Sep 14, 2010 | HP 20s Calculator
HP12c showed expected display for low battery (star in lower left), put new batteries in and could not get any display at all. Took betteries out of mine (working great!) and now the one not working shows...
Resetting the calculator using the keyboardThe easiest reset is done from the keyboard. To reset the calculator, follow the procedures below in the order presented.
  1. Press ON to turn off the calculator.
  2. Press and hold [ - ] .
  3. Press and release ON .
  4. Release [ - ] .
  5. The screen will display “Pr Error
  6. The calculator will reset to the default settings, and the memory will be erased.
Aug 04, 2010 | HP 12c Calculator
I need to clear the apps so that my students can test. What is the easiest way to do this?
You can reset all of the memory. The RAM, user data archive memory, and system variables are restored to factory settings. All nonsystem variables, applications, and programs are deleted.
Press 2ND [MEM] to display the MEMORY menu.
Select 7 to display the RAM ARCHIVE ALL menu.
Press right/arrow twice to display the ALL menu.
Select 1 to display the RESET MEMORY menu.
To continue with the reset, select 2. The message "Mem cleared" is displayed on the home screen.
May 21, 2010 | Texas Instruments TI-84 Plus Silver...
Can I completely delete the memory from my Zyxel P-334WT router?
Hi there, in short yes. the reset button on the back will delete all the info on the router however a short press will not. What you will need to do is hold the button down for a good 20 second.... if this does not work then pull the power lead out and push it back in with the reset button pushed in, again for a good few second. Now to view all setting on the router before hand open your web browser up and in the top address bar type 192.168.1.1 or 192.168.0.1 the access code for your router varies on the make but can usually be found in the manual.when asked for a user-name and password just enter those (usually the user-name is ADMIN & the password is PASSWORD or also ADMIN. anyway you shold then be able to view the log and all settings.... hope this help ....Tony A
Dec 13, 2008 | Zyxel P-334WT Router (91003155003)
HP 32 won't work
Hey Dave- take a look at the following link. I like to have the user actually look at the user guide instead of describing it. If this solves your problem PLEASE rate this as fixed. If this isn't exactly right or you need more help just add a comment and I'll be glad to help you further. Thanks.
http://h10032.www1.hp.com/ctg/Manual/bpia5305.pdf
Jeff
Apr 30, 2008 | HP 32sII Calculator
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
