Want to add an internal hard drive to the hp d530 compaq. Is there any other way to fit it, besides removing floppy drive?
  • 69 Answers
It a slimline small form factor design and unfortunately you will not have a second 3.5" bay. I would recommend using a usb floppy because the use of a floppy drive is quite limited now
Posted on Jul 24, 2009
    Habit-Forming:
  • 120 Answers
Floppy drive ? A tech person can easily add an internal HD or CLONE your HD to a larger size with specific software. Cloning will copy everything and you don't lose anything. Most store will install and CLONE the HD for not much money.
Five beep in Hp compaq 530
1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occur while restoring, flashing or updating the BIOS : Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
Apr 21, 2011 | HP Compaq Business d530 Ultra-Slim PC...
I have a d530 minitower pc. a problem in this product microcode patch error. i have download the update but the update wana a floppy disk. i have no floppy drive or disk. please sent me the microcode...
must be stinking XP and the F6 blunder.
so why run XP, the virus magnet.
i guess you meant something does not work
and that Something (a secret) needs a DRiver.
or you mean you are installing windows XP from scratch
and when it gets lost finding SATA drives. (as XP loves to do)
and then asks you to load the SATA driver using F6 key.
then you look and there is no floppy there.
upgrade to W7
XP and VISTA are not supported now.
Dec 13, 2017 | HP Compaq Business d530 PC Desktop
I have a HP Compaq d530 SFF with a 40 G hard drive. I want to upgrade to a hard drive of at least 80 G. Am I able to do this? Like to know also how much more RAM can I add I have 1.5 GBs now..
You can get a maximum of 4GB of ram.
Yes you can also upgrade your drive, probably to a lot larger than 80.
The following is a link to the manual that you can download, in PDF format, that has information on upgrading/adding both memory and hard disks for the HP d530 SFF. It has both diagrams and instructions.
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00059123/c00059123.pdf
Go to the "Hardware Upgrades" section.
Feb 11, 2011 | HP Compaq d530 SFF PC Desktop
Wont recognise HD, have to disconnect DVD drive and floppy drive to force it.
While it can be a faulty hard drive, please make sure you have checked the following:
  1. Update BIOS.
  2. Check if Master/Slave jumpers are set. If you have DVD and HDD (hard disk drive) on the same cable, set HDD to Master and DVD to slave.
  3. Check that the Floppy cable is correctly connected. If connected wrong, the light remains on.
  4. One or both DVD and Floppy are faulty.
When the PC starts, BIOS checks the integrity of components in a sequence, if one component is damaged it will stop and give an error. Like say the HDD comes after floppy and DVD. if the DVD is faulty, then it will hang at DVD and not proceed to HDD.
Nov 26, 2010 | HP Compaq d530 SFF PC Desktop
How much i can upgrade my d530 ultra slim desktop RAM and HDD
You can install up to a max 2 GB RAM and can add a 2nd hard disk
See the following Specs for your computer.
dotclear.gif HP Compaq Business d530 Ultra-Slim (Pentium 4 2.8GHz, 256MB RAM, 40GB HDD, XP Pro) Type Personal computer
  • Product Form Factor Ultra-slim desktop
  • Built-in Devices Speaker
  • Width 12.4 in
  • Depth 13.1 in
  • Height 2.8 in
  • Weight 15.4 lbs
  • Color Silver
Processor
  • Type Intel Pentium 4 2.8 GHz
  • Installed Qty 1.0
  • Max processors supported 1.0
Cache Memory
  • Type L2 cache
  • Installed Size 512.0 KB
  • Cache Per Processor 512 KB
Mainboard
  • Chipset type Intel 865G
  • Data bus speed 533.0 MHz
RAM
  • Installed Size 256.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM
  • Memory Speed 333.0 MHz
  • Memory Specification Compliance PC2700
  • Form Factor DIMM 184-pin
  • Upgrade Rule Max 2 x 1 GB module
Storage Controller
  • Type 1.0 x IDE - Integrated - PCI
  • Controller interface type ATA-100
Storage Controller (2nd)
  • Type 1 x Serial ATA - Integrated
  • (2nd) storage controller interface type Serial ATA-150
Storage
  • Floppy drive type None
  • Hard Drive 1.0 x 40.0 GB - Standard - ATA-100 - 7200.0 rpm
  • Hard Drive (2nd) None x None
Dec 08, 2009 | HP Compaq Business d530 Ultra-Slim PC...
D530 sff hard disk & cd drive update error
hi,
you must be do the default setting into BIOS SET UP so that the hardware you add can detect into it...thanks
Nov 22, 2009 | HP Compaq d530 SFF PC Desktop
HP Compaq d530 CMT Desktop Freezes after a while
Is it like that before? If not then probably, a failing component, a short, most likely RAM card (when you happened to check its rated capacity getting low), connection problem.
Also, too much running applications at the same time, hard drive getting almost full, virus. Or borderline hardware specification for installed application.
Check the easiest first. Is this virus? is hard drive getting full? Borderline specification? Add on card contact dirty? Ailing component?
hope it helps
Apr 06, 2009 | HP Compaq d530 CMT PC Desktop
I can't format my 32gb pen drive.Window unable yo format it
Try to use this program to format it.
Utilityfor formatting and creating loading USB Flash (it is supported NTFS,FAT, FAT32). It works with the devices through port USB 2.0. For theload from flesh in BASIC INPUT-OUTPUT SYSTEM Setup it is necessary toestablish as the first loader USB-HDD Device. m_right_m.gif banner_header m_right_m.gif VERSION: 2.1.8 Rev. A
DESCRIPTION:
This SoftPaq contains a Windows-based format utility for the HP Drive Key or
DiskOnKey USB 2.0 device.
PURPOSE: Routine
SOFTPAQ NUMBER: SP27608
SUPERSEDES: SP27213, SP27135
EFFECTIVE DATE: May 17, 2004
CATEGORY: Driver - Storage
SSM SUPPORTED: No
PRODUCT TYPE(S):
Desktops
PRODUCT MODEL(S):
HP Compaq d220 microtower: All Models
HP Compaq d230 microtower: All Models
HP Compaq d240 microtower: All Models
HP Compaq d248 microtower: All Models
HP Compaq d330 desktop: All Models
HP Compaq d330 microtower: All Models
HP Compaq d330 slim tower: All Models
HP Compaq d338 microtower: All Models
HP Compaq d530 convertible minitower: All Models
HP Compaq d530 small form factor: All Models
HP Compaq d530 ultra-slim desktop: All Models
HP Compaq d538 convertible minitower: All Models
HP Compaq d538 small form factor: All Models
HP Compaq dc5000 microtower: All Models
HP Compaq dc5000 small form factor: All Models
HP Compaq dc7100 convertible minitower: All Models
HP Compaq dc7100 small form factor: All Models
HP Compaq dc7100 ultra-slim desktop: All Models
HP Compaq dx2000 microtower: All Models
HP Compaq dx6100 microtower: All Models
HP Compaq dx6100 slim tower: All Models
HP Compaq dx6120 slim tower: All Models
HP d325 microtower: All Models
HP d325 slim tower: All Models
HP RP5000: All Models
N/A: All Models
OPERATING SYSTEM(S):
Windows XP Home Edition
Windows XP Professional
LANGUAGE(S):
Global
ENHANCEMENTS:
New Windows-based interface. (For DOS-based interface, download SoftPaq
SP27214.)
FIXES:
- Allows creation of a FAT32 volume larger than 32 GB.
- Fixes installation issue where installation process stopped after the earlier
version of software was uninstalled and the new software was not automatically
installed. The installation process now restarts automatically to install the
new software after uninstalling the older version.
PREREQUISITES:
- Requires an HP Drive Key or DiskOnKey device plugged into a USB 2.0 port.
HOW TO USE:
1. Plug the HP Drive Key device into an available USB 2.0 port.
2. Download the SoftPaq .EXE file to a directory on your hard drive.
3. Execute the downloaded file and follow the on-screen instructions. If
prompted to overwrite any files, answer Yes to all to continue installation.
http://www.maxiwarez.com/2007/12/21/hp_usb_bootable_format_tool_v.2.1.8.html
Dec 30, 2008 | Kingston Technologies 512MB DataTraveler I...
How to install new hard drive
2 choices for you. Get the external to run the game or 2. Add a larger hdd to the system as a slave drive leaving the smaller drive as the master. If you go the 2nd route just make sure you buy a compatible hdd. Hope this helps & please remember to rate my answer.
Dec 28, 2008 | HP Compaq d530 PC Desktop
Computers & Internet Logo
145 people viewed this question
David Payne
David Payne
