Sir I have Windows 8.1 want to setting taskbar
    Master:
  • 507 Answers
Right click on the windows taskbar and click properties and this will bring up a box on changing the items related to the taskbar and start screen
Posted on Apr 21, 2017
How to upgrade Windows 8 to Windows 10 ?
Restart your computer and there should be a box in the bottom right of your taskbar. You can click that to upgrade.
Mar 28, 2017 | Computers & Internet
Tip
Remove text on taskbar icons like Windows 7 An easy way to give your Windows...
An easy way to give your Windows Vista box a clean look is to remove the application labels on the taskbar. With a registry hack you can make your Windows Vista taskbar look similar to the Windows 7 icon only taskbar.
1.Click on the start button and type in regedit and hit Enter.
2.Navigate through HKEY_CURRENT_USER\ControlPanel\Desktop\WindowMetrics.
3.Create a new REG_SZ value and call it MinWidth
4.Set the value of MinWidth to 56
5.Restart
on Nov 19, 2013 | Microsoft Windows XP Professional
How to move icons from left side to bottom of screen
On all windows apart from Windows 8, you drag them from the desktop (left hand side) to the bottom (taskbar) with the mouse.
If the taskbar gets full up the icons might disappear.
The double bar at the end of the taskbar must be moved to the right for more of the taskbar to appear.
Mar 14, 2015 | Lenovo Computers & Internet
Windows 8.1 store app works but all other apps only open to taskbar including change PC settings
You might try installing a $ 4.99 program called " Start8 " It will install a real start-up button very similar to the Windows 7 start button. You can find it with any search engine.
( I am in no way affiliated with the makers of this program, I just use it and find it makes the Windows 8 and 8.1 OS much more usable, I wouldn't use 8 or 8.1 without it)
Nov 02, 2014 | Computers & Internet
How to enlarge the icons on the toolbar
If you mean enlarging the task bar items please follow the following steps:
1-Access the Taskbar and Start Menu. This particular menu will allow you to customize your taskbar features and resize the icons. Click on the Start menu, or Windows logo, from within your taskbar.
2-Select "Control Panel," then select "Appearance and Personalization." On some Windows 7 computers, this option may also read as "Appearance."
3-Click on "Taskbar and Start Menu." This will open a Taskbar and Start Menu Properties dialog box on your screen.
4-Change the size of the taskbar icons. Place a checkmark next to "Use small icons" within the Taskbar Appearance section to make your taskbar icons appear smaller.
5-Click directly on the checkmark if one is already present to enlarge the size of your taskbar icons.
6-Save your taskbar icon customization settings. Your new taskbar settings will go into effect immediately. Click on the "Apply" button to save your changes, then click "OK" to exit from the Taskbar and Start Menu Properties menu.
Apr 27, 2014 | Panasonic Toughbook CF-51 Notebook
Usb driver qhm500 8lm Sir i want drivers for
Hello
Currently, there are no Windows 8 drivers fo rthe QHM500-8LM PC camera (16 Mega pixels).
I would suggest downloading the drivers from the company web site:
http://www.qhmpl.com/Download-Drivers.html
....and save them to the hard drive. Once saved, right click the driver and choose PROPERTIES. From the new window, click the COMPATIBILITY tab at the top. In the COMPATIBILITY MODE section of the screen, enable this and choose the OS that the driver is listed to work with.
For example, if you download the Windows XP driver, set the COMPATIBILITY MODE to Windows XP Service Pack 3. If you download the Windows Vista driver, choose that OS.
Until a specific driver is created for this hardware, this will be the only way to get it to work with Windows 8.
Nov 01, 2013 | Computers & Internet
To adjust rotating display of laptop ,taskbar with all icons moves on different(bottom to top)
Step 1:
Has your Windows taskbar suddenly moved to the side of your desktop screen or even to the top? This can be very disruptive to your daily computing, which may mean a loss of productivity at work. Your taskbar could have moved because of a glitch in programming or an inadvertent mouse click while you were focused on something else. The latter is more common and is usually the result of an unlocked taskbar.
Older Windows Operating Systems Windows 98, Windows ME, Windows XP and Windows Vista all utilize similar solutions for this problem. For the quickest route to returning the taskbar to the bottom of the screen, first place your mouse pointer over empty space on your taskbar (space not occupied by an icon or a button indicating an open program) and right-click. Look near the bottom of the menu that appears for the "Lock the Taskbar" listing, and make sure there is no check mark next to the listing. If there is a check mark, it means the taskbar is locked and cannot be moved, so click on the listing to deselect (and unlock) it. With your mouse pointer again over an empty space on the taskbar, click and hold the left mouse button and then move the mouse pointer to the bottom of the screen. When you release the left mouse button, your taskbar should have moved. As long as the taskbar is unlocked, you can also vary its height. Hold the mouse pointer over the upper edge of the taskbar until it becomes a double arrow (pointing up and down). Then click and hold while you drag the upper edge of the taskbar to the you desire. Once you have the taskbar where you want it, remember to lock it again by selecting the listing on the right-click taskbar menu.
Another option is to visit the Microsoft Windows website and download and run an automatic "Fix it" program, which should take care of programming issues. Windows 7
There are three options for moving the taskbar in the Windows 7 operating system. The first option involves right-clicking on an empty space in the taskbar and then navigating to the "Properties" menu (look near the center of the menu) to set the location of your taskbar on your screen. This menu also allows you to change or establish a number of other default settings relating to your Start menu and taskbar. The second option is exactly the same as the first process given for the Windows operating systems previously mentioned. And again, to prevent the format you have established from changing, lock the taskbar by right-clicking on an empty space of the taskbar and selecting "Lock the Taskbar" from the menu. The third option is a bit more involved and requires downloading registry files (files ending in ".reg"), saving them to your desktop and then double-clicking on them to merge them with your operating system. The files can be deleted after use.
Microsoft online support
http://support.microsoft.com/kb/253679
Feb 17, 2013 | Dell Inspiron Mini 10 Notebook
Windows start bar has completely gone
Sympton
You cannot see the taskbar (which contains the "Start" button) anywhere on your desktop.
Causes
  1. The taskbar may be hiding at the bottom of the screen after being accidentally resized.
  2. If the presentation display was changed, the taskbar may have moved off of the visible screen (Windows 7 and Vista only).
  3. The taskbar may be set to "Auto-hide" (Windows XP with Service Pack 2 only).
Solutions
  1. Put the mouse pointer on the bottom border of your screen.
    • If the pointer turns into a double-arrow doublearrow.gif, click and drag upwards.
    • If your taskbar isn't hiding at the bottom of the screen, try moving the mouse to the right, left, and top edges, looking for the double-arrow.
  2. Press the Windows logo key and the P key on your keyboard to bring up the presentation display mode options.
    • Make sure "Computer Only" is selected.
    • Use the arrow keys to toggle between options and Enter to select the correct display mode.
  3. Press the Windows key on the keyboard to bring up the Start Menu
    • Right-Click on the taskbar and select Properties.
    • Toggle the 'Auto-Hide the taskbar' checkbox and click Apply.
    • If it is now checked, move the cursor to the bottom, right, left, or top of the screen and the taskbar should re-appear.
    • Repeat step three to return to your original setting.
Dec 04, 2012 | Computers & Internet
Windows vista home premium taskbar troubleshooting
dear sir
please click on the task bar drag it & drop it on the bottom of the desktop
regards
murali
Dec 18, 2008 | Microsoft Windows Vista Home Premium with...
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
