I have a whirpool stack duet washer and dryer mod wfw9250ww01 it wont fill all the way it sounds like the water pressure level switch do you have to take the dryer off before you can get to the part?
  • 507 Answers
Modern front loaders dont use a lot of water when washing clothes since the diagnostic board doesnt allow for too much water to flow into the washing drum this is fully normal for eco reasons
Posted on Apr 21, 2017
Water wont shut off
Hello, Thank You for using FixYa. I will be helping you today.Unplug the unit if it still fills replace the fill valve. If it stops filling when the porwer is off and keeps filling at start of a cycle it would be the pressure switch or pressure hose came off. The pressure switch is the water level selector switch and the hose goes from it to the tub.
Thank You and please rate my answer if it was helpful..
Jun 27, 2011 | Kenmore 98702 Stacked Washer/Dryer
Washer overfills, dosen't stop filling even after I cut washer off
bad water level switch or the clear plastic hose has a hole in it or popped off the water level switch or the pressure switch same thing.the switch works by pressure,if there's a hole in it or the line feel off there's no pressure and the switch keeps calling for water,shut the water valve off
Jul 11, 2010 | Kenmore 98702 Stacked Washer/Dryer
LSE7806A stack: the wash fills to the water level/load size selected. it starts to agitate then stops and begins to fill with water again which causes overflow, help please
Your fill sensor is leaking and allowing air pressure from the clear tube to seep out. First make sure your clear tube from the tub to the water level valve is firmly connected. If it is then you may need to get a new water level adjuster switch.
Mar 09, 2010 | Maytag LSE7806A Top Load Stacked...
Washer will not stop filling up it overflows
Very simple. No parts needed! Remove the pressure tube that connects from the water level switch down to th bottom of the tub. Blow out the trash that has accumulated in the bottom of the tub and re connect the tube to the water level switch. Drain the washer. Retry.a097efc.jpg
Dec 15, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washer won't agitate, drain or spin
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
FH Code in Digital Window.
The fh is a fill error caused by one supply being low on pressure, a bad fill valve, a bad flow meter or a bad pressure switch or hose .
Sep 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire stackable will not stop filling with water or agitate.
yes unless pressure switch(water level switch)detects proper fill level wash will never start agitating some washer will not spin if switch does not detect empty tub
Jun 02, 2008 | Whirlpool LTE6234D Top Load Stacked...
Washer not filling
stuck pressure switch/water level switch also ckd for blocked or pinched hose to switch try taping water level switch possible stuck contact if this is case replace control wouldn't trust it not to do it again or worse overfill and fload
May 10, 2008 | Whirlpool LTE5243D Top Load Stacked...
Washer stopped working??
change the pressure switch its the switch that you select the water level with
Mar 18, 2008 | Maytag LSE7806A Top Load Stacked...
Whirpool duet front load washer door trouble
I have stacked ours too, though after 5 years we have not had any issues with the pressure. I would suggest checking the screws holding the hinge in place as they may have loosened or been tightened with the door not properly lined up.
Aug 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
