Question about Vizio Televison & Video
Vizio m70 D3 red screen switching from casting to directv. On input dmi 5. Rebooted does not help. Screen says it doesn't support 4 k.??????? It's a 4 k TV. DirecTV is a genie 4 k.
SOURCE: vizio and the directv dvr
Vizio recommends using code 11758 or 10178 for Cable/Satellite universal remotes that use five digits such as DirecTV. For four digit Cable/Satellite universal remotes , use 1758 or 0178. For three digit Cable/Satellite universal remotes, such as Dish or Echostar, use 627. These codes typically make the Power, Volume and Mute functions work.
Posted on Feb 01, 2009
SOURCE: directv remote codes
Trutech is a daewoo product. I used the code 10451 also try 11661, 10092, 10672, 10019, or 10623. hope this helps.
Posted on Feb 10, 2009
go to menu
setup again
the satelite receiver will tell you the procedure for programing the remote
Posted on Apr 03, 2009
  • 5568 Answers
SOURCE: Programming with DirecTV remote
Since the flood of new models is great, your remote will never have the capability to control all brands and models. Vizio (like many others) is a very new name in the marketplace so if they did not choose to mimic the IR system of another, more wide-spread brand, you may never have a code set in proprietary remote such as yours (and mine from Dish Network). Even the 'learning' remote I bought will not accept the control signals from the lousy Ilo we own either. Your provider, DirecTV may have some newly developed partially effective code sets so check the support section of their website.
Posted on Apr 22, 2009
SOURCE: directv rc23 remote - new Viore 42" TV, Model v42rmfj
hold the mute and select button down till the light blinks at you ( note the remote must be in the tv mode ... switch on top all the way to right) once the light blinks enter 991 then pause a sec and enter 1 again then use the chanel up till unit turns on then hit select button repet till all functions work
Posted on Jul 24, 2009
Vizio M70-C3B TV
The t con board or the LCD panel is fault. You have to replace the TCON board to confirm.
If you wish to get some details; check the site linked here. Pull up older posts.
Sep 02, 2016 | Vizio Televison & Video
Could you please tell me how to reset my tv? I have a blue screen
What should I do if my TV screen turned black, blue, or gray? print.png Print try this.
Proceed with the troubleshooting steps below only if you're seeing:
  • Black, blue, or gray screen
  • "No Signal" message without the DIRECTV logo
Note: If your TV screen appears "frozen" or you're seeing wavy lines or overlapping images, try this.
Solution 1: Check that your TV is set on the right input
[img border="0" alt="Image" src="">Turn your TV and receiver off and back on.
[img border="0" alt="Image" src="">Using your DIRECTV remote control, press the TV Input button to cycle through TV inputs (Component, HDMI, etc) until you see a picture. If nothing happens when you press the button, try programming your DIRECTV remote to control your TV Input and try again.
Note: You can also try changing the TV Input using your TV remote.
[img border="0" alt="Image" src="">If you're still having issues, check the cable used to connect your receiver to your TV.
Still not seeing a clear picture?
Continue to Solution 2.
Solution 2: Reset Your Receiver
[img border="0" alt="Image" src="">On some DIRECTV receivers there is a red reset button located inside the access card door on the front panel. Press it, then wait for your receiver to reboot.
Note: If you cannot locate the red reset button or your receiver does not have one, unplug the receiver's power cord from the electrical outlet, wait 15 seconds, and plug it back in. Then press the Power button on the front panel of your receiver and wait for your receiver to reboot.
could-please-tell-me-reset-tv-blue-i0x50p0fk40mg1d0uyxi2cma-5-0.jpg could-please-tell-me-reset-tv-blue-i0x50p0fk40mg1d0uyxi2cma-5-1.gif
May 12, 2014 | Vizio L37 Television
Have a Vizio VX37L that when it is turned the
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix.... TV is stuck in RGB input.
(option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV.
If that doesn't work, try:
(option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.
Option 2 worked for me!
Jan 24, 2010 | Vizio VX37L Television
I'm house and pet sitting at a friends' house who have a large screen Vizio TV and DirecTV. Right now, the TV is set on HDMI, but there's a floating message on a black screen: ''No Signal!'' This...
You need to make sure that is has enough signal, if you have poor signal, you will get pixels(as oppesed to snowy picture on CRT televisions) make sure all plugs are plugged in correct, and try diff inputs from DirecTV to the Tv to ensure its not the HDMI input thats faulty. Good Luck.
Sep 26, 2009 | Vizio GV42L 42 in. LCD Television
Vizio 42" LCD. Flat screen. Won't display CC on setup screen using HDMI input. Have a Sharp tv on another Directv box and it shows CC via HDMI connection. Problem with receiver or with TV? Costco's "Help"...
CC is a feature of the TV. All TVs are different in features and the Vizio is limited on its features due to cost. To eliminate the directv receiver connected to Vizio TV just swap with the receiver connected to Sharp TV and see if CC is displayed.
Mar 05, 2009 | Vizio VO42L 42 in. LCD TV
I am trying to connect an akai dvd player to directv, please help
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
Jan 31, 2009 | Akai DVD-3850S DVD Player
Im trying to get my nintendo 64 to work on my avic d3. i know i need a power inverter, what else do i need? also, do you know where the red white and yellow plugs from the nintendo 64 goes into the d3?
the red white yellow wires plug into the rear of the unit (white and red RCA will go into video or aux input) the yellow wire will go into video in (the red and white RCA from Nintendo they can go into either video 1input or aux input) on back of in-dash unit
hope this helped
Dec 15, 2008 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
Pink Screen on Vizio 37 inch with HDMI Connection
I work as a contract technician for Vizio, and I can tell you from experience that replacing motherboard is one of the only solutions to this problem. The other solution if under warranty is to replace it. If you experience red, blue, or green pixels where dark shades (like nose, eyes, clothes, etc), call Vizio and accept nothing less than a full replacement! I have had situations where I replaced motherboard and within 2-3 hours the pixels return. Hope this helps.
Dec 13, 2008 | V, Inc. Vizio P50HD Plasma Television
How to hook my directv to digital input to lcd tv j32l637
I don't know what flat screen tv you have,but you must be aware of the coaxial input behind the TV.It could be analog input,digital input and OUTPUT!!
Anyway,if you connect your basic directv box to your digital input,it will not serve you any purpose to get HD channels and you don't have the HD directv box.The TV will not display digital channel for you because if you use coaxial input to TV,you should be under either channel 3 or 4 and be sure either channel had been saved under memory.In order to change channels,you will need to change it from your directv box.
JUST LIKE a VCR connect to TV.TV will be under channel 3 or 4,and you will change your channels from the VCR.Don't forget to scan all the channels from the VCR!
Nov 11, 2008 | Televison & Video
Weird problem not convergence
Mine is doing the exact same thing! have you found a fix yet?
Apr 23, 2007 | JVC AV-48WP74 48" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
