Question about KitchenAid Ovens
Calibrate my kitchenaid oven - KitchenAid Ovens
Need Specs and sizes for a 1989 KitchenAid Superba 27 - KBS277
Are you sure of the model number? I see several KitchenAid ovens with the model number KEBS277: http://www.kitchenaid.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10552&langId=-1&storeId=10202 . The single oven version is 28┬│??" (73.0 cm) H x 26┬│??" (67.9 cm) W x 23" (58.4 cm) D.
I hope this helps.
Sep 03, 2016 | KitchenAid Ovens
Cracked inner oven glass window
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Jan 16, 2011 | KitchenAid Ovens
Kitchenaid Oven
good day,
hope this link below will solve your problem.
kitchen
Jul 27, 2010 | KitchenAid KEBC101 Electric Single Oven
I think the oven is not getting hot enough,i have baked three
Buy an oven thermometer to check if the temperature you set the oven at is accurate. You may have a faulty thermostat, but if the temp is only off by a little, you can calibrate the temp setting on the oven by as much as + or - 25 degrees. If you have an LCD screen, then most likely you can adjust it right on there. If not, then the backside of the oven knob can be adjusted + or -. by moving a set screw and turning as needed. Your owner's manual will have a more detailed explanation on this procedure. Douglas
Jun 13, 2010 | KitchenAid 30 in. Architect II Series 4.3...
GE profile oven (drop in ) Thermostat is way off (set at 400 its only really 365. how do i calibrate it>?
YOU CANT CALIBRATE THE STATS YOU WILL NEED TO REPLACE IT THEY DO A UNIVERSAL 2 TAG 400 DEG STAT AT APROX £18.00
Mar 08, 2010 | GE Profile JTP18 Electric Single Oven
Oven unit not heating up - Kitchenaid KEMX377GWHO
This sounds like a blown thermal fuse, a common problem. What model oven was this?
Dec 02, 2008 | KitchenAid Architect® KEMS378S Electric...
Kitchenaid oven
turned off oven. continues to beep F 7
Aug 27, 2008 | KitchenAid Ovens
Ovens Logo
107 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
