Question about Tablets & eReaders
Excelvan BT1077 tablet, when turned on, only shows Excelvan and does nothing. Tried: Pressing Power & Back buttons Hard Reset Holding Reset for 1min I can't link via USB to my PC either. Any ideas?
  • 361 Answers
SOURCE: tablet pc rotation
u can use once time alt+ctrl+ any type arrow to roated screen
Posted on Jun 13, 2009
SOURCE: Motion Computing C5 Tablet PC won't power on
Hi! I do understand that you are having the problem on the laptop turning on. Try another option, turn off laptop, remove cables and battery, press and hold power button for 10 secs. Reinsert the cables and battery on the laptop. Then turn it on. If the laptop did not turned on, remove the power cable and turned on the laptop. If still didn't, remove the battery and insert the power cable. If still did not work then check if there lights flashed on the laptop when turning it on. If still does not, then you need to contact the pc manufacturer for repair and possible replacement. Otherwise, if there is light on the laptop, then there might be a problem either the battery or the power cable itself. If there is light on the laptop but no power cable, most likely the monitor did not work simply because the battery works due to the fact that there is light on the laptop. On the other hand if there is light when plugging in the power cable on the laptop, then you need to check and insert another battery if it works. Otherwise you need to replace the battery...
Posted on Jul 06, 2010
SOURCE: my sylvania tablet will not charge or power on, i've tried the hard reset and it didnt work do you think that the charger is bad or thetablet is defective
(will not charge or power on)I sent my smartphone in for repair the other day.They told me it was water damage in the charging point
i have never had it near water but apparently having the phone in high humidity places is common for it to happen eg talking on phone under bus stop in the rain, having phone somewhere in bathroom while having shower,
holding phone over hot coffee? hope you get it fixed :p
Posted on Jul 29, 2012
  • 21 Answers
SOURCE: Tablet wont boot
Posted on Jan 07, 2014
  • 77 Answers
SOURCE: the 7 inch tablet when you turn it on shows the 2 dogs then goes to rca logo and nothing else. tried to reset by holding power & volume button at same time, did not work
contact vendor mfg - shoulds be under warranty
Posted on Jul 11, 2014
How do i get my prontotec 7 android 4.4 kitkat tablet pc cortex xA8 1.2 GHz dual core prosesor 512 MB/4GB to reset?
You can reset if you do a hard
follow this procedure.
1. switch the tab off. after,
2. long press power button +
volume down key simultaneously.
3. after it shows the logo then
release the power button but
continue pressing the volume key
until the wipe or reset menu
after that you can reset/wipe it.
May 23, 2015 | ProntoTec Tablets & eReaders
I know how to turn on my tablet, but for some is not turning on today. I have tried the on button and also tried pressing and holding it down a couple of times and it still wont turn on. it...
try holding power button down for 20 seconds. if nothing, then tr holding power and up or down volume on bot at the same time for about 20 seconds or until something happens and release both t the same time. good luck. oh, and some tablets there is a reset hole on the bottom or side that you can reset with a paperclip.
Mar 03, 2015 | Irulu 7" 4gb Google Android 2.3...
How to restart my tablet without turning it on because I forgot my password?
Look in your tablet instruction book for a procedure called 'hard reset' or a location for a small hole on the edge or back of the tablet where you can push in something non-conductive, like a toothpick to press a hidden reset switch. Without having a make and model for your tablet, it is hard to determine what exactly to do because each make and model is different. You talk about pressing the power and low volume buttons- are you holding them both in simultaneously for 10 seconds? This might be the reset procedure for your tablet, but that is not clear. One last thing to try is to hold in the power button for 10 seconds and see if you get a power off screen. If you get this, try powering off the tablet and then restarting. Also make sure the keyboard isn't on caps lock when you type your password.
Jan 03, 2015 | Tagital Taital TM 7" Android 4.0 4B MID...
I have no volume no sound Would a Hard Reset fix this problem?
A hard reset is worth a try but it is unlikely to fix the problem, it sounds like a hardware issue.
Here are instructions for a hard reset
Make sure the tablet is OFF.
Press and hold the Volume Up and Power buttons at the same time.
When the Android starts to flash, release the buttons.
Then try to press different hardware buttons until you are given a list of options.
Note: If Volume Up and Power doesn't work, try Volume Down and Power.
Dec 25, 2014 | Craig CMP741d Tablet
Coby not working
1. Turnn completly off the tablet.
2. With the tablet turned off, holding the return button while turning on the tablet-pressing power button. Keep holding the return button until you see the Hard Factory reset screen.
3. Confirm the hard reset procedure. Once done, simply wait until process has finished-the tablet will restart. This process can take up to 30 minutes, so it's very important that the battery of the tablet is completly charged before attempting the hard reset. If you can connect it to the charger while resetting, even better.
May 28, 2014 | Coby Tablets & eReaders
Trio tablet wont turn on
sounds like the hard drive is froze up
Mar 08, 2014 | Mach Speed Speed Tablet Trio Stealth G2 7"...
Hard reset tablet
There should be a reset button on the bottom right corner on the back of the case. You may need a paper clip or something to reach in and press it. Make sure the unit is charged (using the AC adapter) and then press the reset and power for 4 seconds, then release the reset button.
Jan 18, 2014 | Tablets & eReaders
I have forgotten my pin code for my supersonic SC-74MID tablet. How do I reset it?
I don't know which OS your tablet uses... perhaps Jelly Bean. If so, if you push the Power button and the "Power Off" option shows up on the screen press the selection of "Power Off" and hold your finger down on it until a pop-up screen shows a selection of: Boot into "Safe Mode". Choose that and what happens is it boots up with no applications loaded. You should then be able to access the "Settings" and then choose "Factory Data Reset" option. Hope this works
Jan 08, 2013 | Supersonic 7" Touch Screen MID Tablet
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
