Question about Vacuums
I have a room 15ft x15ft what size carpet would i need
  • 2,602 Answers
15 x 15 = sqft
Posted on Apr 21, 2017
How does the carpet cleaner work
Resolve carpet cleaner is a cleaner specifically designed to work on carpets. Resolve comes as a steam concentrate, a powder, a foam spray, or liquid spray. Before using the carpet cleaner you should vacuum the carpet. Resolve carpet cleaner works by being applied to the carpet then worked in with a soft bristled brush. Depending on the cleaner, it will be sprinkled or sprayed onto the carpet. Use the brush to work the cleaner down into carpet fibers. There is a waiting period for the cleaner to work, then you vacuum the cleaner out of the carpet.
Apr 25, 2014 | Electrolux Sanitaire SC688A Upright...
Carpet cleaning
If you wet cleaned and vacuum extracted yet find carpet still quite damp,
The most common methods to dry are:
With windows open on a warm day...
Air movers
(High speed squirrel cage fans with low exhaust openings)
Designed to shoot air across the surface of the carpet...Evaporation occurs that way.
Alternatives are:
Depending on climate..running your central air or room Air conditioner with fans set around the room ,...This option is what I normally use when humidity is high in Kansas
Another option..And actually the best would be to use a Dehumidifier...They are a bit pricey new...but rentals are available
Sep 12, 2012 | Rug Doctor Mighty Pro X3 Carpet Cleaner -...
What is the best way to take up carpet?
go please to www.hoover.com and go to customer support and see the video and all instructions for your questions.
God bless you
Jul 06, 2012 | Vacuums
What do I need to do to extract water from a carpet following a leak.
If you're renting your home, call the landlord and let him have it taken care of.
If you own your home, the best thing you can do is to call a carpet cleaning company with a truck mounted machine. They still won't be able to remove all the moisture, but will get it dry enough for the next step. If you feel this would be too expensive, rent a "steam cleaner" from a rental place, or store where they rent them, and go over your carpet several times with this.
After the water has been vacuumed up, you'll need to lift carpet and prop it up enough to allow a fan or two to be placed so it will be able to blow air on the bottom of the carpet, as well as the pad. Raising the temperature in the room, or placing a heater that will blow warm air on the carpet and pad will help dry them faster.
Ensure origin of leak is fixed.
Dec 21, 2010 | Numatic Henry Bagged Canister Vacuum
Too much solution being dispensed--carpets very wet--running out of solution before even 1/3 of room cleaned
The cleaning solution tank is only sufficient for part of a room, unless the room is very small.
Are you following the instructions for using the cleaner carefully? The machine has to be pulled backwards (towards you) at a steady pace in order for the vacuum to pick up the water that is dispensed. Do not use it like a normal vacuum cleaner - that will not work.
You need to start facing a wall, and pull the cleaner towards you, moving at about one foot every two or three seconds. The vacuum will then pick up the water that has been dispensed and the carpet will be damp but not sodden.
Apr 06, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
How to assembel the kirby accesories to manually shampoo
I just did and it's multiple steps but not too hard.
There are complete detailed explanations if you do a search engine on kirby shampooer instructions. I found one explanation on Ebay, and another on EHow. www.goodvac.com/Articles.asp?ID=153
Step one - vacuum your carpet more thoroughly than you usually do. Each back and forth pass - four times.
Take off the dirt bag and the head off of your Kirby.
Where the dirt bag attaches to the Kirby is where the shampoo mixing container goes. Before you attach the mixing container on there take your container and fill it to the 1st line for a very small area, 2nd for a medium sized area, and to the third line for an average sized bedroom. A large living room may need a second container. For the solution - you must use Kirby shampoo. If you fill to the first water line - use one capful, 2nd line 2 capfuls, and etc. Make sure the sponge filter is positioned on the mixing container in the spot where it hooks onto the vacuum (mini-emptor).
The shampoo brushhead I find to be the biggest challenge because that L-shaped tube attachment gets in the way of the belt lifter when you try to hook on the belt. The belt is going to hook on the brushroller the same way it does on your vacuum head. Pop the brush roller in the head of the shampooer and then sit that head onto the tray mechanism.
Once you puzzle piece everything together and now ready to shampoo. Let me tell ya this - after the hassle of putting everything together - just do the whole room and make it worth the bother.
Turn the machine on, and lower the shampoo head ALL THE WAY DOWN, unless your carpet is ultra thick and then maybe just one click up. Turn the dial on the shampoo mixing container to on. Push the machine forward rather quick and pull back slow. Do overlapping passes.This will spread the foam nice and evenly. Let the foam sit for about 5 minutes, then turn the dial to off and go back over it slowly forward and backwards massaging the foam solution deep into your carpet fibers. Then let it sit for 2 - 3 hours. Then vacuum really thoroughly. Right after I go through the shampooing process and the carpet is still moist - I use a carpet brush and I scrub the foam even deeper into the carpet.
Good luck. Hopefully you will be motivated in the fact that I just did mine and the high traffic carpet looks really good. I just had clients come in and they noticed the difference right away, as it looks like a pro came in and did the job.
Mar 21, 2010 | Kirby Ultimate G Bagged Upright Vacuum
A friend loaned me her Bissell Proheat Turbo carpet cleaner and I don't know how to use it - any help?
I like these cleaners.
First vacuum your carpet very thoroughly.
Depress the lever to tilt back the handle.
Grab the tank from the base. Remove the lid.
Fill the bladder with hot tap water. Replace the lid, and place tank back into the base. Put the handle back upright until it locks into place.
Take the soap container on the side and fill it with the Bissel soap solution. Place your dial on floor cleaner, and select either soap or heavy traffic.
Turn on the machine and the heater. Take your machine to the far end of the room and depress the handle put the machine in the corner depress the trigger and you will see a little spinning thing on the machine starting to spin - this means that the solution is blending and the spray is wetting the carpet. Pull the machine slowly back towards you about three feet and then let go of the trigger and pull the machine a couple more inches. When you stop the trigger will release. Push the machine forward and repeat the pull pass this time without depressing the trigger. For the next pass - overlap each and every pass (I do each pass at the half way point). Do this along the back wall. When you depress the trigger and that spinning dial does not spin - you are either out of water or out of soap. Go over the entire room with this technique.
Now this next step is VERY important. You have to do the whole room process AGAIN - this time with NO SOAP. I have used these machines for years and trust me - if you don't go over it again - your carpet will be a magnet for dirt. This time empty out your soap cup and rinse it out and refill it with WHITE VINEGAR. Again fill your tank with hot water. Re-do the entire room as if you are shampooing the carpet.
Let the carpet dry overnight - the next morning I would recommend applying scotchguard carpet protector (you can get the cans at H.D. or Lowes. Yes the Bissell solution has scotchguard, BUT when I apply the scotchguard again - the carpet stays so much cleaner so much longer.
Do it right the first time and don't cut corners and you will have the cleanest carpet on the block. It's a long process to do it right, but the end result is worth it.
OR if you want to save money and use something more environmentally friendly - fill with white vinegar. This will work just as good and leave your carpet less sticky from the soap and your carpet will stay cleaner longer.
Mar 19, 2010 | Bissell 1699 ProHeat Clear View Upright...
Smartstrand carpet makes vacuums difficult to push
The seam problem could be an installation problem. It is important to pattern match any carpet with a pattern. If the carpet is a plush carpet, the seams should not be invisible, but not unsightly. If he carpet is a frieze, the seams should be hard to find. Any variance from these norms could mean a redo of the seams by a talented carpet installer. In a large room such as yours seams will never be invisible.
Good Luck, carpetguru
Aug 24, 2009 | Oreck XLS700A Upright Vacuum
Wont **** up very much and know my room smells rotten
Even the professionals have problems getting pet stain smells out of carpeting. You need to use a good deodorizer and get the carpet as dry as possible.
Aug 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I'm using way more cleaning fluid
i am bisell dealer and i would reccomend mixing soap in the clean water tank and place just water in soap tank to get more accurate dispencing because there is no other adjustments on the unit
Mar 26, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
