Question about The Computers & Internet
I cannot get the app to go to the next puzzle. It is really slow and I have to click on then it just gets stuck. It might open then it gets stuck again. It's getting very frustrating.
  • Adrienne Serio
    Adrienne Serio Apr 22, 2017
    Hi SandraAllison , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?What app? What are you using to access the application?
MNfisherman
  • 11896 Answers
SOURCE: Driver side window stuck on Nissan Maxima 2004
It is likely the window motor is wearing out and will need to be replaced. You can always try a different switch on those wires to rule out switch problem. Otherwise, the motor will have to be replaced.
Posted on May 25, 2009
  • 31 Answers
SOURCE: My cleaner almost always get stuck on the white
If the pool drain cap is recessed below the bottom of the pool floor, you can fabricate a plexiglas acrylic or polycarbonate cover for the cap. Measure the diameter of the recessed drain and add 4 to 6". Cut a circular piece of 1/4" thick acrylic/polycarbonate (you can purchase this at a home improvement store or glass company) to that diameter. Drill 10 or more 3/4" holes, evenly spaced, in the panel. The total area of the holes must equal or exceed the area of the drain caps openings. You can position the panel over the pool drain using a skimmer net extention pole. The pool cleaner will ride smoothly over the panel. Reaching the exact size and shape needed may be trial and error. I hope that I have answered your question and that this works well for you.
Posted on Dec 08, 2010
SOURCE: my HTC HD2 is really
You can return your phone to its original state, as it was when it left the factory.
See the link below:
http://www.htc.com/www/howto.aspx?p_id=297&id=182
Posted on Jun 15, 2011
  • 6277 Answers
SOURCE: My Hotpoint aquarius 1100 constantly
(no promises but it's worth carrying this out anyway!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Aug 01, 2011
vqcb43
  • 1623 Answers
Mobile Phones and Acessories
    Verified Fixya Pro
    SOURCE: Cant open market app
    Kenneth-
    Go to Settings > Apps > All Apps > Find the Google Play store and clear the app data and force stop it and then power cycle the phone and then try again.
    Mark
    Motorola Support
    Posted on Jan 13, 2015
    Have downloaded puzzle, been playing for months but now I can't opened the app
    Delete it, Reboot and then go to the app store and re-download it. Sometimes apps get corrupted.
    Jan 14, 2016 | Android Apps
    My i phone 4 get stucked at least 1 in every 45 days
    if it gets stuck force reboot Hold power and home button down for 10 seconds then turn it back on. For performance regularly shutdown open apps double click the Home button. Apps pop up down the bottom, hold finger on one and they all begin to wiggle, click the X in the corner of all the open apps.
    Nov 14, 2013 | Apple Iphone 4s I Phone 4 S Factory...
    For some reason my hilti te 22 is now stuck on reverse any ideas?
    Hi David,
    This is puzzling, since the TE22 was never designed to run in reverse. Neither can the electronics or the switch be the cause, since they too are not laid out to change polarity. The only cause i can think
    Nov 22, 2012 | Drills
    Nokia n70 working slow
    buy again.same unit of cellphoe and maybe it will work fast next
    Nov 13, 2012 | Nokia N70 Cellular Phone
    Ok well i am having a couple of problems with my dash. for one its very very slow and two whenever i go into the settings and click on a tab in the settings it sais error the settings could not bee opened....
    Make sure the phone is not running too many programs at once. I know that when I have Adobe Reader and Windows Media Player open, it will run REALLY SLOW. So, don't have those open at the same time. Also, when I've downloaded 3rd party app, specifically YOU TUBE, my phone has gotten the problem where the settings cant' be opened. In order to fix this, hard reset you phone, BUT FIRST BACK UP ALL YOUR ITEMS THAT ARE STORED ON YOUR PHONE MEMORY, because it deletes them. It also deletes your calendar info, just to let you know. I have pretty much everything on my phone saved on a Micro SD card; I reccomend using one to back up your data. So, to hard reset the phone to get rid of the bugs, go to the Start Menu, go to Accessories, and then click "Clear Storage." Follow the instructions. PS: The phone starts itself up 2 times during the process. Hope it works. Also, in reality, 3rd party apps should work because my brother has the same phone I do, and he has a lot of apps and games on his, and his phone doesn't have a single problem. Guess we're just some of the unlucky ones stuck with a defective Dash.
    Jan 24, 2011 | T-Mobile Dash Smartphone
    How to fix my Nokia N70 It get Stuck and Very Slow
    Pls update your handset firmware. Phone is slow because you might not have uodated your phone firmware. Contact your service delear.
    Jan 29, 2009 | Nokia N70 Cellular Phone
    Phone is slow
    Do you know if your phone has an extra memmry card and which one? And try to find out where is the default destination for saving phone entries..!! If you just tired just reset to the factory default settings..!!! Q: it was from the begining slow?
    Sep 03, 2007 | Motorola Mobility MoroKRZR K1m Cellular...
    Computers & Internet Logo
    42 people viewed this question
    Top The Computers & Internet Experts
    Perry Ralston
    Level 1 Expert
    ashu k...........
    Level 1 Expert
    ted dux
    Are you a The Computer and Internet Expert? Answer questions, earn points and help others
