Question about The Health & Beauty
What does it mean if the green light is flashing and scooter not working
gewiz
  • 1271 Answers
SOURCE: no drive,flashing green light
Are you sure the FREELEVER is in the right position ? , to test try to push the scooter ?
Battery Low ?
Posted on Jun 13, 2009
gewiz
  • 1271 Answers
SOURCE: Scooter batteries will not charge. Green light on
ok, this could be a dodgy connection with the batteries or the charger is at fault ?
1. try another charger
2. check the batteries if possible on another scooter.
3. check the connection on the battery and the charge socket connector.
Regards
GeWiz.
Posted on Oct 01, 2009
  • 177 Answers
SOURCE: need manual for craftmatic scooter
Hi. How many flashes between the pauses? Let me know and I can tell you what is wrong with it. Neil.
Posted on Jul 13, 2010
Ironfist109
  • 3018 Answers
SOURCE: I have a pride gogo
  • What that flash code indicates that there is that the battery voltage is to high to operate the scooter. This can happen for a number of reasons and from out of no where. The manual says you should contact GoGo for this problem. But I know a couple things to try and if they do not work then you need to contact GoGo.
  1. First remove the battery connectors for 5 full minutes and see if that resets it.
  2. You may have a wire that got caught up somewhere so check all wires for breaks in the insulation, cracks etx.
  3. Check the fuse as well.
  4. Push in the main circuit breaker reset button (see diagram)
  • Here is the GoGo Pride Scooter website should you need to contact them and if what I listed does not work then you need to. The things I list are some at home troubleshooting tips GoGo does not offer. They say to contact them immediately. http://www.pridemobility.com/contact.asp
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Jun 16, 2011
caroldon
  • 17130 Answers
SOURCE: freerider Ascot scooter will not
Possible fault in the drive selector switch/ circuit or the motor. You can check the motor, test using a DC line to confirm. If so the selector drive is faulty. check the continuity and the DC drive feed to the motor. It is possible that the circuit is not working and so the board needs a check/replacement.
Posted on Jul 11, 2011
Green light flashes 5 times on Dalton scooter and won't move
hi Richard , do you have a model name of that scooter ?
normally five flashes means a problem related to the magnetic brake...located on the side of the motor.. what about the freewheel lever is it in drive position ?..
regards
Rob
www.gewizrepairs.co.uk
Feb 19, 2017 | Health & Beauty
My active care 1420 spitfire scotter wont start an is blinking green
You need to consult the owners manual to determine what
the blinking light means. It will flash from 1 to 9 times and
repeat the cycle. Count the number of flashes and refer
to the manual to see what the problem is.
Jun 30, 2015 | ActiveCare Spitfire EX 4 Wheel Travel...
My wife's scooter worked until she stopped at bathroom, then returned to no go....key shows full charge, circuit breaker pushed, tranny disengaged and reset, green light blinked 3 times once........ju
You didn't specify what kind or model of scooter, but you need to consult the owners manual for the flash codes.
There can be several flash codes, each one means a specific
issue. I always carry the flash codes with me on my scooter.
Jan 31, 2015 | Health & Beauty
Scooter Pioneer 1 s2354. When turn right won't go and green light flashes
count the flashes, then look in the manual to see what the number of flashes mean. Your controller is probably going bad, though.
May 29, 2014 | Health & Beauty
What does it mean when the green light which comes on with the ignition flashes please? I have a Mayfair economy scooter but it is second hand and I have no user manual with it. The battery shows 3/4...
I AM A TECH FOR ELECTRIC MOBILITY # 1-800-MOBILITY
THE FLASHING LIGHT USUALLY MEANS LOW VOLTAGE AND THE BATTERIES ARE TOO LOW TO RUN THE SCOOTER. REPLACE THEM.
GOOD LUCK
TIM
Apr 29, 2011 | Electric Mobility 4 Wheel Power Electric...
My Lynx L4 4-Wheel scooter green light flashing but it said it is charge it wont go forward
the green flashing light indicates an error with the scooter. Count the number of flashes 4 flashes pause 4 flashes pause etc and your manual should give you the meaning of the flashes Check to make sure that you are not in freewheel move the lever at the back of the scooter up and down a few times and make sure you leave it in drive mode turn on the power and see if the light stops flashing and the scooter will operate correctly Hope this helps
Oct 03, 2010 | Activeforever Lynx L4 Portable Mobility 4...
Green light flashes 9 times will not go
Hi. Different brands of controllers give different fault codes.If this is a dynamic controller, 9 flashes is the code for a faulty controller. This does not always mean that the controller is actually at fault.
It could be a burn't out brake solenoid, that now has a different resistance through the solenoid coil.
You mention the middle speed green light is flashing, normally on dynamic controllers, it is the most left battery level LED that flashes. You might have a different controller.
Have a look under the panels and let us know what controller your machine has.
You could try the agents, and see if they can tell you what the problem is.
Good luck. Neil.
Jun 06, 2010 | Golden Technologies Companion II Travel...
Scooter batteries will not charge. Green light on charger comes on briefly and fan tarts momentarily. Does green/yellow flash mean disconnection as indicated on the charger?
Regards
GeWiz.
Oct 01, 2009 | Shoprider Health & Beauty
Which indicator light on my mobil line battery charge complete
the green light should remain on when fully charged.
Regards
GeWiz.
Jan 11, 2009 | RTO Mobil Line Mobility Scooter Chair...
Health & Beauty Logo
Top The Health & Beauty Experts
iranna
iranna
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
