Question about The Office Equipment & Supplies
The machine is showing fault lamp - The Office Equipment & Supplies
Sir, my canon ir 400 machine shows an error code 803. how can i solve the my problem. give detailed information to my mail. thanking u.
the code 803is for faulty exposure lamp or fault in composite power supply(the power supply to exposure lamp is not sufficiant to operate the lamp).to remove exposure lamp, remove copyboard glass,remove back cover ,slide scanner in the line of rear exahaust fan at the right side of scanner, remove rear exahaust fan, remove lamp holder(one screw).slide out lamp on the rear side replace new one and reverse the whole process.
Jan 27, 2011 | Canon imageRUNNER 400S Copier
We have a sharp AL 1610 that shows CH f 5 on the display and has the light that looks like a belt drive showing. What does that mean?
It appears you have two faults showing up. A 'CH' fault means there is a door or hatch that's open or ajar. Check to make sure the unit is buttoned up correctly.
An F5 code means your copy lamp isn't turning on and off correctly. I recommend that you have a trained service tech diagnose the problems with this machine.
Sep 29, 2009 | Sharp Office Equipment & Supplies
Christie error message "Lamp Interlock Fault"
the switch itself may be broken. check continuity.
May 14, 2009 | Christie Roadster X9 Multimedia Projector
E000003-0010
fault not listed in manual but E003 is to do with the fixing temp check thermistors and heater lamps
May 10, 2009 | Canon imageRUNNER C6800 Copier
Showing E002 and not working
E-002 is an error code for the heat unit in your machine and needs reset, You can try turn it off and unplug it for a couple minutes, plug it back in and turn it back on. The heat lamp or a temp fuse may have blown out in that heat section and need replaced.
Good luck
Bob
Apr 17, 2009 | Office Equipment & Supplies
I am receving error messages E301 or E100
E100 - 001 and 002:
BD error has occurred.
• The laser unit has a fault.
• The BD PCB has a fault.
• The laser driver PCB has a fault.
E301:
The scanning lamp intensity has a fault.
• The scanning lamp has a fault.
• The CCD PCB has a fault.
• The DC controller PCB has a fault.
Seems to that you have issues with dc controller pcb
Oct 04, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Samsung fax/printer model scx5315f
your machine has a fuser unit fault and either needs a new fuser lamp or fuse, you will need a service technician to fix this fault.
Jun 01, 2008 | Office Equipment & Supplies
Blue colour spread
  1. Reset the projector to factory defaults,Change sources. Try plugging the projector into another computer.If the color problem persists, check the cables for bent or broken pins. If any pins are damaged, the cable will need to be replaced with an InFocus-approved cable.
  2. Upgrade the projector firmware. If the projector still will not display the image, it is possible that there is an internal problem that requires repair.
Jan 18, 2008 | InFocus ScreenPlay 4805 Multimedia...
27 people viewed this question
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
