Question about Brother Office Equipment & Supplies
Ii need a mdaanual for my brother rs-36 - Brother Office Equipment & Supplies
    Top Expert:
  • Brother Master
  • 40,233 Answers
Try Googling (brother)(RS-36)(manual) without parens.
Posted on Apr 21, 2017
Testimonial: "yes ive tried that its the brother rs 36 sewing machine i need a manual for it"
My brother rs-36 wont pick up yhr boobin thread please can you help
Try installing a brand new needle. Verify the needle is installed with the flat part facing the correct direction.
If has no positive affect, then it's possible the timing is off on your machine. Search for sewing machine timing or take it for service.
Apr 21, 2017 | Brother Sewing Machines
Error 36 on my brother printer.
Here are some tips to fix error message 36 in Brother: Replace damaged parts error message 36 may go into your printer Brother due to physical damage. Therefore, to resolve the problem by replacing these damaged parts of the printer. Is necessary to replace the maintenance unit with a new one. It is good to improve the transport of PCBs, head or transport unit and motor transport, if they are causing problem. The printer main PCB may also get the problem and you need to replace the main board. You may also need to change the power supply PCB is damaged. Check the power cord to get this error message, you must open the printer to check the internal parts of the printer. You can obtain a series of papers stuck inside the printer to open different covers and paper printer, front and back and more. You can resolve the problem by the elimination of these documents and then restart the printer. You can also take the help of a technician or read the printer manual to open the printer and get the paper. Points to keep in mind that there are some points to consider when taking the above steps to fix an error message 36 on the Brother printer. You have to be careful to replace components of the printer with the latest available. You can also check the user manual of the printer to do these tasks efficiently.
Thank you..........
Jul 26, 2011 | Office Equipment & Supplies
Give me solutation of errore 36 came inb DCP165C Brother Printer
That error 36 - means "Head/carriage unit travel error" , if the printer is still under warranty, have it serviced. But if its out of warranty try to find any obstacles on the travel path of the head/carriage unit. If you cant find anything, it only means you need to replace some parts.
1. carriage PCB
2. head/carriage unit
3. CR encoder strip
4. carriage motor
5. main PCB
6. power supply PCB
7. maintenance unit
May 13, 2010 | Brother DCP 165C Compact Color Inkjet...
I have plugged it in but don't know what to do next, please help
HI irenepaine. I've installed this once and I know it could be a little tricky because you need to use the software to convert whatever design you want - from JPEG to the machine's type. Then you use the card to save the file and then connect it to the sewing machine and then, using the display select the file you want. You need to use like 2 different software to acomplish this. Also you can do it thru the USB cable. Since I can't remember - I'm sending you the brother support site. Please find the correct model and see if it helps.
Please dont forget to rate and provide positive feedback for our free support today. Thank you :D
Apr 29, 2010 | Brother PED Basic Card Writer Box &...
I've got a brother RS-36 and have just got it out after not having used it for a while. When I depress the pedal the neddle moves up and down as you would expect but the machine does not draw the fabric...
You should check whether claw is pulled down ad it has two position. Moreover some machines have switch which lower pulling mechanizm thus it doesnt pull fabric
Sep 28, 2009 | Brother Sewing Machines
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
27 people viewed this question
James Cagle
James Cagle
Jim Keysor
