Televison & Video Logo
A
Anna swanagan Posted on Apr 21, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I go to settings on fire stick the fire stick screen goes blank
Ray Jefferson
Level 2:
New Friend:
  • Expert 50 Answers
  • Posted on Oct 23, 2019
Ray Jefferson
Expert
Level 2:
New Friend:
Answers
50
Questions
0
Helped
11276
Points
165
Turn off the firestick and your router for a couple of mins then try again make sure internet is working and use a VPN
Repairlass1989
Level 2:
Passionate:
Visited the website for 10 consecutive days.
  • Expert 208 Answers
Repairlass1989
Expert
Level 2:
Passionate:
Answers
208
Questions
Helped
59043
Points
280
Unplug it and plug back in and see if that works or u may after by another fire stick
2answers
How can I delete my fire stick remote that is connected to my TV and how can I add it on
To disconnect your Fire Stick remote from your TV, you can follow these steps:
1. On the home screen of your Fire Stick, go to "Settings" in the top menu bar.
2. Navigate to "Controllers & Bluetooth Devices" and select "Amazon Fire TV Remotes."
3. Select the remote you want to disconnect and then choose "Remove."
4. Follow the on-screen prompts to complete the removal process.
To reconnect your Fire Stick remote to your TV, you can follow these steps:
1. Turn on your TV and make sure that it is set to the correct input for the Fire Stick.
2. Press and hold the home button on your Fire Stick remote for at least five seconds.
3. Wait for the remote to pair with your Fire Stick. Once the pairing is complete, you should see a message on the TV screen confirming the connection.
If you want to disconnect and reconnect your Fire Stick to your Element TV, you can follow these steps:
1. Unplug the Fire Stick from your TV's HDMI port and power source.
2. Wait for a few seconds and then plug the Fire Stick back into the HDMI port and power source.
3. Turn on your TV and switch to the correct input for the Fire Stick.
4. Follow the on-screen prompts to complete the setup process.
Once the setup is complete, you should be able to use your Fire Stick and remote as normal.
Firestick want work
*won't
Press and hold the Select and Play/Pause buttons at the same time for about five seconds. Or, From the main screen of your Fire TV, go to Settings. Then go to Device. ... Alternatively, you can unplug the power cord from the device, wait 10 seconds and then plug it back in.
How to Fix a Fire TV Stick That Isn't Responding - Support.com
www.support.com > how-to > how-to-fix-a-fire-tv-stick-t...
10 Troubleshooting Ideas For When Your Amazon Fire Stick Is ...
helpdeskgeek.com > help-desk > 10-troubleshooting-id...
Jun 27, 2020 - ... Fire Stick is not working. You may either see a blank screen, issues with streaming content, or the remote to control the features won't work.
Firestick Quit Working? Here's the 1 EASY Way to Fix It!
www.kodifiretvstick.com > firestick-quit-working
Whether you believe that your Amazon Fire TV Stick has stopped working or that ... If your Firestick won't ... Jul 29, 2016 · Uploaded by KFire TV News
2answers
Fire stick is frozen
A number of scenarios may yield a frozen fire stick. And just what screen is visible during the freeze is sometimes relevant. Other than a reset procedure, you can also consider the scenarios mentioned on the following page:
Solved Amazon Fire Stick Black Screen Frozen updated 2018
Here is a discussion of the reset process:
How to Reset Your Amazon Fire TV
This generally involves pressing select and start simultaneously and after a restart, unplugging and re-pluging the power cable after a brief delay.
Fire stick will not startwhat can I do to start it ? I hook it up once got page that said fire then blank
One idea is trying it on someones TV that you know is working with WiFi.
Another is plugging it into your PC via USB (only) open File Explorer and see what's in there. (Be careful - don't reformat it or delete things from it).
I'm leaving a link on Trouble shooting Firestick & Fire TV, It talks about a blank screen in there.
Fire TV is Frozen Blank or Wont Power On
When I go to settings or anything on the fire stick it goes to a blank screen
I am attaching a link with instructions to restart the firestick and also how to reset it to factory defaults, hope this is helpful.
Fire TV Blank Screen on Boot or Black Screen FIX KFire TV News
I’m happy to help further over the phone at https://www.6ya.com/expert/adrienne_b03fb46fc6334991
Looking t0 register my fire stick
How do you register a fire stick?
You can also view or change the account your device is registered to from the Settings menu:
  • Open Settings from the Home screen.
  • Go to My Account. If your device isn't registered, you'll see a Register option on this screen. Select Register and enter your Amazon account information when prompted.
Amazon.com Help: Register or Deregister Your Amazon Fire
https://www.amazon.com/gp/help/customer/display.html?nodeId=201452550Search for: How do you register a fire stick? register my fire stick Google Search
Problem with getting tv to fire up, takes about 20 minutes of pushing power button to start.
Recent Fire TV software updates causing blank screen issues
www.aftvnews.com/recent-fire-tv-software-updates-causing-blank-screen...
Aug 17, 2015 - Ever since Fire TV software update 51.1.6.1 and Fire TV Stick software update ... update, Fire TV devices now enable HDCP immediatly at boot up. ..... I'm still getting this blank screen issue on one of my TV's but not the others.
How to Get Your New Fire TV Device Up and Running - Wired
www.wired.com/2014/12/amazon-fire-tv-setup/
WiredDec 25, 2014 - Here's how to take that new Fire TV device from zero to streaming in five easy steps. ... How to Get Your New Fire TV Device Up and Running .... I'm not sure why this is not an issue for Chrome Stick, et. al but I invite you to ...
Report Amazon Fire TV / TV Stick Playback issues here - Plex Forums
forums.plex.tv > Google TV & Amazon Fire TV
Jan 10, 2015 - Indicate if your problem is for the Fire TV/ TV Stick or both, if the FireTV, .... when playing files back, i'm getting the same freezing issues regardless of ..... to have to refresh content about 25% of the time when I first fire up Plex.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
