Question about De Dietrich Ovens
Unlock top oven door on de dietrich oven - De Dietrich Ovens
SOURCE: Oven Light does not turn off
The problem is due to a faulty door switch, this is part of the door lock mechanism. The reason is that the oven thinks the door is open , this puts on the light and stops some of the oven functions ie the fan the fan element and probably the bottom element.
The answer is to fit a new door lock mechanism.
Posted on Jun 16, 2008
SOURCE: De Dietrich Oven - Clock tripping back to 00:00 means I cant turn on my oven!
its a fix more than a solution but you can bypass the clock thus allowing the oven to operate again
unplug at the mains and remove the oven from the housing remove the two fastening screws from the metal lid on the top of the oven ,and remove the lid
you will see the timer back panel with 3 wires coming to it, 2 are black (switching line) and 1 is red (Live feed to timer )
If you pull the connectors from the 2 black wires from the timer board and connect the ends together using a connector block, the timer switch becomes inactive and allows the oven functions to operate again.
you will have no timer functions but its a cheap fix and who uses the timer any way
good luck Andy B
ps if anyone has a set of operating manuals for ths oven i would be glad of a copy
Posted on Sep 26, 2008
e-Guru
  • 3917 Answers
SOURCE: HOW TO UNLOCK THE OVEN DOOR
In order to unlock the oven you need to perform the following:
Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
Thank you for contacting Fixya.com
Posted on Aug 07, 2009
barkencoa
  • 3463 Answers
SOURCE: Why does my De Dietrich oven trip the RCD fuse?
You need to replace the oven element, as this is what is causing the prob.
Please rate my solution.
Thanks.
Posted on Nov 06, 2009
SOURCE: De Dietrich oven not working!
I suspect that it is the oven lock that needs replacing. I bought a De Deitrich oven (pyroclean) in Sept 2007. The oven failed to heat in Aug 2009. The oven lock needed replacing which meant the unit had to be removed from the wall. It was replaced under guarantee but failed again in June 2010 and was replaced at a cost of €140 by enginneer. I am very dissappoined in the oven and expected to have no problems with it considering the DeDeitrich name. I would not recommend it to a friend. By the way the clock is easy to use if you follow the instructions exactly. Oven used by two careful owners only.
Posted on Jun 30, 2010
I cannot unlock de Dietrich oven model ump504e1
Unplug the oven from power for 5 min to see if the lock will reset.
Nov 19, 2016 | De Dietrich Ovens
Hot air blowing out at the top of De Dietrich oven, just after putting on new oven seal, fan seems ok what could it be.
Pending on the location of the oven (i.e. not where the seal is) it could be natural ventilation of the oven. Many ovens have ventilation underneath the stovetop.
Sep 02, 2015 | De Dietrich Ovens
Unlock control panel
Function switch must be in the "O" position
Press the " /\ " button for a few seconds until it beeps.
Then use the +/- buttons to set time.
Try powering off and switching back on again if that doesn't work.
May vary between models but De Deitrich do free manuals downloads. Just google it
Nov 10, 2014 | De Dietrich Ovens
De dietrich range cooker very noisy when oven on?
Have you checked the exhaust fans within the oven? These can make a lot of noise if something has come lose. They should be located at the top of your oven or on the back. I would check that.
Good luck
Dec 05, 2013 | De Dietrich Ovens
How do i unlock a de dietrich oven?
Jun 25, 2011 | De Dietrich Ovens
How to get the heating element out of the large oven in a De Dietrich DOD348*
If you mean the element at the back (not the bottom one), inside the oven undo a screw at the back to reveal the element, then undo one more screw attaching the element. THEN, totally disassemble the oven, removing all the cladding, taking off the top oven and controls, detaching lots of wires to be able to do this, in order to finally gain access to the 2 little nuts securing the element behind the oven. Then if you're not sufficiently dismayed by De Dietrich's design skills, email their customer service to be given the wrong part recommendation at twice the price of an independent supplier. Finally, buy part from independent supplier, spend several hours dismantling and rebuilding oven. Then it will work. But maybe don't ever buy De Dietrich (Brandt) again!
Dec 22, 2009 | De Dietrich Ovens
Thanks.
Nov 06, 2009 | De Dietrich DOC310 Electric Single Oven
HOW TO UNLOCK THE OVEN DOOR FOR THE DIETRICH OVEN MODEL DOP440BE1
Aug 07, 2009 | De Dietrich Ovens
Mar 08, 2008 | De Dietrich DOP390 Pyrolytic Electric...
Ovens Logo
26 people viewed this question
Top De Dietrich Ovens Experts
ashburton
Shehu Pro
Shehu Pro
Electro Med Services...
Are you a De Dietrich Oven Expert? Answer questions, earn points and help others
