SOURCE: LCD Tv turns off automatically within few seconds
It is a software problem sony was fixing for free untill 03/01/08
You can unplug your set from the outlet for 30 seconds and it will work fine untill several hours of use acrue again. Found this out on the sony website. hope it helps.
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
SOURCE: volume level
On this model it has a preset volume when it comes on. To change the preset volume press and hold the volume button on the reciever you will hear a beep or 2 and poof its done.
SOURCE: Toshiba (Model : 36A43) - volume goes down automatically
I am having same problem on 32 inch same problem. After playing with board with no results,I tried front buttons and found that if I held the power button in ever so slighItly as not to turn it off, it fixed problem which is the micro on/off switch, I removed the switch and used the remote and everything is back to normal, I am about to insall a used micro switch after I finish typing this but I am sure this will clear up volume problen and menu going crazy problem if not I will just leave micro switch out and use the remote, and I will get back to this board only if that micro switch still causes the problem, so if I don't post in next hour the problem is fixed and I'm more than glad to help.
SOURCE: heater tries to light, then goes out within a few seconds
air psi is too high or jet is cloged
