    New Friend:
    An expert who has answered 20 or more questions within one hour.
  • 56 Answers
Replace the lock unit switch
Posted on May 13, 2017
  • 2651 Answers
SOURCE: Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Posted on Mar 10, 2008
  • 97 Answers
SOURCE: Indesit W1A 111 front load W/M
no need to worry they do this.
hope this helps
please dont forget to rate the helpfulness. thanks kj
Posted on Jul 31, 2008
SOURCE: My hotpoint aquarius wd440 washing machine - flashing lights ?
I have a fairly new Hotpoint Aquarius machine (out of guarantee).
When it is switched on, all of the red lights flash and it will not operate.
Can you help please ??
Posted on Dec 06, 2008
SOURCE: Hard scratchy towels. Have used all wash cycles, and use fabric softener
have you tried just white vinegar as your rinse aid. Do a full cycle of your washing machine using white vinegar instead of detergent, to clean any residue from pipes, and then in the next wash try white vinegar as your rinse aid.
Posted on Apr 18, 2009
SOURCE: bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
Posted on Jan 07, 2010
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Feb 12, 2015 | Indesit Washing Machines
Why do my machine flashes red lights when pluged in AC and nothing else works ?
Replace doorlock and mainboard.
If all five spin cycle buttons flash, its a fatal error.
It depens on which wash button that ligths up.
One of them is doorlock error, the other is main board error
May 21, 2014 | Bosch WAE24166GB
Error code 1000 on blomberg washer
We found a way to reset the computer and solved the problem.
1. Press and hold pause turn off machine and turn back on holding pause all the while.
2. This should reset the computer. All lights will light up on LCD display.
3. Release pause button. Turn off machine, turn back on and begin a new wash cycle.
woo hoo!
Apr 08, 2013 | Blomberg WM87120 24" Front-Load Washer...
Lights flashing and unable to start cycle. Helped once when turned off at mains but not now.
Hi it could be your door lock switch your machine on and wait for 6 seconds and try to open the door if you can thats your problem or may be that the door catch ic worn try and push the door shut with a bit more force
Jun 29, 2011 | Hotpoint Aquarius WF210 Front Load Washer
Whirlpool washing machine wont stop all lights
Check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out.
While the machine is on press "end of cycle" for 3 seconds, then wait for 2 minutes to try the door. Try this again if it does not open, this is the child lock program - to lock and unlock; it is the same procedure.
How abt a nice rating for the free help? Thnks
Jan 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Flash from the back of the washing machine.
it sounds like the brushes have gone in the motor that turns the drum
Apr 21, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Oct 18, 2008 | Hotpoint Aquarius WD63 Front Load...
Door Lock Light - flashing
does the door still lock? becasue it sounds like a faulty lock. It may need to be replaced.
Aug 25, 2008 | Hotpoint WMA46 Front Load Washer
Open Questions:
Frigidaire GLTF2940ES3 washer cycles/controls out of whack since replaced main control board -- is there a compatibility problem with our 11 year old washer? Bought washer in 2007, Frigidaire GLTF2940ES3. Stopped working, got error code suggesting problem with main control board, so replaced it with new, part# 137006000. Didn't fix problem, got new error code suggesting problem with speed control board. Replaced that with new, part# 134743500. Now washer works at least, all the cycles we've tried do something plausible, but the controls and cycles are out of whack. For example, when I set the dial to normal, it used to show 52 minutes in the display, now it shows 28 minutes. When I set the dial to heavy, it used to show 56 minutes in the display, now it shows 52 minutes. Did they rearrange the dial since 2007? If so, is there a key we can use to translate new dial labels to old dial labels? It seemed like there was only one way to assemble the knob and dial, so I don't think I put it together with the dial in the wrong position. Or is this a common failure indicating that the new main control board is defective? Easy to imagine a defective control board causing one or more cycles or controls not to work; hard to imagine a defect that results in the case we have, i.e. everything working, but cycles scrambled. Our laundry room is tiny and we've got the dryer stacked on top of the washer, so it's a major hassle to get at the main control board major hassle like can't get into the refrigerator or use the back door of the house while the laundry machines are un-stacked. Otherwise I would swap the old one back in and see what happened. Any thoughts or suggestions welcome! Thank you.
Mar 18, 2018 | Frigidaire Washing Machines
Washing Machines Logo
Top Washing Machines Experts
