Question about Makita Drills
Makita 1 1/8 rotary hammer (corded)not working. Light comes on but no drilling action.
  • 2712 Answers
SOURCE: hammer drills and rotary hammers comparison
Basically yes. Lower power units are usually titled as "hammer drills." Higher power units, usually labeled "rotary hammers," tend to be larger and provide bigger impact forces. But there are a few differences that are worth knowing: The rotary hammer usually have a chisel only feature, for light chiseling and masonry removal. Rotary hammers also have specially designed chucks that only accept bits specifically designed to fit their chuck. The special chuck on a rotary hammer helps hold the drill bit and prevents it from slipping during use.
Posted on Aug 27, 2008
jimboz4
  • 305 Answers
SOURCE: Sir, I have a Powerbase Xtreme Rotary SDS 1200W
http://manuals.syntigroep.nl/manuals.htm
have a look here, they have just about every owners manual on the planet
Posted on Jul 23, 2009
deme-tri
  • 90 Answers
SOURCE: I have a makita hr2455x rotary hammer drill that won't hammer
you need to get that service,
the grease causes the hammering.
and probably too much pressure was applied
to it.
Posted on Dec 03, 2009
rowdy45176
  • 2176 Answers
SOURCE: i have a makita hr300c rotary hammer drill.
it sounds like it needs new o rings and serviced. you can go to Makitatools.com and download a breakdown for this tool, If you are handy and take your time they are not that bad to repair. Let me know if you need more assistance.
Posted on Mar 21, 2010
SOURCE: which is the best rotary hammer drill to buy
Hi
yes it is a good tool all deppend on what kind of work you want to
do with it ,
just remamber this is not a jack hammer it is a light impact
Hammer Drill. and it is a problem free if it used for the right
work and load.
Posted on Oct 07, 2010
I have a makita hr4011c rotary hammer drill, was working perfect then stopped, plugged into transformer but green light has come on on the drill but no action from the drill,
Did you check to see if the motor is even being energized.? If not check the switch. If yes, then check motor brushes.
Mar 29, 2017 | Makita Drills
Makita drill burnt out
The motor is bad from overheating. Have motor rebuilt or replaced.
May 24, 2014 | Makita Hr3210c 1-1/4" Avt Sds-plus Rotary...
MAKITA HR3000C HOW DO I REMOVE THE HAMMER/DRILL MODE CHANGE SWITCH
The big control levers off, but the small one only comes off once you have removed the screw and have it in the down position.
Sep 27, 2012 | Makita HR3000C Electric Rotary Hammer
Makita
possible broken spindle or gear in the gear case
Aug 26, 2012 | Makita HR3851 Electric Rotary Hammer
Makita HR4041C rotary hammer drill
There is no tension to adjust on the Makita HR4041C rotary hammer drill. If you are not getting the hammer action you think you should be it's possible the o-rings on the piston are damaged or not lubricated or the striker is stuck or not lubricated enough to work properly. If you're having problems with the bit turning, there are several gears that turn the bit that could be slipping or are stripped. If you need a manual or brakedown of the tool, one is available on www.makitatools.com. The insides of rotary hammers are fairly complicated so be carefull of what goes where if you decide to take the tool apart to check for internal problems.
Aug 26, 2012 | Makita HR4041C 1-9/16" Spline Hammer
Whats it mean whene the top light comes on and it wont drill wit the makita hr3000c
green light up : all electrical contacts are ok
red light on : time to replace carbon brushes ant if possible bring back for maintenance kit
Nov 17, 2009 | Makita HR3000C Electric Rotary Hammer
Makita HP1640 hammer drill dual mode - 2 hours
Exchanged Makita HP1640 hammer drill for a new one. The 2nd drill did the same thing in under an hour!! Will return for refund. Instructions say the Forward/Reverse switch must be in a full up or down position for the Hammer/Rotary switch to move; well, it is and the Hammer/Rotary switch still stops at a 1/2 way point between modes. Although I can still use the drill, instruction warnings say not to because it may potentially burn out the motor. I'll have to go with a different brand this 3rd time around. It seems to be a design flaw.
Oct 10, 2009 | Makita Drills
to it.
Mar 25, 2009 | Makita HR2455X 1" Rotary Hammer Drill
Drive systems Question
SDS (or Slotted Drive System) bits for hammer drills/rotary hammers allow the bit to slide in the chuck and enhance the hammering action of the tool. For most applications, these bits provide plenty of torque. SDS Max bits are similar to SDS bits, but have larger shanks and come in larger sizes than SDS bits. These powerful bits are useful in industrial applications.
Aug 27, 2008 | Makita Rotary Hammer 450 Rpm, 2500 Bpm,...
Drills Logo
98 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
