Question about Cell Phones
How do I connect my iPhone to the internet? - Cell Phones
    Top Expert:
  • Cell Phones Master
  • 12,744 Answers
Open settings turn on wifi if off and sign into internet if a password is needed
Posted on Apr 21, 2017
    New Friend:
  • 24 Answers
Via a router
Iphone 5c won't connect to internet after upgrade. Google works fine
If Google (search?) is working, then you ARE connected to the internet. Specifically, what isn't working?
Oct 02, 2014 | Apple iPhone 5
How to connect an iPhone to the Internet
Connecting your iPhone to the internet is an easy process. You just simply use any application on your iPhone which uses internet service.
Your iPhone can either use WiFi or Cellular for internet access.
- A WiFi network is simply a wireless network. You can find them at coffee shops, libraries or even at your house if you a router setup for wireless access.
- Cellular data networks allow Internet connectivity over the cellular network. Check your carrier's network coverage in your area for availability.
When you use an application on your iPhone that requires internet service it will either connect to the last WiFi network used, or if that network is not available it will list all available networks in range. You can simply tap on the network you wish to join and it will connect. If the network requires a password it will show a lock icon. If no Wifi networks are available your iPhone will connect over the cellular data network and fees may apply.
To see all the Wi-Fi networks in range, from the Home screen choose Settings > Wi-Fi. Tap a network to join it.
I hope this article was informative. You can check out more of my tech articles by clicking here then going to the Tips section.
how to connect iPhone to the internet, connect to internet, iPhone internet, connect iPhone internet, how to use internet on iPhone, iPhone internet application, iPhone wifi, iPhone wireless internet connection, iPhone no internet, internet not working iPhone, iPhone 3g,
on Jul 09, 2011 | Apple iPhone Smartphone
How can I share an internet connection using a PC?
On your PC, open up Control Panel, click on Network And Internet, Click on Network and Sharing Center, then on the left side click on Change Adapter settings. On the tethered iPhone connection, right click and select Properties. On the Sharing tab, check the box to share that devices connection with other devices on the network. Click OK and close out of the open Network connections window. Connect your ethernet cable from your computer to your router's Internet/WAN port and run the router setup. If the setup does not detect the network correctly, configure it to use DHCP.
If the shared connection method doesn't work, try selecting both your LAN and iPhone connections in the Network Connections screen, right clicking, and selecting Bridge. Then proceed with instructions as written.
Jul 19, 2014 | Apple iPhone Smartphone
IPhone can't connect to Internet thru my router
What is the model number of your router?
If your wireless network is secured then make sure that you have the correct network key.
See how to connect to WiFi on IPhone
May 23, 2012 | 2wire HomePortal 1000 Router
Tether my iphone 4 for free
step 1 : From Home Screen select Settings
step 2 : Select General > then select Network
step 3 : Press Internet tethering to turn the function on
step 4 : Connect it to the PC using the USB cable or using Bluetooth
step 5 : Once handset is connected to PC , Select iPhone from the list of available connection using the Internet access icon in the system tray. Press connect and you'l be able to surf the internet using your device.
Apr 08, 2012 | Apple iPhone4 4G iPhone 4
How we connect internet to iphone
The iPhone can connect to the internet through both Wi-Fi and EDGE. Wi-Fi would be the wireless network at your home or business. When the iPhone connects to the internet through EDGE, it is actually connecting through the AT&T phone connection (or any other service provider the iPhone works with in the future).
safari.jpgTo the connect to the internet, you simply need to open up Safari (which is the internet browser used by the iPhone). If you're used to using a pc, think of Safari as the 'Internet Explorer' that the iPhone uses. You can use Safari the same way you could use Internet Explorer.
Once you open up Safari, the iPhone will attempt to connect to the internet. If there are wireless networks available wherever you happen to be, the iPhone will prompt you to choose one to connect to. If you're trying to connect to a network that has security, you will be prompted to enter the password for the network.
If you want to check to see whether there is a wireless network available where you live, work, or play, go to 'Settings' and then 'Wi-Fi'. The iPhone will show you all of the wireless networks that are available.
If there aren't any wireless networks to connect to, iPhone will connect to the internet over EDGE. Connection speeds over EDGE will likely be somewhat slower than they would be over a Wi-Fi network. You will also not be able to answer phone calls while connected to the internet through EDGE. If the iPhone is connected to the internet over EDGE you will see this small icon at the top of your screen: edge-icon.jpg
for more information you can go thru this link
Hope this helps. Please rate my response.
Have a good day
Dec 29, 2010 | Opera Software Mini
Iphone 3g waps message
even if you're not using the internet, the iphone automatically connects you to the internet that's why it keeps on prompting you. try changing your settings so that you wont automatically connect to the internet.
Jul 26, 2010 | Apple iPhone 3G
Iphone Wifi/Internet
On your Iphone part of the service should be web through Att anywhere you have a cell phone signal you should be able to connect to the internet.
Jun 18, 2008 | Apple iPhone Smartphone
Cell Phones Logo
64 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
