I need to remove my timing belt on my e z go golf cart
You have to pull the clutch, remove the cover, losen the idler pulley, move the pulley to give slack in the belt, install new belt. You align by using the key-way grooves in the cam and crank shaft. Both should point straight up.. once on, lossen the bolt on the idler pulley and let it go tight, and then tighten the nut.
