Question about Pool & Spa
Can modlel sba033bc pump be used in salt water?
3 Suggested Answers
  • 19 Answers
SOURCE: my water softner pumps water into salt container,
Your line running from the softener has an air leak, inspect your connections, redo them to ensure sealing
Posted on May 18, 2010
  • 10 Answers
SOURCE: how do you set the panel on a salt water intex pum...
to set the system, hold the down button until it beeps, then hold the up button until it beeps. Now the system is ready to set. Push the up button to the desired number of hours you want it to run. Now, hold the down button until it beeps, then the up button until it beeps. It should be locked and ready to start working.
Without knowing how large your pool is, I can't give you an exact amount of salt to use. If you know how many gallons your pool holds the formula is Gallons x 0.025 = pounds of salt to start up. When you need to add salt, its gallons x 0.0067 = pounds of salt to add when needed.
Posted on May 28, 2010
Culligan water softener manual
You are likely using a rock salt and what you are seeing is a build up of dirt and fine sand because rock salt isn't clean... it's got rocks in it. Clean your tank out and rinse it thoroughly with a hose. Be sure to clean out your 3" tube (brine well) and under the salt platform if you have one. Start with a clean salt like System Saver II or Crystal Plus. Never fill your salt tank over half full. Always let your salt be used down to the water level. IF the salt at the water level is soft and pasty don't add more; tip the salt tank until the salt is raised along one side or corner to above the water level when you stand the tank up carefully. This will allow all the water in the tank to become brine (saturated solution).
IF you are using potassium instead of salt, the brown is a natural component. Don't worry about it although it never hurts to clean your brine tank yearly.
Aug 04, 2014 | Water Dispensing & Filtration
Can I use pool salt in my summer escapes pool?
if you have a salt system add salt but you have to shock pool to get it clear
Jun 09, 2014 | Intex Automatic Salt Water System for ...
Can i put salt instead of sand in my pump
No you cannot. Sand is used in a sand filter to filter the water to remove dirt. Salt is dissolved in the pool water and a salt water chlorinator produces chlorine using the salt.
Aug 27, 2012 | Intex Pool & Spa
We purchased the Intex 633T pump. We want to know if this pump can be ran with saltwater pool?
Unless the manual specifically says otherwise there should be no problem. The salt level in salt water pools is very minimal, so it's really no different than using mineral additives. Do pay attention to salt system though as far as using other mineral additives such as copper or silver algaecides as they can damage the salt system.
Sep 19, 2010 | Intex Krystal Clear Model 635 Pool Filter...
I have an Intex Ultra Frame 24'x52" pool. We are installing the saltwater filtration system today. How much salt will be need to use and are there any other chemicals we should use for the initial setup?
I HAVE THE SAME POOL FOR YOUR FIRST START UP ADD 310 OF POOL SALT. IF YOU DO NOT HAVE A INTEX SALTWATER CHLORINATOR I WOULD SUGGEST GETTING ONE. IT WILL GIVE YOU READINGS ON LOW SALT, HIGH SALT, AND ALSO HAS A BOOST FOR COPPER IONIZATION, WHICH KILLS ALGEA AND BACTERIA. MIX YOUR SALT AROUND THE POOL AND LET THE PUMP CIRCULATE IT. GET A TEST KIT TO CHECK YOUR SALT LEVEL. IT SHOULD BE AT .OO3 OR 3 PPM. TO DO A GOOD JOB OF KEEPING YOUR WATER CIRCULATED YOU MAY NEED TO UPGRADE YOUR PUMP FROM THE 2500 GPM TO THE 4000 GPM PUMP. THE INITIAL SALT YOU ADD SHOULD GET YOU IN THE BALL PARK. AFTER CIRCULATING AND SWIMMING A FEW TIMES CHECK THE LEVEL AND IF TO HIGH LET OUT WATER AND ADD FRESH, IF TO LOW ADD MORE SALT. ONCE SET YOU SHOULD BE GOOD TO GO AND ENJOY FOR THE SEASON. HOWEVER I RECCOMEND CHECKING YOUR POOL LEVELS WEEKLY. HOPE THIS HELPS.
Jun 22, 2010 | Intex Automatic Salt Water System for ...
I'm thinking about getting a above ground pool. Can I use the pump that comes with the pool to for salt water? And what is the routine for salt water maintance and start up?
What kind of filter comes with the pool?
If your using an intex pump don't waste your time. They do not pump enough.
If you are getting a sand filter then by all means get a salt system
Start up is simple ad x amount pounds of salt determined by the volume in gallons of your pool then filter only for 24 hours then you can start generating chlorine.
Just remember just because you use a salt system does not mean you do not need chemicals you will still need to use a stabilizer and keep track of ph also a good non foaming algaecide and crystal clear solution should be used
here is a manual for salt set up click on the top pump and look at around pg 15 this will give you salt to gallons ratio for pounds of salt needed
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?lst_docsea=2009&source=intexstore&gid=2&lid=8738
Jun 24, 2010 | Intex Automatic Salt Water System for ...
I have a salt water clorinator system can I use softwater salt instead of pool salt when I set up my pool
no you must use a 99% pool salt
The electro cells in a salt generator can not turn anything else into sanitizer ( chlorine )
Jun 21, 2010 | Intex Automatic Salt Water System for ...
How do you set the panel on a salt water intex pump mdl no.8110 and how much salt do use
May 20, 2010 | Intex Automatic Salt Water System for ...
We switched to the saltwater system and the water is cloudy after 2 days
DID YOU USE POOL SALT, MINE STAYED CLOUDY FOR 2 WEEKS AND FINALLY CLEARED UP , I USED THE WRONG SALT , 25LB BAGS OF TABLE SALT FROM SAMS CLUB
Jul 18, 2009 | Intex Automatic Salt Water System for ...
My saltwater pool tastes very salty, but my intex saltwater pump keeps saying low salt. I have to clean the cell everyday or it will not operate properly because the cell gets covered with white buildup...
Your salt is way to high if you can taste it. You will need to dilute with fresh water until you get the salt back down and then clean the cell for continued use.
Jun 25, 2009 | Intex Automatic Salt Water System for ...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
